Программы для диагностики и конфигурирования на базе ELM327
15 years ago
Взял китайский клон адаптора ELM327
на 5atm.ru работает ина высокой кан шине и на средней!
ELM, ELM327, диагностика, диагностический адаптер, диагностический разъем, конфигурация
vovanmal
13 April 2010
2,6M
10,1K
civil-zz
11 May 2014mobile
mrwadi
Да, это значит, что этот блок не может по стандартному запросу отдавать свой номер железа..
fyl
11 May 2014
Hi Civil-zz,
Need some help. I encountered this error when trying to configure Cruise Control and programming PCM.
Here is what I did
1) continue to work with high bus (HS-CAN)
2) PCM => Information => Read
3) PCM => Configuration => select the type of module (PCM) presented in the Information tab (n. 3)
4) click " Read from PCM ".
5) do the next step backup (preservation) VID-block, ie current configuration (the button "Save"), in case of unforeseen problems, as well as for the possibility to revert to the original settings.
6) in the section " Configuration "select Availability cruise control .
7 make a copy of your current firmware: go to the "Procedures" => Page 2 and click "Read firmware PCM to BIN file" ( this procedure by default in a single file with the firmware saves and VID-block). If errors occur, then try to change the size of the block.
8) I then disables / enables the ignition and restarted ELMConfig. Repeat step 4 & 6.
9) start to download your firmware back: in the same section (PCM => Procedures => Page 2) click "Download the firmware from HEX / PHX / BIN file "and select your firmware file you created in step 8. program asks" is not empty VID block, use it as the current? ". I answered "No" to use the configuration loaded previously in the program (see step 5) and modified in step 7.
10) exhibiting the block size for writing "Auto" and click "Save current firmware in PCM". On the question of inserting in the current firmware VID-block firmware respond positively (ie, yes) .
Then it starts erasing memory ... and after about 30 seconds it gives the above message. After that car cannot start.
I managed to get it to program back to original (car can start) doing step 9 by answering "Yes". Still no cruise control yet.
Appreciate if you can advise.
[GOOGLE TRANSLATE]
Привет Civil- ZZ ,
Нужна помощь . Я столкнулся с этой ошибке при попытке настроить круиз-контроль и программирования PCM.
[ IMG] http://media.ffclub.ru/up249424-error-1399821113.jpg [/ IMG]
Вот то, что я сделал
1) продолжать работать с высокой автобусе (HS- CAN)
2) PCM = > Информация = > Прочитать
3) PCM = > Конфигурация = > выберите тип модуля ( PCM ) , представленную в закладке Информация (п. 3)
4) нажмите кнопку «Прочитать из PCM " .
5) сделать следующий шаг резервного копирования ( сохранение) VID- блок , то есть текущей конфигурации ( кнопка «Сохранить »), в случае непредвиденных проблем , а также за возможность вернуться к первоначальным настройкам .
6) в разделе "Конфигурация" выберите Наличие круиз-контроль.
7 сделать копию текущей прошивки : перейти на "процедуры" = > страница 2 и нажмите кнопку «Прочитать прошивки PCM , чтобы BIN файл " ( эту процедуру по умолчанию в одном файле с прошивкой экономит и VID -блока ) . В случае возникновения ошибок , а затем попытаться изменить размер блока.
8) Я тогда отключает / включает зажигание и перезапуска ELMConfig . Повторите шаг 4 & 6 .
9) начинают загружать прошивку обратно : . В том же разделе ( PCM = > Процедуры = > Страница 2 ) нажмите " Скачать прошивку с HEX / Финикс / BIN -файла " и выберите файл прошивки , созданный на шаге 8 программа просит " не пусто VID блок , используйте его как текущий ? ». Я ответил : "Нет ", чтобы использовать ранее загруженную конфигурацию в программе ( см. п. 5 ) и изменение в пункте 7.
10) выставляется размер блока для записи "Авто" и нажмите кнопку "Сохранить текущую прошивку в PCM " . На вопрос о вставке в текущем прошивки VID- блока прошивки отвечают положительно (то есть , да ) .
Тогда он начинает стирать память ... и примерно через 30 секунд он дает на это сообщение . После этого автомобиль не может начать .
Мне удалось получить его для программирования обратно в исходное ( автомобиль может начать ) делает шаг 9 , ответив «Да» . Тем не менее не все же круиз-контроль.
Цените , если вы можете посоветовать
mzt
11 May 2014mobile
civil-zz
Может есть мысли по глюку замка багажника. Вот только что ехал с дачи. Открыл машину. Все открылось. Положил в багажник вещи. Приехал к подезду багажник уже не открывается.
Sholoiko
11 May 2014
mzt
Вы ранее писали что машина хетч, тогда проверяете проводку Проблемы с замком багажника (сообщение #1547575)
фокусник555
11 May 2014
Многие дают ссылку на эту тему. когда я спрашиваю как вообще начать работать с ELM 327... Тут много полезного . Но мне надо понять как вообще сейчас воткнуть адаптер чтоб он показывал что-то на ноуте когда он к машине подключен!!!) НУ подскажите где посмотреть как адаптер с ноутом и вин8 срастить?? пожалйста!) Дело в том что тема начата довно , возможно тут уже это разжовывали- НО Я немогу найти((( с меня пиво
Sholoiko
11 May 2014
фокусник555
могу удаленно Вам настроить и по скайпу все объяснить, так проще чем расписывать все нюансы. так или иначе будут вопросы. если что пишите в ЛС
mzt
12 May 2014mobile
Sholoiko
Данная проблема характерна для седанов. Я конечно ещё раз проверю на предмет излома проводов. Но у меня такое ощущение что какая то проблема в млзгах.
