AuRoN89: |
they work. I just checked. |
AuRoN89: |
— New Sync 3 OS Released — Package Name: NU5T-14G381-AC Epoch: 1682460957000 Major Version: 3.4 Build: 23088 Build Date: 2023-03-29 Package Date: 2023-04-25 Release Date: 2023-05-08 List of Changed files: https://pastebin.com/wXrj15Yr Changes (based on diff): * Updated some ifs, some bins and some libs |
J jgOrlando: |
En: Скрытый текст Hello from sunny Orlando Florida, I'm a Ford enthusiast and just upgraded my 14 explorer sport from sync 2 to sync 3. Installed a Czech made 2019 apim running 3.3 19052. Everything was working well, I then ran the reformat and upgrade to 3.4 20021 and found several issues. The first issue was GPS was receiving no signal, in diagnostic screen zero satellites register and it just sits blank. If I change apim country code to UK or many other non North America country code, GPS instantly starts receiving signal. US MX CA all of the normal north America countries kill the GPS signal. The 2nd issue is also tied to the country code, I assume because Sirius is only a North American company, using the country codes that allow GPS to work stop any of the data services in Sirius, so no icons or channel guide data, no rewind button. If I change back to the US country code, Sirius icons and channel guide appears. What change did the format or 3.4 upgrade change that caused this? 3.3 didn't have this issue and I don't believe going back to 3.3 fixes it. Is there any other forscan apim or other module setting I can change so that GPS will work when country code is set to US? Did the reformat wipe the satellite list? x |
cusco: |
ratushnyi.nv Прошивка для 8 и 10 дюймов одна и та же. Размер экрана выставляется конфигом: <DID ID="DE02"> xxxxx7xxxx - 10 дюймов горизонтальный <DID ID="DE02"> xxxxx8xxxx - 10 дюймов вертикальный <DID ID="DE02"> xxxxx6xxxx - 8 дюймов горизонтальный |
K korand: |
Никто не пытался ковырять прошивку на предмет замены графики, чтобы сделать свою тему оформления? Уж больно темы какие-то убогие, особенно синяя в 3.4. Хотелось бы ее модифицировать. |
APIM: 7D0-01-02 8XXX XXXX XXXX 7D0-03-01 XXXX X2XX XXXX Экран загрузки 7D0-02-01 xxxx **xx xxxx ** = 03 - Lincoln Black ** = 04 - Presidential ** = 05 - Raptor ** = 06 - Mustang ** = 08 - Vignale ** = 09 - GT 350 ** = 0B - ST performance ** = 0C - RS Performance ** = 0E - Continental ** = 0F - Navigator ** = 10 - Ford Performance ** = 11 - Aviator ** = 12 - Explorer ** = 13 - Corsair ** = 14 - Nautilus ** = 17 - Bronco |
Romvad: |
После установки 3.4 реформатом синк перестал выполнять голосовые команды. Файлы загружены все. Выглядит так: - после нажатия на кнопку появляется меню голосовых команд (т.е., как и до переустановки); - команду слышит, меню после произнесения команды закрывает, но команду не исполняет (вообще ничего не происходит). Пробовал разные команды. Если кто сталкивался с таким (или не сталкивался, но имеет идеи по теме), буду благодарен за рекомендации. |
V.Viktor: |
RedDen хороший вопрос, я бы еще помнил У меня с завода стоит вот это: Номер по каталогу (CM_BCMii_PN): BV6N-14A073-FS CM_BCMii_F188_Версия_ПО: BV6N-14C094-XA, но у меня кнопка, для ключа другой блок и они не взаимозаменяемые!!! Еще одна особенность этих блоков то, что к ним не подойдут новые ключи, которые можно прописать на серию DV и новее (это касается машин с кнопкой, по ключам не подскажу — не сталкивался)! После серии BV пошла серия DV — там все равно кнопка или ключевой запуск, главное что бы были полные, ну и это справедливо для серии F и последней серии G. В них запихать можно как старые, так и новые ключи. P.S.: сейчас у меня валяется серия F, все никак не доберюсь поставить его вместо BV, могу посмотреть какие там буквы, если интересно. |
X XABK: |
Спасибо. Еще бы знать какой адаптер заказывать. Заказал пришел какой-то фуфлыжный, не подключается, вскрыл, а там вообще какая-то левая плата. |
X XABK: |
Всем привет.Подскажите какая программа и какой самый дешевый адаптер смогут скинуть ошибку BCM по лампам ближнего? |
L lunichkin.vadim: |
Он же ксенон с автокорректором? |
У меня дхо сразу горелиА по активации стоит :HiD альтернативный |
Q Qwer102: |
Всем привет! Подскажите сколько ватт у штатного ксенона? |
