[EN] Focus Mk3 (2011) quick help
5 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
330,3K
D-K
10 October 2014
Hi
I swapped my FF3 factory fitted insturment cluster for C-max instrument cluster BM5T-10849-JS (HW: BM5T-14C226-BE, SW: BM5T-14C026-BL).
I want to update the firmware, but I have no idea where to look for the firmware files. Could you please give some direction?
Thank you.
slanick
11 October 2014
D-K
look here Панель приборов
Universe
11 October 2014
D-K
TRY HERE
D-K
12 October 2014
slanick Universe
Thank you both. I have one more question;
How to find what is the latest firmware for my cluster?
KoopaTroopa
15 December 2014
Hello,
I see you are doing some great things to your cars but most of the communication is in Russian which I do not speak.
Is it possible for someone to walk through what modifications to the electronics systems you have found in English? There are many people in the US that could benefit and possibly support the projects you are working on.
We are using Focccus but have read some things about UCDS but the information is very limited on UCDS.
Universe
15 December 2014
KoopaTroopa
Hi!
This topic was opened special for english speaking people. You can ask a question you`re interested in here. We try to answer it or at least google translate the appropriate post from this forum.
I`m a user of UCDS so some special questions may be asked too.
wjtwjc
3 January 2015
Who can tell me how to make such an interface? Thank you
wjtwjc
3 January 2015
At the same time, the interface is such. Below 0 degrees Celsius is red snow light, greater than 0 degrees of less than 4 degrees Celsius is warning yellow snow lamp
wjtwjc
3 January 2015
_bleak_
? Thank you
Boris98
3 January 2015
wjtwjc
If you want to get the red and yellow snowflake light just flash BU firmware. To get ST logo set #236 parameter of central config to 03 ST.
Alex49
3 January 2015
wjtwjc
What do you mean "such an interface"?
As we see you have ST dashboard.
Giuseppe209
26 March 2015
Hi,
I have a little trouble
I tried to update my IPC my Focus with the program FOCCCUS, but unsuccessfully. The IPC is dead, would not light up, I tried to do even recover, comes to 99% after 50 minutes and then tells me he can't upload file VBF.
HW: 8M5T-14C226-AE
APP: 8M5T-14C026-AAC
EEPROM: 8M5T-14C026-AEC
Please help me, thanks a lot.
Best Regards
Giuseppe Africola
ittrium
30 March 2015
Giuseppe209
Could you tell which device do you use for firmware upload?
Baudrate?
Timeout in device advanced settings (see in "Device manager")?
Please attach the log if you have one. If you don't have any try again with logs enabled.
It is recommended to set 500k baudrate for ELM327 and 2M baudrate for ELS27, 1ms timeout in case FTDI uart bridge.
duorw
15 April 2015
Guys,
I have a Focus Mk3, without cruise, no DDS, so I heard that I can upgrade the firmware of my gauge, and after the upgrade, I would be able to enable these cool functions with Fcccous.
I'm not sure how to update the firmware, but I found below info from internet, it is said that they are from this forum, it would be much appreciate if you could confirm that this will work.
I already bought a ELM327 with FTDI chip, and the speed can be set to 500k, so I guess that would work.
I bought another gauge just in case I would damage my own one.
so besides of below firmwares, may I know where we can get the latest firmware for the gauge?
Sequence of actions is as follows:
1. ELM327 (revised) manually set the maximum speed 500000kbp
2. The program is unchecked (FoCCCus) cars and maximum speed, because falling out when reading error.
3. Downloaded firmware and calibration files from here
4. Open the tab IPC click GET INFO rewrite everything in a notebook. Click READ rewrite everything in a notebook. (If something goes wrong diagnostician will be easier to restore the "brick")
5. Open TOOLS tab click BROWSE specify the path to
- BM5T-14C026-AAA (there where you saved it) press START forward 100% then specify
- BM5T-14C026-AEA (to where you saved it) press START
ittrium
22 April 2015
duorw
You need ELM327 with switch for MS-CAN bus, because IPC on Focus Mk3 is on MS-CAN.
The sequence is correct, but actually you don't need to update calibration if just want to add DDS and cruise.
It may be enabled on old fw versions. All you need is to change direct configuration in IPC and change central configuration in BCMi. Then for DDS you have to execute ABS initialization (still in FoCCCus).
But anyway your ELM327 must be with MS/HS-CAN switch, or you need STN1170-based tool, which has two can buses out of the box.
duorw
22 April 2015
ittrium:
duorw
Hi Ittrium,
Thanks for your reply.
I have tried with these two files, but they both failed with error "Error During Loading VBF", I'm not sure if it's because of the poor wire. My wire has a switch for MS/HS-CAN. and I have tried to edit BCM with HS-CAN, enabled "Auto Locking", it's working, also under MS-CAN, I uploaded two SBL files successfully. (BM5T-14C025-BD and BM5T-14C025-AD), but uploading BM5T-14C026-AAA and BM5T-14C026-AEA both failed. I can see in the status bar, when it's trying to "Loading Secondary Bootloader", then if failed immediately.
Kindly share any ideas or concerns, if we can confirm it's the wire issue, I will buy a ELS27 and try again.
ittrium
22 April 2015
duorw
Seems that your ELM327 is not stable or fast enough. Is it based on FTDI chip? If so, try to set timeout to 1 ms in device properties in device manager (default is 16 ms). And if it doesn't help, enable logs in FoCCCus and share here.
duorw
22 April 2015
ittrium:
duorw
Yes Ittrium,
I'm using ELM327 with FTDI chip, and I have set the timeout to 1ms in device manager already, still got same issue. I captured the log, please help to check.
hidden
duorw
22 April 2015
By the way, the speed is 500000 when starting Focccus.
duorw
28 April 2015
Guys, it is much appreciate if you can provide any update, any advice/guidance will be helpful.
ittrium
28 April 2015
duorw
Seems that now it is not ELM327 related problem.
The problem is that your IPC doesn't accept the secondary bootloader to the address it is uploading.
Maybe your IPC is different and is not supported by FoCCCus yet.
I will check the right bootloader according to your log a bit later and will let you know.
duorw
1 May 2015
ittrium:
duorw
Thanks Ittrium,
Let me know if I can help, maybe there is some kind of scan software, which can scan the car for the SBL address? I'm not sure, well, thanks again for your help!
duorw
1 May 2015
I was told that UCDS can flash my car's IPC, not sure if this helps.
tracer
3 May 2015
Hello Everyone,
I have a question does new LIFT steering wheel is plug and play ?
I want to install this one:;
I have this one:
Universe
4 May 2015
tracer
Hello!
You will need new Airbag, and new steering wheel module assembly. Old one does not support cruise control.
tracer
4 May 2015
Hello
I have cruise control now with old steering wheel, buttons are on left bottom side.
How can i check my module version ?
Universe
4 May 2015
tracer
I`m not sure but it may be needed to install new BCMii module from Focus MY 2015 . Today I will try one.
tracer
4 May 2015
Universe
Thanks for info.
My last question, how to get and where is located BCM ? Does BCM contain VIN ? I have new car from 2014 and I am thinking what happens if i change BCM.
Did you try install this one to 1.6 E.B ?
tracer
23 May 2015
Universe
Did You try to install this Steerwing Whel in 2014 BEFORE Lifting Focus Titanium ?
I am thinking to buy the steerwing wheel but not sure if it will work ?
