[EN] Focus Mk3 (2011) quick help
4 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
281,5K
cavallo76
4 October 2016
Snegg
My factory light is this
Bm5t-13776-fa (rear), Bm5t-13776-ec (front)
These are new light
AM51-13K767-BD (rear), Am51-13k767-ad (front)
I used this scheme page 42
But color of wires are not same into my car.
These are my factory wires
With multimeter on factory wires i have + 12v on pin 1 only if i have a door open but if i put this pin on new light this don't work. I must to plug this wire on pin 3 of new light. New ligth work only if open door. Don't work while i drive, they are dead.
If i push all switch nothing happens. When i have door open all switch work.
pd3jcw
5 October 2016
Just upgraded to a Sync2 system in my 2013 ford focus, but now the original camera setup is not working...
Module BM5T-19H423-CB and camera BM5T-19G490-LB is installed but will this setup work with sync2 or do i need to change anything...?
Universe
5 October 2016
pd3jcw
Need to change module to AD version
pd3jcw
5 October 2016
Super !!!
So a BM5T-19H423-AD will work with the camera (BM5T-19G490-LB) and Sync2 system.
Universe
5 October 2016
pd3jcw
Yes
BM5T-19H423-AE also fits
Snegg
5 October 2016
cavallo76
I am not so strong in electrical system.
But i suppose you need to seek the cause in lack of constant power supply.
cavallo76
6 October 2016
Snegg
Any user has done this work on forum?
Google translate don't help me...
pd3jcw
6 October 2016
On the new front light;
pin 1 = constant power from interior light relay and F60 on BCM
pin 2 = link to rear light pin 4
pin 3 = illumination switch (BCM connector C4 pin 20)
pin 4 = interior light dimmer signal (BCM connector C4 pin 11)
pin 5 = GND
pin 6 = link to rear light pin 6
The new rear light;
pin 2 = not connected
pin 4 = to pin 2 front light
pin 5 = GND
pin 6 = to pin 6 front light
Maybe you have to check what the functions are of your current wiring !
Snegg
6 October 2016
cavallo76
I'll try to find some information for you.
duorw
6 October 2016
can you give me your WeChat? Let's discuss together.
or you can add mine, 微信号 13504246886.
W
wowfans:
Universe
Thank you for your prompt reply.
I have already replaced the airbag cover, with multimedia buttons, and cruise / lim buttons.
In order to save money, I refit the right button (OK with arrows circuit board, M with mutimedia control shell ), replaced the SMD RESISTOR on the circuit board with the same value that on the cruise/lim controller , so now the left the button(ok with arrows)is used to control the trip computer settings or switch the displaying information , the right button (the appearance is M with next/previous/vol+/vol- , the circuit board has been changed ) is used to control cruising / lim speed driving, and so I need't to cut the steering wheel to install the cruise/lim controller.
About the odometer , I've bought a new basic odometer which has been installed the firmware F1ET-14C026-AAE, it's a 2012 focus English firmware, everything works ok, the firmware can support the cruise control, speed limiter, and view the mileage information, consumption information, tire pressure detection function...
Now I want to upgrade the firmware to a 2015 focus English firmware, model is F1ET-14C026-AAJ , I'v downloaded it from the site that you provided me , and I also download the other 3 maching documents: F1ET-14C318-AC, F1ET-14C026-AEG, CM5T-14C318-AD.
I'm a novice, only get a elm327 cable (ms-can enabled) , so I want to konw how to install the new firmware ( the 4 files above), and these 4 files form a complete firmware? No more files needed ? If the firm is competed , can I use the focccus 0.8.6 , switch to the "tools" table, use the "upload vbf" function to install the new firmware? or I must by a new els27 cable to replace my elm327 cable ?
My car current status:
pd3jcw
7 October 2016
installed the BM5T-19H423-AD module today but camera is still not working... throughs up DTC B115E:08-0B on IPMB
Universe
7 October 2016
pd3jcw
Does APIM has correct configuration?
pd3jcw
7 October 2016
Yep, FOE camera in APIM
pd3jcw
7 October 2016
i've read the "myford touch" topic and what i found is that the BM5T-19H423-AD module requires a BM5T-19G490-CB camera. What i have mounted originaly is a -LB camera...!?
Could this be the problem ?
Universe
7 October 2016
pd3jcw
The part number of camera doesn`t matter. Of couse CAMERA has LIN that may not me accepted by the module but the motion picture should be shown anyway.
