А ведь Ecoboost тоже с прямым впрыском, однако
Вот, например:
1.6-litre EcoBoost (150, 182PS)
Type Inline four cylinder turbo petrol, direct fuel injection and Ti-VCT, transverse
Displacement 1596
Bore 79.0
Stroke 81.4
Compression ratio 10.0:1
Max power 150 (110) / 182 (134) at 5700 rpm
Max torque
240 (270 with transient overboost) at 1600-4000 rpm (1900-3500 rpm for overboost)
240 (270 with transient overboost) at 1600-5000 rpm (1900-4000 rpm for overboost)
Valve gear DOHC with 4 valves per cylinder,twin independent variable cam timing
Cylinders 4 in line
Cylinder head Cast aluminium
Cylinder block Cast aluminium
Camshaft drive Timing belt with dynamic tensioner
Crankshaft Cast iron, 4 counterweights, 5 main bearings
Engine management Bosch MED17 with CAN-Bus and individual cylinder knock control
Fuel injection High pressure direct fuel injection with 6 hole injectorsEmission control Close coupled three-way catalyst system with heated oxygen sensors and catalyst monitor sensors post catalyst
Emission level Euro Stage 5Turbocharger Borg Warner KP39 low inertia turbo
Lubrication system Pressure-fed lubrication system with variable displacement pump and full flow oil filter
System capacity with filter 4.1
Cooling system Water pump with thermostat and valves, with thermal management system
System capacity incl heater 5.5
