[EN] Focus Mk3 (2011) quick help
5 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
310,1K
gurtaz
16 April 2019mobile
ZaQik
Thank you
Komper
9 May 2019mobile
Автомобиль 2011 года 1.6 ecoboost 150 л.с. Какова правильная проводка? Как мне установить этот гоночный чип? Спасибо
(Car 2011 1.6 ecoboost 150 hp.What is the correct wiring? How do I install this racechip?thank you
gurtaz
26 May 2019mobile
Hi, i dont have nav voice in addded sync3. I install nav voice package 422. Maps works but navigation havent voice 😞
storage01
15 June 2019
Hi I'm new here, can someone advise on how do I access ford catalog for parts and service such as these information?
galipst.52
18 June 2019mobile
semiho:
Hi friends!
Can somebody help me with thatcham buzzer? Where is it located in a 2015 Focus?
does anyone know where this piece is? The damn piece has been stuck in the car for years.
PRP
18 June 2019
storage01:
For Ford parts you can use "FordEcat" or "Microcat" software. Both are not free, but they are in torrents.
The second picture is from here. Electric circuits are also available in FordEtis, too, is not free.
PRP
18 June 2019
galipst.52:
This is the alarm siren, number 13A803B
galipst.52
18 June 2019mobile
PRP
Я знаю это, но я не мог найти его место на транспортном средстве. Я думаю, что было бы легче, если бы я мог найти реальную фотографию, сделанную через автомобиль лично
storage01
19 June 2019
PRP:
The second picture is from . Electric circuits are also available in FordEtis, too, is not free.
Thanks for the link on electrical diagram! Does anyone here have the torrent or magnet to Microcat or ECat? please pm me if you do not want to share it here..thanks
Muma2620
22 June 2019
Does anyone know if SYNC 3 has TCM with voice warnings? I have activated TMC (and yes i have a ACM with TMC).
It displays road work icons on navigation, but it doesnt say warning traffic ahead etc.
My old Sony mfd5 had TMC and it did have voice warnings so can it be true that SYNC 3 doesnt have?
clepsy
23 June 2019
This is something that I also want to know, however sync 3 does have tcm with proper radio, some say with latest f8 maps is not working...
Muma2620
23 June 2019mobile
clepsy
That could be the case. I currently have F8 installed. I have never tried on F7. I have the menu under Navigation called Traffic. But no voice in mine
Outformer
26 June 2019
Hello there,
My car 2017 ford focus odak
Can you help me activate these features with the forscan program?
Warning when I exceed 120 kilometers
Automatic door locking at a speed of 10 km
notification when I lock the door
alarm with horn
shortening the opening and closing times of the windows
zloster12
26 June 2019
I'll try for a third time to share the following information:
The FF3 1.6 petrol flywheel, drive plate and cover can be installed on Fiesta 2006/1,6 petrol. Which means they should fit also on FF2 1,6 petrol engine. The FF3 1,6 petrol clutch has 228 mm diameter, the FF2 1,6 petrol clutch has 220 mm. So if the price is right it is a little upgrade over the stock one. There is also data about the weights:
fordbg.com/forum/index.php?topic=10421.msg134285#msg134285
There is some filtering and it's not allowed to post the full link.
FLYWHEEL AV61-6375-BB
COVER AV61-7563-DB
DRIVE PLATE AV61-7550-D1B
Dragoonz
25 August 2019mobile
Hello, excuse for my english is bad, i change the cluster for my ford to 2012 to 2017 cluster, but i havent the beeping reverse anymore, can someone help me ? Tha'k you
cavallo76
26 August 2019mobile
How I dismount this?
cosmo
26 August 2019
cavallo76
Check this post: Подсветка салона, бардачка, подлокотника, багажника и тд. (сообщение #11633825) (you need to expand "hidden text" block).
cavallo76
Thank you cosmo
PRP
26 August 2019
Dragoonz:
Are you saying you have a factory installed parking systems? If so, you have two options:
Option One: You need to put a PAM module and a BCM module from a Ford Focus MK3.5
Option two: Try installing IPC software from Focus MK3
This is the version that needs to be installed:
1) BM5T-14C026-BBG (software)
2) BM5T-14C026-ACE (pictures)
3) BM5T-14C026-AFH (EEPROM)
4) CM5T-14C318-AE (signals)
Good luck!
Dragoonz
31 August 2019mobile
PRP:
Good luck!
Hi, thanks for your attention, i tried to install those software but i have a message : unkown ECU HW F1ET-14F094-BB. I cant read the IPC, i have ELM. Thank you
kuhler
20 September 2019
Hello
I have Focus MK3 2014 with PATS standard key not Keyless. My BCM does not work. I think about installing lift BCM.
Will lidar ACS pre lift CM5T-14F449-AC work with lift BCM for example F1FT-14A073-EG ?
ZaQik
22 September 2019
yes, it will work
kuhler
22 September 2019
ZaQik:
yes, it will work
thx
kuhler
27 September 2019
I have a UCDS interface. Will I be able to upload the AS-Built module and update the immo if I replace the BCM module myself? What is the immo coding procedure after replacing a module, e.g. BCM or PCM? How to do it?
Of course I have two original keys.
rfr78
27 September 2019
UCDS will only upload AS-BUILD - there is no immo procedure.
You need to go to magician that has another tool or ford Dealer tools (e.g IDS ) and subscriptions.
kuhler
27 September 2019
Thank you Lukasz.
zivny.ondrej
6 October 2019mobile
Hi there, I did find it anywhere. Did anyone please upgraded from BT module (I dont have Sync1) to Sync2? It would be great, if someone has some scheme how to replace wires from BT module to the Sync2 connector and also from ACM and main connector from old display to the Sync2 (apim) connector. Thank you very much for your help!!
zivny.ondrej
Universe
Hi there, I did find it anywhere. Can you help me with this please? I want to upgraded from BT module With navigation (I dont have Sync1) to Sync2? It would be great, if you have some scheme how to replace wires from BT module to the Sync2 connector and also from ACM and main connector from old display to the Sync2 (apim) connector. In ACM I have only one main connector (I have seen that in Sync1 are two big connectors) I have ready everything for Sync2, I have also all cables and connectors from Sync3. Thank you very much for your help!!
PRP
7 October 2019
Z
zivny.ondrej:
Here are two circuits, one is on your BT module, the other is on sync1 and sync2. Just arrange your pins according to the sync2 table. However, your connector does not fit with the sync2 connector. You will have to replace it, just the distance of the pins are different.