You need to test all components step by step.
pd3jcw
11 October 2016
Universe
Found the problem... bad grounding on camera unit... the good thing is that the picture shows when selecting reverse !!!
Thanks for your help
Universe
11 October 2016
pd3jcw
you are welcome
ozeraksu
14 October 2016
I installed the camera. rear parking sensors diagrams does not work. As-Built Code as in the picture
This Car Ford Focus MK^3 Sedan 1.6 Ecoboost 182Ps Titanium X
ozeraksu
16 October 2016
Universe
I get the DTC in the picture. DTC seems to be on the display panel E101-00.
How can I fix
galipst.52
22 October 2016
Hello there.
I bought my 2015 ford focus heated seats KLIMA panel.
Some of the connections available.
After c237 numbered socket cable is not available.
what should be done next connection.
Thank you for your interest and do, I'm joyful forums.
tomekd12
7 November 2016
Hi everyone!
I have one question about main display. In my car (Ford C-max 2013) I have monochrome one and I want to change them to multicolor 4.2" display. When I had installed there AM5T-18B955-CH, BT and USB doesn't work. Then I found info that display to Sync with BT and USB (Yes, I have Sync1) should be BM5T or higer, so I bought CJ5T-18B955-GC and it's still not good for my car. This one is from Ford Escape US. Can I change software in this display to adapt it to my car? I use ELM327 v1.3
Thanks for help.
Universe
7 November 2016
tomekd12
Hello
You`d better find BM5T or DM5T version
syrusas
18 November 2016
Hi,
Sorry, that im writing to you in english language, but I can only read and talk in Russian, writing in it isn't my strong side.
So I have tried to flash the IPC to Quad screen using focccus.
Everything went well, all the files
BM5T-14C026-ACC
BM5T-14C026-BBB
BM5T-14C026-KG
Flashed without a hiccup.
But one file, the last one, calibration file failed to flash.
CM5T-14C318-AD
Focccus APP crashed (stoped working message poped op) in the middle of the process and after that, I was not able to recover.
Now, my IPC is dead and I cannot connect to it.
It was flashed off the car, connected to the 12v power source and a ELM327 adapter.
So, do you have any idea, how to recover it, or it is dead and I can throw it away?
I have a backup one from a donor car, so it is not a problem for me, but I would really like a QUAD screen on my 2012 Titanium
My car is imported from USA to EU.
Writing here, well because I think you are quite clever in sorting things like that, and I am not ))
syrusas
19 November 2016
This is the log I get
09:46:27.883 > ATWS
09:46:27.897 > ATE0
09:46:27.913 > ATL0
09:46:27.929 < OK
09:46:27.929 > ATS0
09:46:27.945 < OK
09:46:27.945 > ATAL
09:46:27.961 < OK
09:46:27.961 > ATAT0
09:46:27.977 < OK
09:46:27.977 > ATCAF0
09:46:27.993 < OK
09:46:27.993 > STI
09:46:28.009 < ?
09:46:28.009 > ATST09
09:46:28.025 < OK
09:46:28.025 > ATR1
09:46:28.041 < OK
09:46:28.041 > ATSH7DF
09:46:28.057 < OK
09:46:28.057 > 0210820000000000
09:46:28.169 < NO DATA
09:46:28.169 > 0210820000000000
09:46:28.281 < NO DATA
09:46:28.281 > 0210820000000000
09:46:28.393 < NO DATA
09:46:28.393 > 0210820000000000
09:46:28.505 < NO DATA
09:46:28.505 > 0210820000000000
09:46:28.617 < NO DATA
09:46:28.617 > 0210820000000000
09:46:28.729 < NO DATA
09:46:28.729 > 0210820000000000
09:46:28.841 < NO DATA
09:46:28.841 > 0210820000000000
09:46:28.953 < NO DATA
09:46:28.953 > 0210820000000000
09:46:29.065 < NO DATA
09:46:29.065 > 0210820000000000
09:46:29.177 < NO DATA
09:46:29.177 > 0210820000000000
09:46:29.289 < NO DATA
09:46:29.289 > 0210820000000000
09:46:29.400 < NO DATA
09:46:29.400 > 0210820000000000
09:46:29.512 < NO DATA
09:46:29.512 > 0210820000000000
09:46:29.624 < NO DATA
09:46:29.624 > 0210820000000000
09:46:29.736 < NO DATA
09:46:29.736 > 0210820000000000
09:46:29.848 < NO DATA
