[EN] Focus Mk3 (2011) quick help
4 years
Ask for any help about Ford Focus Mk3 (2011) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Also check our most popular topic for international visitors: Ford Sync 3 - multimedia and navigation (RU) - it's in Russian but you may use Google Translate to post, it's ok there 🙂
en_ffclub, fast help
ter
28 May 2005
283,2K
Universe
5 August 2015
tracer
Yes if you will return your stock IC then sounds will be back too
tracer
5 August 2015
Universe
One more question,
To pre-lift Instrument Cluster from ST, I want to flash Dark-Blue theme, like in USA oraz LIFT Clusters.
Do You have a SW version which I could flash my instrument clusters to get Dark-Blue in my old ST Clusters and Speedo Meter ?
Universe
5 August 2015
tracer
Dark-blue theme appears in case you have MyFord Touch. Therefor it needs to change an Asbuilt but in this case OEM Bluetooth (Novery or SYNC Gen1) starts mulfunction.
If you even flash you PFL IC with facelift software you will loose park sounds.
tracer
5 August 2015
Universe
I do not have MyFord Touch - I have normal Sony Sync 1 - it means I need to change what to get Dark-Blue theme ?
Thanks !
Universe
5 August 2015
tracer
It means - don`t brake the thing that works.
tracer
9 August 2015
Universe
How about flash new clusters ( 2015 ST lift ) with old 2014 Software ? Did You try that ?
Does sound appear ?
Thanks in advance !
Universe
10 August 2015
tracer
Yes I did.
But I failed to do it.
tracer
10 August 2015
Universe
And Software 2015 to instrument cluster from 2014 - flashing try ?
I mean if it is easy to get speedometer on it ? (guess no sound on park tronick )
Universe
10 August 2015
tracer
this time I do not understand you. What do you mean?
tracer
10 August 2015
I mean, can I flash 2015 Software to Instrument Clusters from 2014 ?
Universe
10 August 2015
tracer
Facelift software can be flashed to Prefacelift.
I confirm this.
tracer
17 August 2015
Universe
Which cable and application can I use to flash Instrument Clusters and from where I can have software for clusters ?
Universe
17 August 2015
tracer
ADS or UCDSys or even FOCCCUS
Prefacelift software is available at motorcraft
Facelift is not available
tracer
17 August 2015
Universe
Thanks
ittrium
18 August 2015
T
tracer:
1. Elm327 or Els27 + FoCCCus
2. UCDS + UCDS
2. ADS + ADS
Elm327 is the cheapest one, but it may have really bad quality. Els27 is more expensive, but more stable and faster.
UCDS and ADS are more expensive, but has more features.
All of them can reflash clusters.
tracer
18 August 2015
ittrium
Universe
Thanks for all kind of help.
I have LAST question
Can I flash OLD software Pre-Lift to NEW Instrument Clusters from 2015 ? ( To get working Park Assist Sound + Park Assist. )
tracer
8 September 2015
Universe
Hello,
FoCCuS program can not flash old SW to new IPC Can not detect FJXXX software...
Any idea ?
Zray
24 September 2015
My car is Ff mk3 with 4.2 inch display. Can I replace it by New Sync 2 touch screen, or any good aftermarket headunit ( doesnt misss any function). Thanks
duorw
29 September 2015
ittrium:
duorw
Seems that now it is not ELM327 related problem.
The problem is that your IPC doesn't accept the secondary bootloader to the address it is uploading.
Maybe your IPC is different and is not supported by FoCCCus yet.
I will check the right bootloader according to your log a bit later and will let you know.
Hi Ittrium,
Any luck for the bootloader?
cavallo76
2 October 2015
Hello people. I need to know how to disassemble this
I must to mount bluetooth module.
There are any screws on left of panel but i don't see them
Kudesnikkk
2 October 2015
cavallo76
You have to unscrew the 3 screws.
cavallo76
3 October 2015
Kudesnikkk
Very tank you, but I have other questions.
1. I must to remove panel near the legs?
I want to upgrade my radio with navi ford or Sony, but I don't found complete system. I'll to buy single parts.
2. can i Mount, for example, control panel sony with radio mechanism ford yes or not?
3. are they all interchangeable?
4. Anyone has all part number of all navi display? I have found this p/n bm5t-18b955-dc
5. It is good?
tracer
11 October 2015
Hello all,
I would like to ask You if anybody here tried to add:
I have that on my front window:
Anybody play with that ?
MrMadMarx
20 October 2015
Hello, I have tried to add the ESP sport function to my Titanium 2014 Focus. I was able to get the logo to change to ST and I changed the 236 entry to ST with Focccus. The entries in the IPC are not the normal ones for DE04 which is FFBF0000 and DE22 with FFFFF707. I tried the settings for the ESP which are DE04 FFFF0000 and DE22 FFFFF787. I have included the software versions and the Configs and a picture. Any Help would be greatly appreciated.
IPC
BM5T-14C226-BE
BM5T-14C026-BBB
BM5T-14C026-AKC
CM5T-10849-CTG
DE04:FFBF0100
DE22:FBFFFF47
DE15:FFFFFFFF
DE10:F7FFFF9F
DE13:FFFEFFFF
tracer
2 November 2015
tracer
Anyone ?
tracer
14 November 2015
Bump
Any ETIS picture what is need for
Camera for SIGNS reocgnation
kalashnikoffer
26 January 2016
Universe
Do you know, if it is possible to enable the digital odometer (km/h) of an ST IPC 2014 ?
Maybe if i upload the 2015/2016 ST IPC to my old 2014 IPC?
Universe
26 January 2016
kalashnikoffer
Yes it will help but you will loose the PARK Pilot sound functionality so as IP dimmering
kalashnikoffer
26 January 2016
Universe
Okay, thanks.
Well, is it difficult to change my Sony Radio to SYNC 2 / MyFordTouch?
I'm coming from Germany. I've only seen some Russian guys which have realized it
Universe
26 January 2016
kalashnikoffer
Show what type of Front panel do you have.
