m_stavros
29 November 2021mobile
sarboys
I changed job, i changed county and i had to sell the car.
It was an amazing project. I had so much fun driving it.
Hello, are there any threads or topics about replacing the stock ST225 inlet camshaft with the one from RS ?
Any help or feedback from users that did it?
Thank you,
Stavros
Dual mass flywheel vs Single mass flywheel
smf before-after
by
stavros mlls
, on Flickr
I wanted to change my clutch set up but my RS clutch was like brand new and i didn't want to waste it, so i decided to change only the flywheel. I received today this masterpiece from TTV Racing. It is a single mass flywheel about 4,5kg less than the standard dual mass.
I will post pictures of instalation soon..
IMG_20170330_105922
by
stavros mlls
, on Flickr
IMG_20170330_105953
by
stavros mlls
, on Flickr
The exhaust studs that Anembo advertised as a heavy duty stud kit, broke in 10 months of use...
I realised that 2 of them were cut as I had a strange noise from exhaust manifold..
I decided to buy stronger ones 14.9 tensile with special heat resistance washers and nuts. It also requires a new exhaust manifold flange again..
Lets hope that will last longer.
2017-03-07_02-08-13
by
stavros mlls
, on Flickr
2017-03-07_02-33-44
by
stavros mlls
, on Flickr
m_stavros
23 February 2017
The new thermostat arrived today. At last excellent after sales services from Polar Parts.
I hope this one is non defective.
IMG_20170223_170530
by
stavros mlls
, on Flickr
IMG_20170223_170513
by
stavros mlls
, on Flickr
m_stavros
21 February 2017
They decide to replace the thermostat and they sent me a new one.
So the problem solved.
I also got this engine mount for 90€ euro. Ford sells it 260€.
IMG_20170221_151059
by
stavros mlls
, on Flickr
IMG_20170221_151210
by
stavros mlls
, on Flickr
IMG_20170221_154357
by
stavros mlls
, on Flickr
IMG_20170221_154450
by
stavros mlls
, on Flickr
m_stavros
15 February 2017
The thermostat loses coolant fluid from the aluminium insert of the upper bolt.. The store i bought it said that there is no warranty as i dont have Volvo...and i installed it on a Ford..
I call that fraud !!! It is 100% a Volvo engine
IMG_20170214_135055
by
stavros mlls
, on Flickr
The RS oil cooler is bigger than the ST225 and helps the oil to run in lower temperatures.
The ford genuine part is from Volvo, the brand is Behr and costs about 350€ .. So i order one from Behr that costs less than half of the price. It is exactly the same.
IMG_20170203_145554
by
stavros mlls
, on Flickr
IMG_20170203_145541
by
stavros mlls
, on Flickr
