[EN] Focus Mk3 (2011) quick help
5 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
333,7K
zivny.ondrej
8 July 2020
rfr78:
Have you saw this? - > CANdo HotCar -> CANdo Микроконтроллеры, расширяющие штатный функционал авто
I already have this in my car. Just installed yesterday 🙂
zivny.ondrej
8 July 2020
rfr78:
I have retrofitted facelift IPMA to my FF3 2013.
But I have IPC/BCM/CLOCKspring Facelift too.
What do you need prefacelift as-built as you will add facelift?
I have auto high beams. It works, but I dont have on my IPC that symbol of the light with A, that shows, that high beams are active. And I dont know how to set it. Tried everything in as-built.
rfr78
8 July 2020
Smbol A - stands for automatic lights. Not for Auto High beams. IPMA is responsible for Auto HIGH BEAMS
Automatic lights are turned on when you switch to A on the light switch (left side near the steering wheel)
"A" symbol will be showed once you will enter tunnel or underground parking and LOW beams are turned on automatically.
zivny.ondrej
8 July 2020mobile
I mean this...
rfr78
8 July 2020
Yes! I mean this too.
This is automatic light system indicator. Not High Beam indicator!
https://www.fordservicecontent.com/Ford_Content/...015.pdf
page 77/78
zivny.ondrej
9 July 2020
Ok, but I have also automatic light system. I have on my light switcher that "A". So why I dont have there that icon on my clusture?
PRP
17 July 2020
I think this symbol only appears in Focus MK3.5, or if you have IPC software from mk3.5. Because in the manual of Focus MK3 it is not written that an indication of the clusture appears.
zivny.ondrej
17 July 2020
My friend have it in pre facelift MK3 and he has prefacelift clusture and dont have facelift SW. I tried to apply his as-built in IPMA and IPC and nothing happend. But he has newer firmware than me, so maybe there is th problem.
zivny.ondrej
20 July 2020mobile
Hi, I want to install for Sync2/3 US fascia and it has 2 connectors. Did you install any one this fascia or do you have wire diagram what to wire to wher from that one connector that is in EU Sync2/3 panel? Thank you.
LaForge
21 July 2020
Z
zivny.ondrej:
I have latest Firmware for prefacelift IPC and I don't have this Icon too.
In Kuga it worked, but not in Focus.
I`ll try to buy a facelift IPC for testing purpose and will see what we can do.
I love this little A Symbol and want it to be displayed.
It is a IPC issue only, no IPMA
rfr78:
page 77/78
This is not correct. The A Symbol shows that the AutoHighBeam System is ready and functional. It`s NOT the automated Lights symbol.
This can be read onto page 78 of your linked manual.
Does somehow know how it can be done?
Regards
Karsten
tonyarms
23 September 2020
Hello, i need help from anyone who own latest UCDS version.
I need below files as i could not find in motorcraft website, but it can be downloaded through UCDS using menu : Additional function>Calibration download.
AG9N-14C175-BA
BV6T-14C172-BF
BV6T-14C173-BC
BV6T-14C411-BA
CV6T-14C217-AR
CV6T-14C218-AX
AV6N-14C107-AB
AV6N-14C104-AN
AV6N-14C105-AK
AV6N-14C430-AE
BM5T-18D619-BE
BM5T-18D620-BE
AV6T-14D370-AB
AV6T-14D368-AF
AV6T-14D369-AD
AV6N-14367-AA
AV6T-14D370-BB
AV6T-14D368-BF
AV6T-14D369-BD
AV6N-14D367-BA
C1BT-14C026-AU
C1BT-14C088-AU
AM5T-14D544-LF
AM5T-14D544-HE
Appreciate if anyone can help me on this matter.
