[EN] Focus Mk3 (2011) quick help
5 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
313,9K
cavallo76
9 December 2018mobile
Universe
If I use sd reader, can work sistem?
Universe
9 December 2018
I don’t think so.
Universe
10 December 2018
cavallo76
pin 7 isn`t used. it should be empty.
BTW I have one hub that works with F4 sd card only. It doesn`t want to work with newer cards. Mistique
cavallo76
10 December 2018
Universe
Same is mine?
On My hub doesn't work usb and sd. If I put normal mini usb - female usb cable and I connect USB pendrive, it work (on black and Grey plug) !
Universe
10 December 2018
cavallo76
defective part
cavallo76
10 December 2018
Universe
On focus mk3.5 which hub there is for sync 2?
Universe
10 December 2018
cavallo76
there was one with 2 usb / 1 sd / aux
but it has different socket
cavallo76
10 December 2018
Universe
Is possible that hub is disable by Direct programming?
This sync is American whit dps. When I reprogram it, I took bit from European sync
Universe
10 December 2018
I`m not sure. I can only state that hub is not a module to be programmed. It is passive. Just a electric part without CAN brains
cavallo76
13 December 2018
Universe
We have some problem with this installation of sync 2.
Any bit we put on APIM with forscan, auto parking, park assist and parking sensors (on sync 2) don't work.
Can you help we on configuration?
Universe
13 December 2018
cavallo76
email me VIN and APIM`s configuration file
cavallo76
15 January 2019mobile
Anyone have link for Etis cracked offline?
Dextervio
22 January 2019mobile
hello I installed sync 3 soon and I got the problem with parking, it does not work and no sound at parking sensors, the body series is this WF06XXGCC6FK23868. thank you.
Dextervio
Dextervio
which parameter needs to be changed to work, thank yo
PRP
23 January 2019
First, change these parameters in Configureren as-built.
#123 - Aux. input = 01 without
#154 - accessory usb input = 01 without
#157 - Bluetooth handsfree = 01 without
#172 - Front display = 09 touchscreen DM-8
#214 - ICP = 09 Non branded mini-ICP
If in this case the parking sensor does not work, you must change the parameters in the sync itself. However, you will need the Russian UCDS cable.
ZaQik
27 January 2019
PRP: his car had SYNC2 - your advice is useless
Dextervio: did you change parameters in SYNC3?
Dextervio
5 February 2019
спасибо за ответ, который я решил с парковкой, теперь у меня есть другая проблема, я купил cdplayer от kuga, cv4t-19c107-nj, и я установил его, чтобы сфокусироваться, но у меня нет звука на датчиках парковки, вы можете помочь мне с конфигурацией cdpayerului.in UCDS выглядит так. спасибо.
cavallo76
24 February 2019mobile
Universe
Do you have electric scheme of kuga mk1?
groauto
27 February 2019
Hi,
I own a FOCUS 3 RS. If I try to read BCM or PCM, I get this message -can't enter security into ECU-
Is there anybody who can help?
changbom
11 March 2019
Hi. I have 2014 ford focus. i updated to sync 3 and it work fine. i have 1 question hope you guy can help me. i want to change my IPC to dark-blue themes like this one. How can i do that. Can it be done with forscan or i need to use UCDS. Thank
PRP
11 March 2019mobile
With Forscan or Focccus, change this parameter and you will have a dark theme.
By the way, I recommend changing the rest if you are not.
changbom
12 March 2019
Thank you so much. i have 1 more question. mine is 2014 ford focus. my PAM module dont have as-built and only have auto parallel parking. If i replace my PAM module with 2017 PAM can i use Perpendicular parking.
Thank
PRP
13 March 2019
It will not work. For parallel parking, you need six rear bumper sensors. Probably you will have to change the BCM module as well.
Better not try to do this experiment.
rfr78
15 March 2019
Hi!
Guys - is it possible to install steering whell from FOCUS mk4 in Focsum MK3?
Plug&Play or not ?
cavallo76
16 March 2019mobile
groauto
Focccus is not good for focus 2014 - 18
cavallo76
16 March 2019mobile
Can I mount internal mirror with automatic dimmer on focus 2017?
Anyone have electrical scheme of this mirror? It has 3 pin
PRP
17 March 2019
Here is the diagram of the interior mirror. Ford Focus MK3
gurtaz
13 April 2019
Can somebody help me? ACM GJ5T-18C815-NN have DAB and TMC?
ZaQik
14 April 2019
DAB - yes
