[EN] Focus Mk3 (2011) quick help
5 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
319,9K
alpdbg
9 February 2022
I flashed it to original software but problem is still here. Now I see that ids calibration level is up-to-date(BM5T-10849-BLK). Before updates it wasnt updated. Can someone send me BM5T-10849-BLD(or BLE, BLF)?
technikibart
30 May 2022
Universe:
FLA
Hi
the chineese camera will work correctly BUT it needs to flash the LCD with one of the modified software. One of them iwas made by Quickie (presented in ADS) and the second by DarkLeo (presented in UCDS).
Hello, I have a "5-inch" FCDIM module AM5T-14D358-DJ - I would like to connect a Chinese camera to the module using a Fakra. Where can I get the modified software?
Universe
30 May 2022
T
technikibart:
AM5T-14D358-DJ
In order to use RVC with 5" LCD it needs to connect non-OEM module. But it seems not to be supplied anymore.
technikibart
31 May 2022
Universe - Is there any other option that will help in this situation?
Is there any function that forces the camera to run, including reverse gear? I will add that I have an R5 manual gearbox.
askn99
27 November 2022mobile
Hello, the 2012 focus 3 vehicle warns on the indicator screen in lamp failures, but it does not warn in case of rear tail lamp failure, what could be the reason?
ZaQik
3 December 2022
only headlamps are indicated
askn99
4 December 2022mobile
Ayn baka Focus 3 de arka lambalar arzas gstergede grnyor Ayrca benim ara 4 derece altndaki scaklkta otomatik n cam ve ayna stclar devreye giriyor arka cam rezistans devreye girmiyor manuel olarak alyor
chleuh2-34
26 December 2022mobile
hello I have a ford c max 2014 2l 140 my vehicle was flooded all the interior computers are out of service except the speedometer and car radio I changed everything with the same references I also changed the bcmii flasher and I put the original configuration with ASBUILT I managed to start everything works well except the keyless start I have to put the key next to the column to start I have changed the batteries still the same key not detected indicates the counter fault code in bcmii u0515 in the rfa module no fault thank you for helping me last thing when the engine is started I get out of the vehicle 1 meter I have a key message not in the vehicle that's all
zappero38
Hello,the car engine is turning on or not ?
chleuh2-34
yes the engine good
yes the engine starts fine
zappero38
Ok,if you have replaced the BCM you must match the keys to it,what adapter and software did you used?
chleuh2-34
autel and forscan
I found a member of this group with exactly the same problem as me his problem dates from the year 2018 I do not know if he is still active here is his message from 2018
firesanek25 Jan 2018
нужна помощь зала, что-то упускаю.
есть c-max 2012 года с родным bcm bv6n-14a073-ft.
согласно еката меняю bcm на gv6t-14a073-ef, прошиваю ключи, инициализирую, заливаю заводской конфиг.
итог - не работает бесключевой запуск, пишет не вижу ключа. машину можно запустить только через аварийный слот.
при этом блоки видят ключи в салоне (есть процедура подсчета ключей в фдрс).
в bcm фиксируется одна ошибка u0515 - недействительные данные полученные от привода дистанционных функций.
еще раз - бесключевые ключи прописываются, дистанционное управление работает, но без вставки ключа в слот зажигание не включается.
больше ошибок нет.
есть идеи? я уже мозг сломал, т.к. у меня фф3, все тоже самое стоит и работает
zappero38
Ok,je comte changer de BCM justement pour mon C-Max mais le problme des cls me freine(systme keyless) si j’ai bien compris c’est le problme viens de la commande des portes.
zappero38
Ok, I intend to change BCM precisely for my C-Max but the problem of the keys slows me down (keyless system) if I understood correctly it is the problem comes from the control of the doors.
chleuh2-34
what is the relationship between door control module and keyless start
zappero38
The RFA module receives the signal permanently transmitted by the key through the 3 antennas when you are inside the car the one situated under central console will detect the key inside and tell the BCM ABS and PCM the right key is inside to turn the engine on if the key is not detected the two modules will not start the car,by putting the key inside the slot only transponder is used ( conventional system) the information is send to only BCM,PCM and ABS directly without passing through the RFA.
chleuh2-34
why would you want to change the bcmii??
zappero38
My BCM is working well but i would like to change my IPC with one from ,Focus mk3,5 and a couple of other features.
chleuh2-34
ah you are talking about RFA module OK I changed it too and I reprogrammed the 2 keys result nothing the same thing u0515
zappero38
U0515 DTC= invalid data received from Remote Actuator Module.
This means the Passive Anti Theft programming is not done or complete.
chleuh2-34
Ok thank you so what is the solution
zappero38
Have you initialized the modules ?
chleuh2-34
Yes
with forscan
zappero38
If the remote key fob doesn’t open close the doors it seems that the PAT’s programming procedure with the Autel device is not done correctly.
chleuh2-34
the remote works well
zappero38
But if the remote works well and the car engine turn on all is ok,for the DTC i could be related to RFA or BCM software not matching,when you delete it dos it come back ?
chleuh2-34
yes it comes back I think communication problem between bcmii I looked at the electrical diagram but there is no cable between the bcmii and rfa
but I do not understand when the engine is started I let it start and I move away from the car put something and a message displayed on the key counter not detected in the vehicle
zappero38
That’s is normal,in my car if get out with the key in my pocket the message pops up in the IPC key out of vehicle chime.
There’s no wiring between modules,they communicate through CAN BUS (High Speed for BCM and Medium Speed for RFA)
chleuh2-34
27 December 2022mobile
I found the link between the rfa and the bcmii hoping for a wiring or connector problem or this damaged cable due to oxidation
zappero38
If the RFA is showing when you scan the car with Forscan than your issue is not related to the wiring.
