[EN] Focus Mk3 (2011) quick help
5 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
326,9K
Universe
11 January 2018
kuhler
Did you try to insert previous SD card ?
kuhler
11 January 2018
Hi, the Universe
I bought a display without an SD card, this is the first time I try to run navi. I have checked the contacts in the card slot, they looks good. I am trying to insert a normal 2Gb FAT32 SD card, navigation system see this card (engineering mode) as FAT 2Gb.
When I try to insert 8Gb FAt 32 micro SD with an SD adapter, the system can not see this card. I have no experience with this and I do not know exactly how this system should work.
How to set the parameter "# 072 NAVIGATION / TRAVELER ASSISTANCE" and # 127 NAVIGATION SYSTEM "in the UCDS FF3 AsBuild configuration - is this important for MFD5 navi?
clepsy
16 January 2018
Anyone know the FINIS code for sync 2 8" screen dash bezel for facelift? It looks like I got the 4.2" nav bezel I'm lost with this codes
rfr78
18 January 2018
Does anyone know what parameter in AS-BUILT of IPC is responsible for MENU: Hdlamp delay ?
kalashnikoffer
19 January 2018
Universe
Do you have experience in swapping SYNC 1.0 APIM to a SYNC 1.1 APIM?
I need as-built data for the SYNC 1.1 APIM (Sony w/ 10 Speakers, Nav, Emergency Assistance) because my SYNC1.1 APIM is from a Fiesta and i drive a Focus MK3 02.2014
Mark12
31 January 2018
Hello, after following everyone's hard work in topic " Installation of a regular bi-xenon " and translating with the help of google, I changed my halogen headlamps to xenon, added HCM, and added front and rear height sensors. I had factory wiring in place and my car is a 2014 focus titanium 1.0 eco boost.
Headlamps: Xenon from focus ST3. Left: BM51-13D155-MA Right: BM51-13D154-MA
HCM: AM51-13K031-CA New unit and had not been previously programmed
Rear height sensor: AV61-5A955-AB
Front height sensor: AM51-13D034-AA For cast iron arm
I checked a titanium x VIN with xenon from the factory on microcat for levelling sensors and HCM, I have used foCCCus to change bcm configuration, headlamps are set to 05 HID, Xenon lamps work and move down and up when ignition is switched on, LED DRL work normal and cornering lights work with the steering wheel position.
The problem I have is that I still have an error on the HCM of missing calibration that I am unable to clear, I have used IDS to calibrate but it warns about a DTC and then fails to complete, I have tried Forscan level and calibration but it also fails, I have tried IDS programmable module installation and it says the module was successfully installed, but even if I run this with HCM disconnected it still says successfully installed? I have also installed the auto levelling headlamp switch inside but I am still unable to calibrate
Can anyone help me out with this and find out what is missing?
HCM Data through IDS, HCM can see both sensors and the values change when pushing down on the car.
HCM ODDTC
HCM CMDTC
Forscan Headlamp Alignment and Calibration error: Service procedure has been interrupted
Forscan HCM DTC
Headlamps from ST3 with black bezel
dj.martzian
8 February 2018
Hi Guys,
Maybe this is not the right topic to ask, it's very hard to search because Russian is not my native language.
Do you have a PCM firmware(especially for 1.6L Gasoline engine) that support the "Shift UP" indicator?
Note: Respect for all your hard work and dedication.
Thank you very much.
civil-zz
8 February 2018
dj.martzian
there is no such firmware. only some 1.6/2.0 TDCi supports it.
dj.martzian
8 February 2018
Thank you Master Civil-ZZ for quick response.
Respect
ozeraksu
11 February 2018
I'm active in traffic sign recognition, but it does not work. There is a camera in the vehicle fabrication. It did not work with FOCCCCUS * 240-2 actively. What should i do? please help me.
the vehicle's etis software number and As-Built codes
can not be selected. it is inactive
http://www.youtube.com/watch?v=z4KCSYgZSnY
ozeraksu
20 February 2018mobile
Thank you @mikryashov
Szymon_Zy
24 February 2018
I have few question.
1. Are there any cid changable sd cards still on the market? During upgrade Sync 1.0 to Sync 1.1 (BTW: from Fiesta) I forgot to take out my MicroSD and broke it. I still have spare original one but I would like to make a backup.
2. When I upgrade my IPC with:
код
SBL - F1ET-14C025-BB.vbf
Main SW F1ET-14C026-ABJ
Second SW F1ET-14C026-ACH
F1ET-14C026-AFG (not ST Calibration)
Signal calibration F1ET-14C318-AC
I will gain 2xtrip computer and restyle on IPC but Navi still will be blue. Is there any restyle soft for navigation unit?
3. Could you point me to place where I can read (with a little help of google translator) about fitting Sync 2 to 2013 TI FF3 prelift with Sync 1 and navigation unit?
marko_b
28 February 2018
Hi Guys,
I have FF3 2014 with sync1 + navi (prelift)+ front and rear sensors and would like to change software of odometer to facelift.
