[EN] Focus Mk3 (2011) quick help
5 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
318,6K
zivny.ondrej
13 January 2020mobile
PRP
Thank you very much. I dont have UCDS. Can I change it in Forscan?
PRP
13 January 2020
It is impossible with Forscan.
zivny.ondrej
14 January 2020mobile
PRP
I think there will be another setting somewhere else and I dont know what and where. Because I have Sync3 in my Focus, where it works in tunels and in testing menu it shows speed. And when I put this Sync3 from Focus to Mondeo, it does not work in tunel and does not show the soeed in testing menu. Do you have any idea? Thank you very much!
AuRoN89
14 January 2020
it's not impossible with forscan. you just have to know the correct byte
Muma2620
31 January 2020
Does anyone know if SYNC 3 has TCM with voice warnings? I have activated TMC (and yes i have a ACM with TMC).
It displays road work icons on navigation, but it doesnt say warning traffic ahead etc.
My old Sony mfd5 had TMC and it did have voice warnings so can it be true that SYNC 3 doesnt have?
AuRoN89
31 January 2020
it does, when it want.
zappero38
15 February 2020mobile
PRP
Hi,i am updating my my 2012 Ford C-Mac BVC to Sync 3,all i plugged and the screen goes on,the new control panel buttons work fine except for the door lock one the steering wheel control dos not work yet
The issue is that when i scan my car with Forscan i can’t find apim and don’t know if the problem is coming from the HS Bus wires (53 and 54) witch maybe not connected correctly,so help please.
PRP
15 February 2020
Where did you connect with HS Can and MS Can? You also need MM Can. Your BVC connector only has MM Can.
zappero38
16 February 2020mobile
For hs can bus i connected them in pin 6 and 14 on the OBD 2 plug,for ms can bus in pin 18 and 19 on the blue climate control connector.
zappero38
Issue resolved after checking out the HS can bus wires so I can now configurate APIM.
Thanks for all.
zappero38
21 February 2020mobile
Hi all,i am still struggling with my BVC to Sync 3 upgrade
Almost every thing is working but i have a sound issue when ignition or engine is on sound goes off as i put it off sound comes back and when i switch the old ACM sound works correctly but i can’t hear the car’s and people voice talking to me although they do hear me.
I don’t know if it’s a programming or wiring issue?
PRP
21 February 2020
Did you make this connection from the table. If not, give it a try.
zappero38
Yes,although i don’t have sirus.
LaForge
5 March 2020
Hi there,
my Name is Karsten and I have a serious Issue with my IPC.
I have flashed a wrong File (Strategy F1ET instead of BM5T) and after a sucessfully flash it takes a reset and never comes up again.
Its dark and dead. No longer accessable. NO IPC was shown in car configuration.
I tried to connect it directly to my ELS327 (Original) Adapter like the attached plan shows, but no result.
I am using a 12V 2A Power Source. I guess it should be enough to send power to the IPC.
FoCCCus cant connect to ECU.
What can I do?
can someone help?
Best regards
Karsten
piroon.eng
26 March 2020
Hele me
my car ford everest MY 2017 (3.2,4x4) Updated to a new version(Sync_3.4.19200_ROW_Base_NonNav_CYANLABS), but an error occurs is "Navication fault".
zappero38
29 March 2020mobile
Hi,did anyone tried to use this lane keeping camera CV4T-19H406-CF with a focus mk3 ?
tired_pilot
30 March 2020mobile
P
piroon.eng:
Hele me
Sync version you have installed has no Navigation. Error is correct if your Sync has navigation before
ZaQik
15 April 2020
Z
zappero38:
yes, it works
zivny.ondrej
31 May 2020mobile
Hi, did you install any one ST boost gauges in MK3 1.6tdci? I knew before installation, that it doesnt work with this engine. Just want to know, if you made any one any progress to make it work in 1.6tdci? Thank you.
PRP
1 June 2020
I also have a plan to put a ST boost gauges on my Focus MK3 1.6 TDCI and as far as I know it will not work only the pressure of the turbo. I have a video of a person who put it on and the turbo readings are wrong. I have a connection diagram and the signals are received via a can bus. With the ST motor, the signals are different and therefore do not work correctly.
This is a 1.6 EcoBoost engine
zivny.ondrej
1 June 2020mobile
I have workin oil presure little bit, nothing else. So you dont have any solution how to make it work?
damianov_adrian
6 June 2020mobile
Hi, i'm new on this forum and i need your help regarding an update that i have made on my ford focus 2011. I have added bluetooth voice control and is not working in calls, on media streaming it is sound perfect, mic is working(the person that i talk with can hear me very well)
I have tried with 2 phones and it is the same. Also the buttons from the steering wheel works exept the voice button. That only stop the music that is streamed. The schematic that i followed it is in the pictures bellow.
Can you help me and tell me what is wrong?
Thank you.
ZaQik
6 June 2020
did you change central configuration in BCM?
damianov_adrian
7 June 2020mobile
I have managed to fix it, it was a setting in touchscreen option that i changed and now it is working.
And yes i have enabled the bluetooth options in BCM
Thank you.
masterT
11 June 2020
Hi, I have a problem with the APMI module. I added it to the Focus mk3 2011 car and the recognition of traffic signs does not work well. The error is that while the function is switched on, after the ignition is switched off and the car is locked (after approx. 30 min.) recognition traffic signs is switched off. But in the right case, the function should always be turned on. Does anyone know anything about this?
masterT
14 June 2020
Sorry i mean IPMA module... Does anyone know anything about this?
zivny.ondrej
30 June 2020
Hi, did any one try to install IPMA from facelift to pre facelift? Will it work correctly? I will have city-stop from facelift, IPMA from facelift and also clockspring from facelift car where was IPMA installed. Thank you.
zivny.ondrej
7 July 2020
Ok, so IPMA works from facelift in pre-facelift. Just have a question, if you have anyone as-built data configuration sheet for pre-facelift? Because I found everywhere just for Focus 2015- and there are some figures different. Thank you.
rfr78
8 July 2020
I have retrofitted facelift IPMA to my FF3 2013.
But I have IPC/BCM/CLOCKspring Facelift too.
What do you need prefacelift as-built as you will add facelift?
rfr78
8 July 2020
Z
zivny.ondrej:
Have you saw this? - > CANdo HotCar -> CANdo Микроконтроллеры, расширяющие штатный функционал авто