Sholoiko
12 May 2014
mzt
Насчет седана не знаю, но если судить по информации из топика, то чаще с этой проблемой сталкиваются универсалы-хетчбеки.
Мозги надо проверять в самую последнюю очередь, если проверка проводов, кнопки открытия, и самого привода (мотора) открытия не выявило проблем, то да начинаем смотреть мозги
civil-zz
12 May 2014
mzt
мыслей особых нет если по мозгам, то все стандартно - почитайте ошибки, попробуйте перезагрузить GEM, скинуть клемму..
а вообще да, надо проводку смотреть..
mzt
12 May 2014mobile
Sholoiko
Как раз всегда страдают седаны. Все разберу посмотрю. Может действительно микрик в кнопке умерает. И банальное совпадение.
R2d2_MEPhI
12 May 2014
mzt:
Sholoiko
- среди темы про замок есть вот такой пост: Проблемы с замком багажника (сообщение #15399538) . Так что все-таки у вас скорее проблема в замке, вряд ли мозги будут периодически глючить, они либо его открывают, либо нет
mzt
12 May 2014
R2d2_MEPhI
Хорошо спасибо. Видимо совпало с ковырянием в машине.
Но у меня просто болезнь другая. Нажимаю кнопку на ключе открытия багажника один раз. И далее открываю багажник нажимая кнопку на самом багажнике. Замок срабатывает. т.е. сама кнопка работает. Такое ощущение что машина закрывает багажник как при использовании центрального замка. Проверю еще раз все провода и саму кнопку.
smartm
12 May 2014
dva1979
Спасибо! Воспользовался Вашим советом, но видать я бракованный, не смог найти ответ на свой вопрос. Программка ELM-FFN хороша, но активации круиза не нашел...
SIMych
12 May 2014
Вопрос возник. Я тут давеча "клал" приборку, поднимали адс-кой, это понятно. У человека нашлась прошивка древняя (rom243 или как-то так), в этой прошивке загоралась красная стрелочка по достижении оборотов отсечки, а вот в новой прошивке 512 нет . Можно её как нибудь вернуть в обратный зад?
И ещё, я так понимаю, приборка знает реальную скорость, но индицирует на спидометре с приличной погрешностью. Сравнивал в тестовом режиме БК, на нафигаторе и собственно спидометре, показания БК и нафигатора сходятся. Нельзя ли теперь "обучить" приборку правильно показывать и скорость на равне с температурой?
Skorpion
12 May 2014
Кто может обменяться elm с usb. Вы мне свой перепаянный, а я вам такой. Просто руки не оттуда растут.
Евген2115
12 May 2014
SIMych
Есть в этой прошивке стрелка!!!
Программы для диагностики и конфигурирования на базе ELM327 (сообщение #15476523)
Поставь галку в пункте "индикатор переключения передач".
SIMych
12 May 2014
Евген2115
В том то и весь прикол, галочка как стояла так и стоит, настройки приборки при перепрошивки не поменялись. Даже при включении зажигания она не загорается, а раньше загоралась. В тесте она горит, всё нормально.
Romich811
13 May 2014
Евген2115
"индикатор переключения передач" и красная стрелочка по достижении оборотов отсечки - это разные вещи.
Про индикатор вот тут было Программы для диагностики и конфигурирования на базе ELM327 (сообщение #15391623)
Евген2115
13 May 2014
SIMych
Romich811
Мы про это говорим!?
-sav-
13 May 2014
Евген2115
Не работает на 1.8 и 2.0 , из-за этой галки пропадает настройка ЭГУРа,
Евген2115
13 May 2014
-sav-
понятно . просто у меня 1,6 - никаких проблем не было с ней!
Romich811
13 May 2014
Евген2115
Нет не про это, а про красную стрелку по достижении отсечки.
Потому что на 1.6 нет ЭГУРа.
Maverick_NE
13 May 2014
-sav-:
Евген2115
вот оно че... а я голову ломаю куда у меня настройки ЭГУРа делись
хорошо еще что зима была без снега и мне не понадобилось настройки менять
PrizraK
13 May 2014mobile
Maverick_NE
Maverick_NE
13 May 2014
PrizraK
оффтоп такой оффтоп
SIMych
13 May 2014
Исходя из вышесказанного, почему в старой прошивке всё вместе работало, а в новой либо настройки эгур либо стрелошке? Мне, конечно, настройки эгур не очень важны, я один раз его в "спорт" поставил (нравится очень чёткое положение "0") и больше не трогал, но всё-же. Делать хуже новыми прошивками не есть хорошо, как-то так...
fyl
13 May 2014
Привет Civil-zz / всем Могу ли я узнать, где я могу скачать старую версию ELMCONFIG
ELMConfig v0.2.10
ELMConfig v0.2.10b
ELMConfig v0.2.10c
Serj63
13 May 2014
fyl
В шапке в разделе конфигурирование и прошивка модулей
fyl
13 May 2014
Serj63:
fyl
спасибо
Matit
13 May 2014
Всем привет. Сегодня диагностика с помощью FORScan показала несколько ошибок. Стер их, завел машину, заглушил, снова запустил диагностику и остались две ошибки. Подскажите из-за чего может быть?
Больше интересует ошибка B2477-60 (B2477 Module Configuration Failure)
В сети нашел инфу что это относится к подушкам безопасности... Подскажите, пожалуйста.