What software do I need to do that ?
What will be the consequences, do I loose something?
I have got ELM327 v4 - interface Vscan STN2120 USB,
BTW:
Do you maybe have some instruction how to change sync1 to sync3?
BR,
Marcin
Szymon_Zy
25 March 2018
Is there any dorastyle firmware I could put into navigation screen APIM?
olteas01
9 April 2018
gonghao
Hallo,
When the BCM changed, the keys had to be rewritten?
As you rewrite them if needed, I also want to change BCM face lift 2015 (F1FT-).
All the best!
gonghao
9 April 2018
O
olteas01:
gonghao
Hallo,
All the best!
Yes, you should do PATS programming for changing BCM.
olteas01
9 April 2018
Thank you very much, this is just the Ford dealership I know.
semiho
9 April 2018
Hi all!
My car is a restyle Focus, 2015. I installed original backup camera recently to SYNC 2. Camera works with no problem, except dynamic lines and zoom. LIN bus of camera is connected to 32th pin of C2280B.
BCM throws B1088:86-2F "Invalid signal - LIN bus B" DTC. Are there any solutions? Does my BCM incompatible with camera?
Thanks!
didotom
26 April 2018
Hello guys,
I have a focus st 2015year form USA with sync small LCD,
I update firmware to 5.11, but still no polish language,
I update to :
Update 5.11: https://yadi.sk/d/6hJhebIe3Nr2iB
so what can I do to get Polish language
Now there is only
English, French, Spanis.
Maby I should install this:?
E1BT-14D205-AJ.rar
and
E1BT-14D207-AA.zip
Bootloader: https://yadi.sk/d/BSblVcGx3Nr32U
VIP: https://yadi.sk/d/hyGpGo833Nr2vw
if it is needed, so how can I install this? Via forscan? Or foccuss program?
At the attachment there is photos from my menu.
Thank u for help
best regards
lukaszooo
11 May 2018
Hey.
I have a Focus 1.6 TDCi 95PS and would like to do it on 115PS
Vin: WF0LXXGCBLBP28071
Module: BV61-12A650-AXF
Soft: BV61-14C204-AXF
My friend has a 115PS version and it has a soft BV61-14C204-NF
If it loads SBL: AV61-14C273-AA and sw BV61-14C204-NF will work?
Jak wybiera sie plik SBL ???
semiho
19 May 2018
Hi friends!
Can somebody help me with thatcham buzzer? Where is it located in a 2015 Focus?
clepsy
19 May 2018mobile
It is said is under the wheel arch, but I could not locate exactly how to fix it, therefore I'm also interested for this
clepsy
28 May 2018mobile
I saw that there are 50w 2 ohm speakers instead of 25w 4 ohm, both with blue membrane (premium) what is the difference? Will the 50w improve the sound?
semiho
7 June 2018
semiho:
Hi all!
Thanks!
Just for the info.
I swapped BdyCM to F1ET-14A073-EG. Previous one was F1ET-14A073-BE. Dyanmic lines are working now.
YEmrE
27 June 2018
hi.
What type of terminal should I use for vacancies in BCM? C4 or C8 socket.
Ford Focus 2017.
edit:
cable diameter 0.35 or 0.50 mm2
marko_b
30 June 2018
I am asking specialists for help and I will thank you for your help so far
I just end up with sync1 on sync3 and I have only one problem ... no sound from usb ( it is being detects, indexes but when I want to play some mp3 -> silence) the same as I want to play music from the phone directly, the sound is only from the CD - it clearly indicates the lack of connection (audio) between APIM and ACM ... I have already checked the plugin (54PIN) twice ... and it is as below (Did I miss any other PINs that are required) ???
Audio (PIN):
ACM> Sync1> Sync3
12> 25> 23
25> 26> 24
13> 23> 25
26> 24> 26
8> 3> 3
21> 4> 4
BTW: I do not have connection between sync1 and sync3 on pin21 and pin22 (it is shield), do you think it cause a problem...
Any idea how could I check it... (resistance or ...)? somehow connect in short ...??
marko_b
9 July 2018
I have update ACM to AM5T-14C044-GS but still the same... no voice from usb
FLA
24 August 2018
Hi friends,
my sister has Ford Focus Combi 2.0 TDCi Duratorq Titanium Plus (2016, at this time cca 50.000lm) what is very strange and finaly wrong is the fuel average , there is 0,7l/100km. What is wrong with the board computer?, I dont know how to proceed, may be reset or ... any idea?
thank you
ter
25 August 2018
FLA
Try to reset your trip values, just press and hold left joystick "ok" button. This should help.
Superb1
15 September 2018
Can any one help provided the correct update filenames for my IPC.
I would like to update to the restyled version
HW CM5T-14C226-BA
SW BM5T-14026BT I think should be BU (Focus St)
PROM CM5T-14C026-KB
P/N CM5T-10849-AJD
Thank you
