Ask for any help about Ford Focus Mk3 (2011) in English.This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there
ter
28 May 2005
[EN] Focus Mk3 (2011) quick help
zivny.ondrej
14 October 2019mobile
PRPOk, navigation is functin now. But still sayin, that emergency system is not availevle... do you have any idea?
PRP
14 October 2019
Yes, I know what the problem is. You need to activate the Emergency Assistant in the RCM module, but you need the UCDS Russian cable. Only with him I know how to activate. The other variant is to encode the values of the RCM module with Forscan from another car. I can give you mine, but the risk is great because this module activates the airbags.
zivny.ondrej
14 October 2019
PRPOk, I think that I dont want to activate my airbags
kuhler
Maybe 1, 2 and 3, but I'm not 100% sure. You need to test. Try it if it doesn't work and you don't need it, I agree to buy it (if the price is good).
zivny.ondrej
I guessed so. There may be a way to de-activate because Russia does not have this assistant, but no one has shared how it is done.
zivny.ondrej
PRP
Ok, I will try to sort it out somehow.
Can I also ask you, what is in BCM setting row 214-ICP? What does it mean? Because via diag it didnt offer me 09. It ended with 08. Thank you.
zivny.ondrej
08 is a Sync2 button panel. For focus MK3 ( #214 - ICP = 08 branded IPC/ Mini EFP) Sony panel.
09 is a Sync2 button panel. For Focus MK3.5 like yours (#214 - ICP = 09 Non branded mini-ICP).
zivny.ondrej
PRP
Ok, and when I don’t see there 09 via diag?
PRP
14 October 2019
What software do you use? The easiest FoCCCus allows you to manually set a value when missing from the list. Forscan can too.
zivny.ondrej
PRP
Ok. I use Focccus. So shall I pu there the choice with 08 and than manually rewrite on 9?
zivny.ondrej
PRP
Ok, thank you. And if I have MK3 and not MK3.5 I can set also 09?
zivny.ondrej
You have a focus mk3, but your panel is from a focus mk3.5. For this, parameter 214 must be set to 09.
Do I need to replace the SASM module for options 1, 2, 3 to work?
zivny.ondrej
16 October 2019mobile
PRPOk, everythinknis now working. But still dont have the small car when I am parking on thy sync2 display. Do you have pre facelift car? Could you send us configuration of apim in USCD? And do you have there automatic parking? You can send on email: zivny.ondrej@gmail.com It is last think I need to set
Thank you very much!
But with automatic parking it shows. So it just does not show the car with normal parking.
PRP
17 October 2019
zivny.ondrejAbout this cart up top right?
or this?
zivny.ondrej
17 October 2019mobile
PRP
You can both, because I will install rear camera next week. Thank you.
leonada2008
23 October 2019
My speed dashboard and central control were bought from the United States. Now I want to update the firmware, but I can't get it. How can I handle it? Thank you very much, and if the speed dashboard can provide me Chinese firmware is the best, thank you again!
leonada2008:
My speed dashboard and central control were bought from the United States. Now I want to update the firmware, but I can't get it. How can I handle it? Thank you very much, and if the speed dashboard can provide me Chinese firmware is the best, thank you again! |
Watch this video, it shows you with UCDS how you can manually make an update. But the software they put on the video is for Europe. I can't help you with China software.
Focus MK3 (2011-2015) IPC Software Update
leonada2008
25 October 2019
PRP:
Watch this video, it shows you with UCDS how you can manually make an update. But the software they put on the video is for Europe. I can't help you with China software. Focus MK3 (2011-2015) IPC Software Update |
Thank you very much, can you give me a list of acm software?
PRP
26 October 2019
Sorry, I don't have software for this part number. But I'll try to find one.
galipst.52
26 October 2019mobile
JV6T-14C097-AA.VBF
I need this vbf file.
https://www.fordtechservice.dealerconnection.com...uct=IDS
file downloaded from the site is corrupt or corrupted
I get a file corrupt error when I command Extract zip file
galipst.52Try this one. It is extracted without issue. If you still have a problem then the problem is with your software.
JV6T-14C097-AA
cavallo76
13 November 2019mobile
Universe
Has anyone installed oem xenon lights, from halogen, on focus mk3.5?
zivny.ondrej
13 January 2020mobile
Hi, I am sorry, it is Mondeo MK5 problem, but I have also Focus MK3 and someone could know here. I did in Mondeo
MK5 retrofit from Sync2 to Sync3. Now I have problem, when I drive in to the tunel, map stops moving. And starts again when I drive out. I see in testing menu on sync3, that there is speed of the vehicle zero. In Focus I have actual speed there. So there would be propably the problem, because when there is not gps in tunel, it should take data from speed and steering. Do you know anyone, where and what to set? Thank you.
In Sync 2, there is a section (
Vehicle Speed Network) in the UCDS that tells which bus to get the speed from the car. Try in Sync 3 if there is section and change the bus to another one. I do not know about Mondeo which one is used.
