[EN] Focus Mk2 (EU, 2005) quick help
20 years ago
10
Ask for any help about Ford Focus Mk2 (2005) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
en_ffclub, fast help
ter
17 March 2004
166K
m_stavros
8 February 2017
RS ECU cover/bracket/holder
IMG_20170207_141129 by stavros mlls, on Flickr
IMG_20170207_141200 by stavros mlls, on Flickr
IMG_20170207_141310 by stavros mlls, on Flickr
IMG_20170207_141355 by stavros mlls, on Flickr
IMG_20170207_141547 by stavros mlls, on Flickr
m_stavros
14 February 2017
Installation process
IMG_20170214_114058 by stavros mlls, on Flickr
IMG_20170214_114105 by stavros mlls, on Flickr
IMG_20170214_114140 by stavros mlls, on Flickr
IMG_20170214_124425 by stavros mlls, on Flickr
IMG_20170214_124452 by stavros mlls, on Flickr
m_stavros
15 February 2017
IMG_20170214_160238 by stavros mlls, on Flickr
IMG_20170214_162314 by stavros mlls, on Flickr
And finally clean!
2017-02-15_04-59-46 by stavros mlls, on Flickr
m_stavros
15 February 2017
The thermostat loses coolant fluid from the aluminium insert of the upper bolt.. The store i bought it said that there is no warranty as i dont have Volvo...and i installed it on a Ford..
I call that fraud !!! It is 100% a Volvo engine
IMG_20170214_135055 by stavros mlls, on Flickr
m_stavros
21 February 2017
They decide to replace the thermostat and they sent me a new one.
So the problem solved.
I also got this engine mount for 90€ euro. Ford sells it 260€.
IMG_20170221_151059 by stavros mlls, on Flickr
IMG_20170221_151210 by stavros mlls, on Flickr
IMG_20170221_154357 by stavros mlls, on Flickr
IMG_20170221_154450 by stavros mlls, on Flickr
m_stavros
23 February 2017
The new thermostat arrived today. At last excellent after sales services from Polar Parts.
I hope this one is non defective.
IMG_20170223_170530 by stavros mlls, on Flickr
IMG_20170223_170513 by stavros mlls, on Flickr
m_stavros
7 March 2017
The exhaust studs that Anembo advertised as a heavy duty stud kit, broke in 10 months of use...
I realised that 2 of them were cut as I had a strange noise from exhaust manifold..
I decided to buy stronger ones 14.9 tensile with special heat resistance washers and nuts. It also requires a new exhaust manifold flange again..
Lets hope that will last longer.
2017-03-07_02-08-13 by stavros mlls, on Flickr
2017-03-07_02-33-44 by stavros mlls, on Flickr
m_stavros
30 March 2017
I wanted to change my clutch set up but my RS clutch was like brand new and i didn't want to waste it, so i decided to change only the flywheel. I received today this masterpiece from TTV Racing. It is a single mass flywheel about 4,5kg less than the standard dual mass.
I will post pictures of instalation soon..
IMG_20170330_105922 by stavros mlls, on Flickr
IMG_20170330_105953 by stavros mlls, on Flickr
m_stavros
30 March 2017
IMG_20170330_171238 by stavros mlls, on Flickr
IMG_20170330_171256 by stavros mlls, on Flickr
m_stavros
6 April 2017
New flywheel bolts
2017-04-06_03-44-31 by stavros mlls, on Flickr
m_stavros
12 April 2017
IMG_20170315_150308~01 by stavros mlls, on Flickr
IMG_20170315_150353~01 by stavros mlls, on Flickr
mutica
22 April 2017
Hello,
Please forgive me, for using the english language on a russian forum, but I have a question that I did not find any information, anywere .. The ford russian community is the biggest in Europe, so I will ask the question:
The FF3 hatch rear shock absorbers and shock absorbers top bush fit on a FF2 sedan? Thank you very much!
