[EN] Kuga Mk2 (2012) quick help
20 years ago
Ask for any help about Ford Kuga Mk2 (2013) in English.
This topic is mainly for people who can't speak Russian - you can ask for any help and we will try to help you.
Ford, Kuga Mk2, New Kuga 2013, Escape 2012
ter
20 March 2004
90,2K
zbugz
3 February 2018
su-ch-kuga:
Hello Friends
thank you for become one of your members.
Until last year I drove a Kuga MK 1 with many modifications:
now I have a MK2 and would also apply some mods.
I bought a UCDS adapter with full license.
I was amazed what can be done with this tool.
Can you help me with getting the climate control in the Sync3 Scree?
I have seen that the US Escapoe have that but why don't we?
If you could please help.
Thank you.
https://wiki.ucdsys.ru/doku.php?id=dc_sync3:start
zbugz
3 February 2018
zbugz:
In APIM SYNC 3:
3: Config Block DE00 - DE00
Climate Control Type - Automatic
3: Config Block DE03 - DE03
Climate - Enable Climate Control Repeater for Dual Climate Control
su-ch-kuga
3 February 2018
Thank you friends,
when that is all
dont I have to restart the AIIPM module?
I heard that would be necessary.
zbugz
4 February 2018
su-ch-kuga:
Thank you friends,
when that is all
You can reboot, I don't remember
su-ch-kuga
4 February 2018
Activating Autolock.
I heard about 2 versions on how to activate autolock
one is via AS-build
As Built Editor, Read vom BCM, Save to File, change line 32 to Locking by Speed, write to BCM, write to Backup IPC
the other much shorter an easier
IPC 4, then on the right side line 14 activate and done
Which one is correct?
and did I miss a step ?
su-ch-kuga
4 February 2018
on the Mondeo my nighbor has it is possible to activate an acoustic signal when locking the door.
Is this feature also available for the Kuga MK2?
su-ch-kuga
4 February 2018
in my kuga I can chose whether or not the system should war me when I exceed the speed limit.
This happens as a flshing speed limit sign.
the Mondeo on the other side also has the option for an acoustic warning.
is this available for the Kuga 2017-?
zbugz
4 February 2018
This
FLA
22 November 2019
Hello,
I'd like to change / setup time when the puddle light are switch ON after closing door
Current status:
1. I unlock the car - puddle light are ON
2. I open door puddle lights are ON
3. I close door puddle light switch OFF imediately -> it is possible to set up cca 5 or 10 seconds that puddle lights will be ON
Cargo Light switch ON after car unlocking.
I want to have the cargo light ON only when the trunk door is opened
Thank you!
zbugz
22 November 2019
FLA
Need change in asbulild where cargo light. Ect.. Center, door, all dooor and more
Tomdan
4 December 2019
Hello
I have such a problem in Ford Kuga 2.0 gtdi year 2014
Starter - ok
relay - ok
switching on the relay from the ECU ok (starter turns)
the clutch pedal works for max 75% (I don't know if it shouldn't be 100%)
The ECU sees the START signal from BCMi but does not turn on the relay
What else does turning on the starter depend on?
when you connect the relay it will light up and work for ok
What bites him?
It shows me the temperature in 104 Ccius car (maybe because of it)
tired_pilot
4 December 2019mobile
Tomdan
Has the car any extra security systems?
Tomdan
4 December 2019
there are no alarm systems
tired_pilot
Tomdan
In this way I think where are some problems with key.
Tomdan
5 December 2019
I have added the key again and it is the same
and in parmetrach clutch what value it has
I have 75%
FLA
12 February 2020
Hello, would you please let me know what is the PN and where is the location of cam shaft sensor on Kuga 2.0 tdci 2014? Picture will be best one 🙂 thanky you very much
PRP
29 February 2020
FLA
I can only help you with that.
FINIS: 1837835
Eng. PN: 9M5Q-12K073-AB
FLA
2 March 2020
Balsoje spasiba! Just to be sure here is my VIN WF0AXXWPMAES87702
pro18s
7 June 2020
Hello
Starter - ok
relay - ok
What bites him?
перевод
Привет
У меня такая проблема в Ford Kuga 2.0 gtdi 2014 года
Стартер - хорошо
реле - хорошо
включение реле от ЭБУ в норме (стартер поворачивает)
педаль сцепления работает максимум на 75% (не знаю, не должно ли она быть на 100%)
ECU видит сигнал START от BCMi, но не включает реле
От чего еще зависит включение стартера?
при подключении реле оно загорается и работает нормально
Что его кусает? Это ошибка ?
Показывает температуру в машине 104 Ccius (возможно из-за этого)
domekrap
8 December 2021
su-ch-kuga Are you asking about the icon to control the A/C from the sync 3 touchpad?
4 people online
4 people online