09:46:29.848 > 0210820000000000
09:46:29.960 < NO DATA
09:46:29.960 > 0210820000000000
09:46:30.072 < NO DATA
09:46:30.072 > 0210820000000000
09:46:30.184 < NO DATA
09:46:30.184 > 0210820000000000
09:46:30.296 < NO DATA
09:46:30.296 > 0210820000000000
09:46:30.408 < NO DATA
09:46:30.408 > 0210820000000000
09:46:30.520 < NO DATA
09:46:30.520 > 0210820000000000
09:46:30.632 < NO DATA
09:46:30.632 > 0210820000000000
09:46:30.744 < NO DATA
09:46:30.744 > 0210820000000000
09:46:30.855 < NO DATA
09:46:30.855 > 0210820000000000
09:46:30.968 < NO DATA
09:46:30.968 > 0210820000000000
09:46:31.079 < NO DATA
09:46:31.079 > 0210820000000000
09:46:31.191 < NO DATA
09:46:31.192 > 0210820000000000
09:46:31.303 < NO DATA
09:46:31.303 > 0210820000000000
09:46:31.415 < NO DATA
09:46:31.515 > ATSH720
09:46:31.527 < OK
09:46:31.527 > 0210020000000000
09:46:31.639 < NO DATA
09:46:31.639 > 0210020000000000
09:46:31.751 < NO DATA
And till the end, it is like this, NO DATA and 0210020000000000
syrusas:
Hi,
BM5T-14C026-ACC
BM5T-14C026-BBB
BM5T-14C026-KG
CM5T-14C318-AD
sargius
19 November 2016
Hey guys
After some light , headlight fixing my Ford Focus SE 2l. 260 hp 2014 went mental
I did use FoCCCus with ELM327 USB to do that and wrote changed date to BCM.
After that all lights went off , I coulnd even start the engine, its like i have no battery at all.
Can anyone be any of help plz
dazst250
2 December 2016
wondering if anyone can help with this one, I have a 2015 Focus ST3 Uk and ive fitted the park assist, ive looked at loads of As-built data files and compared what I think are the correct bits and ive got as far as getting the front and back side sensors working and the pictogram on the screen?
What im still having trouble with is the sapp and pas buttons don't seem to do anything. So once the front sensors are activated through the reverse gear i cannot turn them off with the pas button? and the sapp button doesn't activate the self park feature??
ill put the vin here cos the info is available to anyone with etis i suppose
WF05XXGCC5FY89759
pd3jcw
5 December 2016
you can check your as-build data, maybe you can have a look at this site and enter your VIN;
http://ford.xtlt.ru/ab/ and then item #59
dazst250
5 December 2016
Thank you, ive got it working to an extent, the buttons now work but it just comes up with park assist not available on the sync2 but if your driving and press it it says to slow down to find a parking space or if your reversing it says take out of reverse to find a space??
I think it is working but there's just something missing and I think it is just 1 wire that I don't know where it goes, pin 4 on the park assist just says wire CCA47 BU-WH goes to 42-3 vehicle dynamic system?? but I cannot access this or find a diagram of it anywhere on the internet
Ive connected 3 missing wires already from connecter C215 to C237 these are pins c215 37=c237 18, c215 36=c237 19, c215 38=c237 28
FLA
15 December 2016
Hello,
I have C-Max 2011, I have original ford rear parking sensors. I have plan to update SW or exchange cluster panel, because I want 2nd trip computer
A variant:
old cluster instrument + update SW to F1ET-14C026-AAJ, F1ET-14C026-APG/AEG, F1ET-14C318-AC
B variant:
FL cluster instrument + new SW F1ET-14C026-AAJ, F1ET-14C026-APG/AEG, F1ET-14C318-AC
[/B]
F1ET-14C026-AAJ
F1ET-14C026-APG/AEG
F1ET-14C318-AC
My question is if the parking sensors will be running with sound alarm or not. It does not matter if I will use variant A or B?
I have read that old cluster instrument with upgraded SW F1ET-14C026 has problem with sound of parking sensors.
thank you very much
dazst250
21 December 2016
I think Universe and a couple of others had this problem and returned to the original sw to solve it, so I don't know if there is a solution to this or not??
