Двигатель 1.6:
FV6P-7J104-JF от 12 июля 2017
Остальные
Двигатель 2.0 (бензин):
Остальные
Номера запчастей:
Состав комплекта
Состав комплекта
FAQ:
Еще немного информации:
Next (2025)
mixir
22 May 2015
3,3M
1,3K
21,4K
mixir
5 September 2015
TotalFocus
Why did you go for a wet clutch design when dry clutch is supposed to be cheaper and more fuel efficient?
That’s a very good question and we have spent a lot of time discussing it. At the end of the day, we have to have an effective product portfolio in terms of cost. With a dry clutch you cannot cover everything from 100 Nm to 500; in any case, if you want to be very sporty and have very high performance, you have to have a wet clutch. And at the opposite end of the scale, with very small engines we are beginning to recognize that many of them are coupled with quite heavy vehicles and that the thermal constraints on these small vehicles are sometimes greater than on a C or D-segment car.
Why precisely is this the case?
If you have a small engine which is unable to accelerate the vehicle’s mass, or accelerate it fast enough, you have to go for much more synchronizing time – and that obviously generates more thermal calories, which must be dissipated. So for very sporty cars with high torque you need a wet clutch, and for undersized engines in oversized vehicles you also need a wet clutch. There’s an area in the middle which works very well with dry clutch, and we have very effective ones in production today. But since we are developing a complete family [of DCTs] with shared technology and shared software, we made the clear decision to have commonality in terms of products. And with this new technology of pump-on-demand we don’t see any significant difference between wet and dry clutch [in terms of efficiency].
Does this mean dry clutch DCTs are finished?
I cannot speak for our competitors, but our new generation of DCTs at Getrag will be 100 percent wet clutch. However, our current [dry clutch] 6DCT250 is one of the very best for fuel efficiency and it will stay on the market for another six to eight years.
источник
Короче смысл в том что сухое сцепление подходит оптимально для С класса и атмосферных движков, для турбированных и движков с большим обьемом нужно мокрое сцепление, сами гетраги считают эту коробку удачной в своем сегменте, и планируют продавать до 2021 года. Так что о каком провале тут речь?
focus68
5 September 2015
L
LS2k:
1,6 титаниум, прошивка HB
сделал калибровку сцеплений форсканом и стиралка и вибрации пропали, теперь все плавно как на новой машине из магазина)
посмотрим надолго ли
А можно поподробнее как это делать. Есть Форскан и есть адаптер ЕЛМ327, в какой пункт этой программы лезть и что делать?
Alex49
5 September 2015
F
focus68:
Читать тему совсем нет желания?
Автомат Power Shift (часть 2) (сообщение #16924137)
focus68
5 September 2015
Alex49:
Если бы эти ссылки работали, и если бы эта версия была на сайте, а её там нет, как быть?
ovsianoi486
5 September 2015
focus68
Как раз таки на самом оф сайте форскана. В открытом доступе лежит прога с функцией адаптации
rays2
5 September 2015
focus68
Нижняя ссылка прекрасно работает.
Но для любого "ковыряния" в машине лучше использовать ELS27, он быстрее и надежней. Едва ли у вас оригинальный ELM327.
ELM327 я бы использовал только беспроводной, только для мониторинга на смартфон.
Что значит быстрее.
ELS27 - скорость 2 Мб - перепрошивка PCM(TCM) - 7-11 минут
ELM327 -скорость 500 кб - перепрошивка PCM(TCM) не менее 40 минут.
mikryashov
5 September 2015
F
focus68:
http://forscan.org/download/FORScanSetup2.2.6.test310815.exe
Крымчанин фф3
5 September 2015
ovsianoi486
Делал уже адаптацию? проблем не возникало? что дало?
ovsianoi486
5 September 2015
Крымчанин фф3
Делал и не один раз. Проблем сделать адаптацию практически не возникло. Щас был новый релиз форскана от 31.08.15. Что дало да стиралка стала меньше а все остально осталась так же. Прошивка TCM. HB
Alex49
5 September 2015
Небольшие наблюдения: после установки EA (1.6) все стало прекрасно с коробкой, даже очень. Пробеги в основном трасса. Но в какой то момент пришлось проехаться в пробке час-два может быть, после чего опять появились небольшие дергания периодически, в основном при проезде лежачих полицейских (тормоз-газ). Это вот если так работает адаптивность коробки, то накой она тогда нужна? Может это риторический вопрос, но нельзя ли было как то зафиксировать состояние коробки без всякой адаптивности?
