[EN] Focus Mk3 (2011) quick help
5 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
334,2K
Universe
23 June 2017
pd3jcw
D-K
Confirmed
Please do not forget to change #172 parameter in Asbuilt from 08 (Touchscreen DM8 w/o navigation) to 09 - (Touchscreen DM8 with navigation) and to make an IPC ECU reset procedure.
pd3jcw
24 June 2017
Great! thanks for the help!
cavallo76
25 June 2017
Have anyone pinout of finis 1.780.243 (AV1T-14C575-DAC)?
strattec
25 June 2017
C
cavallo76:
cavallo76
25 June 2017
strattec
I must rebuilt wires of AV1T-14C575-DAC
Can you tell me all pin of These wires?
strattec
25 June 2017
C
cavallo76:
strattec
pin don't know
tracer
26 June 2017
arcomp
I have exact same problem. I think it metter of PCM calibration.
cavallo76
17 July 2017
Anyone know finis or part number of these 3 Plastic covers (i need to know black plastic ST version)?
Universe
17 July 2017
cavallo76
Moulding, LHD, dual climate, ST - 1835376
cover, control selector lever, black, ST - 1733660
panel, console, LHD, ST - 1837021
cavallo76
24 July 2017
Thanks Universe
Universe:
How i unmounting this?
egotrip
9 August 2017
hi guys i need help restoring the original firmware on bcm and ipc i have the 2 original firmwares but i need the original secondary bootloader and other files for the bcm and on the ipc there were 5 files in total when i updated it i will need the otherfiles for that too so where do i get these from?
egotrip
10 August 2017
E
egotrip:
BCM Is now all done but for the ipc i still need 3 files
G1ET-14C026-ABD VEHICLE MANUFACTURER ECU SOFTWARE
G1ET-14C026-ACC ECU SOFTWARE PART 2
G1ET-14C026-BSC ECU SOFTWARE PART 3
anyone got access to oasis can see if the files are available?
kuhler
10 August 2017
Hello all.
I have Focus MK3 2014 prelift. I changed FCDIM display from low level two rows to 4,2' coulor F1BT-18B955-SA (from Fiesta MK7).
Last week i instalka new IPC with big screen from Focus mk3 lift (with "dark theme"). Now graphic and colours on displays are different. Is possible to flash FCDIM F1BT-18B955-SA with graphics and colours similar like IPC "dark theme"? If is possible please tell me which set of calibration files use "dark theme".
to:
Universe
10 August 2017
kuhler
NEw FCDIMs have different HW. So it is impossible.
kuhler
10 August 2017
Thank You.
Display part number F1BT-18B955-SA is a old one?. Which Ford colour 4,2' FCDIM displays have "dark theme" - please give me part number.
Universe
10 August 2017
kuhler
EU version (for SYNC 1 only)
F1FT 18B955 G* (C or D instead of * and so on)
egotrip
10 August 2017
E
egotrip:
resolved
kuhler
14 August 2017
Universe:
kuhler
Universe,
I bought recommended 4,2' FCDIM F1FT-18B955-GD. After mounting in Focus mk3, when I insert the plug , on screen appears only Ford logo, next date & time. The radio is dead, it does not respond to pressing panel buttons. I can't turn it on. When I insert the CD, "CD reading" appears in the display but player does not play. Is it software incompatibility or different display wiring after the lifting? Is it possible to run this display in mk3 ?
Regards.
Universe
15 August 2017
kuhler:
F1FT-18B955-GD
This is known fact that ICP-FCDIM LIN was changed in Facelift. Prefacelift ICPs are not compartible with facelift FCDIMs. I thought you got it.
Sorry man))
cavallo76
15 August 2017
Universe
So is impossible to mount f1ft Display on MK3 prelift?
kuhler
15 August 2017
Universe:
Sorry man))
O.k. but I have a ICP F1ET-10849-BJG (dark theme - working perfectly) facelift, realy we can't do anything?
Universe
15 August 2017
kuhler
I
Please do not confuse IPC with ICP.
cavallo76
It is possible if only to change ICP to facelift at the same time.
kuhler
15 August 2017
Universe:
kuhler
cavallo76
Sometimes knowledge is expensive . Is there a way to install 4,2' FCDIM with "dark theme' in SONY radio system mk3?
Universe
15 August 2017
kuhler
I had done it once in a client`s car:
kuhler
15 August 2017
Universe
I am looking for a solution to this audio system
Universe
15 August 2017
kuhler
I see no way to complement old LIN with new one.
May be someone will do it sometime... I don`t know
kuhler
15 August 2017
Universe
O.k.
Thank you for your time.
Regards
Jacek
cavallo76
15 August 2017
Universe
Universe:
kuhler
I
If I change fcdim and ICP does system will work?
Universe
15 August 2017
cavallo76
If you change both FCDIM and audio control panel to facelift version then they will work.
arunparthan
16 August 2017
Hi,
I am from Dubai, Ford focus 2013 S Germany.
I would like to swap my instrument cluster and enable cruise control.
My current cluster
New Cluster
Is it compatible...Please help