DjeR
23 April 2017
mutica
Взаимозаменяемость запасных частей ФФ2 и ФФ3 (сообщение #14289435)
Yes, everything fits perfectly. Here is a topic for help to non-Russian-speaking users Ford Focus 2
m_stavros
25 April 2017
IMG_20170425_142300 by stavros mlls, on Flickr
IMG_20170425_142245 by stavros mlls, on Flickr
m_stavros
26 April 2017
IMG_20170426_135324 by stavros mlls, on Flickr
IMG_20170426_135337 by stavros mlls, on Flickr
IMG_20170426_135343 by stavros mlls, on Flickr
m_stavros
27 April 2017
2017-04-27_02-19-40 by stavros mlls, on Flickr
m_stavros
7 May 2017
2017-05-03_03-12-54 by stavros mlls, on Flickr
m_stavros
7 May 2017
Dual mass flywheel vs Single mass flywheel
smf before-after by stavros mlls, on Flickr
m_stavros
7 May 2017
2000 by stavros mlls, on Flickr
3000 by stavros mlls, on Flickr
4000 by stavros mlls, on Flickr
5000 by stavros mlls, on Flickr
6000 by stavros mlls, on Flickr
m_stavros
10 May 2017
Hello, are there any threads or topics about replacing the stock ST225 inlet camshaft with the one from RS ?
Any help or feedback from users that did it?
Thank you,
Stavros
vincmass
15 May 2017
Good morning, I have a problem with the Radio sony 6000cd.
For a few days I do not recognize the bluetooth module, and when I recognize it in playing songs via usb and cellphone, it rustles on the front chest.
What do you depend on?
mutica
30 September 2017
Hello,
Does the FF3 rear breakes fits on FF2? The brake disc diamenter on FF3 it's 271mm, and on the FF2 it's 268mm... Can I put the 271 mm brake disc and brake pads, with out any modification? The brake calipers are the same on both models, if so, if I change only the caliper mounts, it will fit?
Thank you!
Kodicc
1 October 2017
mutica:
Hello,
Thank you!
you need to change the calipre mounts. Yes, it will fit.
mutica
3 October 2017
Hey guys,
Thank you Kodicc for your answer!
Because I decided to go with the 265mm, FF2 brake disc, and not the 271mm FF3 disc, I have a dilema. I bought rear calipers that came with 280 mm mounts, and I didn't have any luck on finding 265 mm mounts.
The question: I have 15" wheels, if I put a 280mm disc it will fit? In the front the discs are 278mm, so a 2 mm difference, and the wheels fits without any problem...
Thank you for your time!
Dyrman
4 October 2017
mutica
No problem, we already use it.
Тюнинг тормозной системы (сообщение #12559212)
mutica
15 July 2018
Hey guys,
I have a FF22 1.6 petrol engine, and a few days ago I got a P2121-A1 error, witch means a faulty accelerator pedal. A new pedal is pretty expensive. Does the FF3 accelerator pedal fits on the FF2?
Do you know the voltage and resistence of the accelerator pedal and the electrical harness, so I can check the pedal, to be sure that this is the problem?
Thanks for the time and help!
clepsy
16 July 2018
That does not mean it's the pedal, you may check the position sensor from the throttle body from intake, and yes the pedal should fit, maybe some wiring swap
dj.martzian
15 September 2018
Hi guys,
Today I've just installed the Ford Focus 3 throttle on my Ford Focus Mk2.5, 1.6L 74KW.
I've followed the instructions from this topic with an adaptive cable. The installation was fast and smooth but after I've turned on the Inginition the message "Engine Malfunction" is still displayed.
All the parameters have been reset using both ForScan ( Reset All adaptations procedure) and Elmconfig (Reset KAM, reset module).
On the PCM I have the DTC - Throttle IDLE position not learned.
Currently I'm using "7M51AKB_L7_E2_2015" software.
Could some help me? I have a bad throttle or I'm missed something from the instructions.
Thank you.
Веталь76
16 September 2018mobile
dj.martzian:
Hi guys,
Thank you.
Привет, ребята,
Сегодня я только что установил дроссель Ford Focus 3 на мой Ford Focus Mk2.5, 1.6 L 74KW.
Я следовал инструкциям из этого раздела с адаптивным кабелем. Установка прошла быстро и гладко, но после того, как я включил Inginition сообщение "неисправность двигателя" по-прежнему отображается.
Все параметры были сброшены с помощью ForScan ( Reset All adaptations procedure) и Elmconfig (Reset KAM, reset module).
На PCM у меня DTC-дроссель холостого хода не узнал.
В настоящее время я использую программное обеспечение "7M51AKB_L7_E2_2015".
Может ли кто-нибудь помочь мне? У меня плохой дроссель или я пропустил что-то из инструкции.
Спасибо.
bandakias
10 October 2018
Hello, could anyone clarify which firmware is the latest for my 1.6 ti-vct 115hp? My current firmware is
As i understand i should updated to E00DS4XC?
