[EN] Focus Mk3 (2011) quick help
4 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
280,7K
Superb1
15 September 2018
^ I should add this is an Australian model, I see you can update to F1ET version
Superb1
16 September 2018
My Car is ST built Germany VIN WF0KXXGCBKCS87354 so I'd expect my dash to be Europe style firmware.
Can I use?
ST:
firmware: F1ET-14C026 -AAJ
firmware: F1ET-14C026-APG
signals: F1ET-14C318-AC
Muma2620
19 September 2018
Hello can anybody help me?
I have just upgraded my Focus mk3 preface lift from Sony Mfd5 to SYNC 3.
I have two questions,
1: SYNC 3 voicecontrol wont work, it says *BING* when pressing on steering wheel button but no sound.
2: Is it possible to program my car so my reverse camera (Non OEM) shows sensors (The little car icon)
Superb1
25 September 2018
I can help with 1: set the option DM8 in forscan/foccus in central config
Muma2620
25 September 2018
Superb1:
I have programmed car but it’s still not working.
Take a look at this link
In the link there is pictures of programming and a video of problem
rfr78
3 October 2018
Hello!
I have small problem with rear PDC.
Module LIFT F1ET (2015) for rear only.
Before I upgraded to SYNC3 I had visualisation on screen.
After Installing SYNC3 I have nothing.
When I set PDC Rear via FORSCAN 7D0-04-02 xxx* xx 1=rear PDC, i have error:
Code: B1087 - LIN Bus A
When I remove PDC settingd from APIM error dissapears.
Where is the problem?
regards
rfr78
cavallo76
5 October 2018
Universe
Hello dear.
Acm bm5t-18c815-rl work whit sync 2?
Universe
5 October 2018
cavallo76
sure
it is base 9 speakers audio unit, no tmc, no dab
rfr78
5 October 2018
Muma2620
You should turn your camera:
Reverse Camera APIM 7D0-01-01 x*xx xxxx xxzz
0=disabled,
2=enabled,
A=enabled with obstacle detection
8=To mam ustawione czyli disabled"
Than show vehicle in camera view:
Vehicle Style in Camera Views APIM 7D0-02-01 xxxx xxx* xxzz
1=Sedan,
2=Coupe/Convertible,
3=Truck,
4=SUV/CUV,
5=Van,
6=Hatchback"
and set PDC on HMI (unfortunatelly I have no forscan style sets to provide)
regards
clepsy
6 October 2018mobile
Is there a list of apim codes both pre ans facelift, which ones are on what level of quality and options?
cavallo76
6 October 2018
Universe
My friend want mount sync 2. On his car he has auto park, park assist and rear / front park sensor. Which are bit for able on APIM?
Universe
10 October 2018
cavallo76
I don`t know which bits are koz I use UCDS
Badrick
7 November 2018
Hello Clubmates!
I would like to retrofit OEM ACC in my car. (VIN: WF06XXGCC6EG58444)
I hope I can ask some questions and someone can answer me. I tried to google translate and read a lot but still have questions.
1st.: Do I need any more hardware module above the ACC radar and wires? I already have OEM LIDAR. SO the ABS can brake I think. (I hope VIN helps)
2nd.: If the ACC module is enough, can I download or rewrite the sw on the modules? For example I buy MK3 Focus(BV6T-9G853-), Everest (EB3T-9G768-) and reFlash them or only the MK3.5 Focus will work (F1FT-9G768-)? Or even Volvo, Jaguar or Land rover modules can work?
So it should come only from Focus due to calibration and embedded position parameters or we can make something?
Thank you very much, I hope everything is understandable.
Badrick
olteas01
11 November 2018
gonghao
Hello,
You can help me with the BCM replacement procedure for a Focus 3/2011 with BCM from Focus 3.5 / 2015.
I tried replacing it with IDS and when replacing the BCM, I can not put my contact (the message appears not to see the keys) and move on to write the keys to the new BCM.
Thank you in advance!
cavallo76
18 November 2018mobile
Universe
Hello.
Ms can into OBD II is same ms can on sync 2/3 and gpsm?
Universe
19 November 2018
cavallo76
Sure
cavallo76
19 November 2018
Have anyone Pinout of hub of sync 2?
cavallo76
22 November 2018
Universe
Do you know Pinout of control panel fo sync 2?
semiho
22 November 2018
cavallo76
cavallo76
22 November 2018
semiho
Thank you.
Is it OK my image?
semiho
22 November 2018
cavallo76
YW. Don't remember exactly but I found this image. You can also check from the connector itself, pin numbers were marked to red part If I remember correct.
cavallo76
23 November 2018
semiho
Thank you for info. Unfortunately I have not red plug. I doing new cable for my friend. He is Away from me.
cavallo76
9 December 2018
Universe
C
cavallo76:
Do you know Pinout of hub of sync 2?
Universe
9 December 2018
cavallo76
cavallo76
9 December 2018
Universe
my cable is correct. Why hub doesnt work?
Doesn't work SD.
How work sd and usb? by usb only or need of this?
cavallo76
9 December 2018
Universe
read up
Universe
9 December 2018
cavallo76
Needs power of cause
cavallo76
9 December 2018
Universe
does it need power by second cable?
Universe
9 December 2018
8-1 power
38-10 ground
And usb enough
cavallo76
9 December 2018
Universe
why do I have a voltage between 7 and 9 volts? is it ok?
