Круиз контроль, установка
1) Чтобы иметь функцию круиз-контроля, достаточно врезать в руль и подключить кнопки, а также активировать функцию круиза и ограничения скорости при помощи дилерского или стороннего оборудования.
2) Вместо установки кнопок можно приобрести руль с уже установленными кнопками
3) Функцию круиз-контроля можно установить и активировать на любой комплектациии
4) Никакие дополнительные модули не нужны
круиз-контроль, установка круиза, своими силами, прошивка круиз контроля, ADSL, ограничение скорости
sv209
4 September 2011
1,1M
4K
Richiemac
19 February 2014
Ok, thanks.
I will order them now.
What to check on Microcat ?
DeadlySin
19 February 2014
Richiemac
Order them throught FINIS codes.
If it is your photo upwards you need only 1801776 wire hardness. Its better to change right buttons on the airbag from "face" to "OK", because they will not work
Richiemac
19 February 2014
Ok, Google translate is not very accurate...
I have ordered them .
When they arrive i will report back.
Thanks for your help
Richiemac
19 February 2014
One more thing...OK button is 1687313...correct ?
DeadlySin
19 February 2014
Yep 1687313
Richiemac
19 February 2014
On the way Thanks.
Richiemac
21 February 2014
Parts came yesterday so i install ok.
With UCDS i write ' with cruise control ' to BCM.
Do i need to change anything else ?
Richiemac
21 February 2014
After writing to IPC and BCM...i have following DTC
BCMii B112B
RCM U0140
U0253
PSCM U0140
ABS U0140
Help !
Universe
21 February 2014
Richiemac
ADD "WITH ASL" too
Vanj
21 February 2014mobile
Хочу поставить круиз контроль
Комплектация титаниум 2012-13 год выпуска
Руль на фото
Какие нужны провода подскажите пож.
1801776 или 1801772
Спасибо
Richiemac
21 February 2014
Of course...i forgot ASL.
All ok...working now
Many thanks guys .
One thing...right side 'OK' button is doing nothing...??
pepa
21 February 2014
When programming had to sew - cruise control and limitator (Auto Speed Limit).
pepa
21 February 2014
I'm happy for you that everything turned out. Good luck.
Richiemac
21 February 2014
Maybe change ' OK ' button to ' M '...?
Not working ...everything else is good.
pepa
21 February 2014
I'm not writing in English and I can not translate
You help this message
Круиз контроль, установка. (сообщение #14343144)
Richiemac
22 February 2014
Thank you . I will try to understand. Google Translate is sometimes difficult to follow...
DeadlySin
22 February 2014
Richiemac
You need to change the type of buttons to "Audio buttons and MFD remote controller in steering wheel" if you use OK button
Richiemac
22 February 2014
Ok. Done it. Perfect now. Thanks a lot
Philter
23 February 2014
Ребят, если кнопка в подушке руля с войсом, то проводку берем аналогично с кнопкой M?
karlon3
24 February 2014
Если самому колхозить проводку от круиза до разъема то какой она должна быть длины ?
mlk
3 March 2014
Please confirm:
FF3 1.6 tdci 95 from 2011 with OK-M steering wheel:
to install cruise control I should change a wheel and buy:
1801774 . проводка руля под круиз и джостик РП-7 1687313 . кнопка ОК правая ???
First_99
8 March 2014
Ребята подскажите кнопки круиза заказывал на tuningshop.su вырезали установили в руле кнопки по распиновки все сошлось прошили не работает Лим скорости почему и для чего он нужен,круиз выставляешь скорость он держит Кан рес сбрасывает и добавляет а-аа кнопка Лим не хочет работать...
rays2
8 March 2014
First_99
Круиз это одна функция, лимитер это вторая.
Тебе просто не включили его. Значит "прошивальщик" начинающий
First_99
8 March 2014
Значит надо еще раз шить...
karlon3
8 March 2014
First_99
А тебе 23 и 224 байт активировали?. Себе сегодня сам ELM активировал все работает.
Friz
8 March 2014
First_99
Лим это ограничение скорости выше которой машина не поедет, но если нажать педаль в пол, то будет разгоняться и дальше.
По поводу прошивки уже писали неоднократно, что не может работать круиз без лима, либо оба, либо ничего
First_99
8 March 2014
У меня один круиз работает а-аа Лим кнопка не реагирует когда нажимаешь...???
First_99
8 March 2014
А-аа можит быть что распиновка не правильна из за этого Лим не работает...???
INTERsport
11 March 2014
А на механическую коробку можно поставить???
rays2
11 March 2014
INTERsport
хорошая шутка.
Можно поставить на любую комплектацию, любую комбинацию двигателя + КПП