Сейчас поставил HB, выполнил калибровку, будем посмотреть.
idler73
5 September 2015
Народ, кто ставил ВV6Р-7J104-РD и какие впечатления?
idler73
5 September 2015
Огромное СПАСИБО! разработчикам FORSCAN за функцию адаптации коробки,теперь хоть не надо ехать к ОД и за 2000 р. делать у них
maxik292
5 September 2015
добрый день Уважаемые форумчане. у меня такая проблема: коробка переодически на ходу стала вставать в нейтральное положение. когда это происходит на щитке приборов загарается чек, загорается система курсовой стабилизации и на табло пишет система помощи трогания в гору не доступно, обратитесь в сервис. что это может быть? делал диагностику: диагностика по коробке пишет - переодичное пропадание питания на блок TSM. по двигателю пишет ошибку- потеря связи с блоком TSM. кто знает подскажите в чем проблема?
astashov
5 September 2015
maxik292
ТСМ накрылся. Что-то посыпались у всех.
maxik292
5 September 2015
astashov
А проводке дело не может быть?
АНДРЕЙ1973
5 September 2015
maxik292:
astashov
зачем гадать? к мастеру вам.
astashov
5 September 2015mobile
maxik292
Машина на гарантии? Делай диагностику.Какой год и пробег?
maxik292
5 September 2015
astashov
Машина не на гарантии. Пробег 160000 тыс. Год 2012г
Iluha2069
5 September 2015
какие пробеги приятные
focus68
5 September 2015
mikryashov:
За ссылочку спасибо, осталось как то расширить лицензию
advert1sing
5 September 2015
Господа рекомендую Вам, оставаться лояльной к данной марке на которой вы ездите, у VAG с dsg, вообще слово из четырех букв.
ILuxa-DobriFey
5 September 2015
maxik292:
astashov
Пробег действительно внушает, прям завидую.
Наверное там если разобрать много чего надо будет поменять и сцепление и вилки и уплотнители.
Блок TCM скорее в сего покидает этот мир, а стоит он сейчас не мерено, может позволить себе только Москвич его купить.
Silvice
5 September 2015
maxik292:
Помирает модуль управления трансмиссией, сокращенно TCM. Пора модераторам крупными красными буквами в заголовке написать признаки смерти TCM, каждое 10 сообщение в этой теме одинаковое.
TotalFocus
5 September 2015
advert1sing:
VAG с dsg
уже несколько раз писал и модули управления PS Ford и DSG VAG сделаны в одном и том же месте отсюда все корни.
advert1sing:
пусть у японцев коробки покупают, а не у халтурщиков-бракоделов европейцев, ничем уже они от нас по отношению к работе не отличаються
TotalFocus
5 September 2015
mixir:
- собственно все и сказано.
В Германии нет ни одного Фокуса с PS сухим в продаже - это не признак отказа Форда от хлама, там где есть возможность его заменить.
Крымчанин фф3
Было у кого такое, что когда включаешь режим s , то на экране не видно, что он включился, а показано будто ни одно из положений не включено?
TotalFocus
5 September 2015
Крымчанин фф3:
это значит что или сдох ТСМ или клинит вилка сцепления - диагностика.
buser-of
5 September 2015
Крымчанин фф3
Было такое! Авто дергалось изначально, КАЛИБРОВКУ ДЕЛАЛ, СЦЕПУ НЕ МЕНЯЛ! Просто в один день пропала тяга на 2-й передаче, на тапок жму, а ничего не происходит- только дергается" повозка"! После выключения зажигания, ничего не изменилось. Постояло авто 5 часов-все прошло! До этого были такие же симптомы, правда с промежутком в 2 ткм. В тот момент переключение в S не привел ни к чему ( единственное что пропала индикация на табло)! Ошибка была " высокое напряжение на исполнительном мехнизме вилке переключения А(. ОД Сказал, что ничего не увидели- катайся пока не прикатишь авто на эвакуаторе... дословно...ездейте- поломается- катите к нам! Самое главное бумажку взять в этом случае... Как то так!
Крымчанин фф3
5 September 2015
Спасибо большое!
Была такая же ошибка "высокое напряжение на исполнительном мехнизме вилке переключения А(В)
Решил вопрос сбросом клемы с аккумулятора на 5 мин. Режим S теперь включается без проблем.
АНДРЕЙ1973
5 September 2015
это только начало конца