Thank you
aissa_chenouf
25 September 2020mobile
Hello
I need this file
DE8T-14F055-BC
Or
This DE8T-14F055-BB
storage01
1 October 2020
Is there anyway to program the car to automatically close all windows when I lock the car? (in case I forgot to fully close any of the windows)
I have global open/close activated and can do it manually if I hold my remote buttons, can this be done automatically when locking by remote or keyfree?
pardon14
9 February 2021
Hello! I would like to know what are the latest calibrations for my IPC.
F1ET-10849-BMH
HW: F1ET-14F094-BB
SW: F1ET-14C026-ABH
Thanks for help!!!
Cheers 🙂
Dextervio
24 February 2021mobile
Hi guys, I also have a problem with focus mk4 2020, I installed the oem masarier camera, but the dynamic lines don't work, the camera is installed in Apim not radio ctr, any ideas? when activating the camera in bcm the error B115E remains.
With the camera activated in bcm I can't initialize Lin the procedure stops.
alpdbg
11 November 2021
Hello,
I was reading this thread about enabling lane centering but I didnt find anyone to successfuly enabled it. I enabled LCA in IPMA and in IPC. Green lines are appearing on display after 80km/h and its keeping me in line but its NOT centering me alone. Im with PSCM CV6T-xxxx-xxxx and I guess:
1. I miss any settings about PSCM. I checked options in PSCM-LA is enabled. In FD13 only ANC is not enabled. What should be ANC meaning?
2. I miss calibration. Is there someone with facelift focus with automatic transmission(LCA is enabled from factory) to check only calibration files?
Thanks!
storage01
17 November 2021
alpdbg:
Hello,
Thanks!
It's been tried many times by various members, generally you'll need a BV6T PSCM, and BM5T BCM. If you have access to UCDS then you can flash the CV6 pscm to BV6 with EEPROM dump shared by other members publicly
ANC = Active Nibble Control (I believe no need to mess with this for LCA)
alpdbg
17 November 2021
storage01:
Can you send me link to this thread or to comment that contains this info? Is it same thread that I send?
storage01
17 November 2021
yeah same thread, start reading around here Система Active City Stop и система удержания в полосе движения (сообщение #19346259)
EEPROM dump is here Система Active City Stop и система удержания в полосе движения (сообщение #19358363)
alpdbg
8 December 2021
DId someone tried to enable some of these:
Cross Trafic Alert(CTA) im looking for but im not sure if it needs something more.
ZaQik
8 December 2021
CTA works only in facelift
you must CTA enable in both BLIS
alpdbg
9 December 2021mobile
I have BLIS
ZaQik
11 December 2021
and facelift? then you can enable CTA in both BLIS module
Blue66
22 December 2021mobile
What that sound?
zappero38
25 December 2021mobile
Mk3 modules are not compatible with cross traffic alert you have to swap them (including brackets and connectors) eventually driver and passenger doors modules and BCM to mk3.5 lift.
morris
4 February 2022
Hi guys does
anyone knows If i can install a reverse camera in this type of display with a fakra cable?
ZaQik
6 February 2022
yes, you can - it works
alpdbg
6 February 2022
Hello,
I upgraded sync 1 to sync 3.4 on my focus mk3 and on IPC screen logos were completly white. So I changed .vbf files and everything is okay except TSR-its acting strange. Before update it was reading all signs. After update sometimes(30%) its not reading them or its showing them a lot later(100-200m later). Also before update it was showing me speed limit on right side only. Sometimes now its showing it on left side also or on both sides(different limits). I read something about settings for fusion or europe but I cant find them again. I tried with older software but its same. Do you have any ideas?
alpdbg
7 February 2022
Is it possbile if I loaded wrong SBL file in VBF loader to be the reason? Can someone tell me what SBL file should I use ford IPC Part number- BM5T-10849-BLD
ZaQik
9 February 2022
SBL: BM5T-14C025-BE
F188: BM5T-14C026-BBG
F108: CM5T-14C318-AE
F120: BM5T-14C026-ACE
F121: BM5T-14C026-AFH
