alarcos
29 September 2020mobile
What are these connectors for, for BCM and ceiling connector?
alarcos
Dik_g
Thanks, I'm going to look for the Molex connector on Aliexpress, I guess I only buy the female one, right? the led lights have a male connector. Where to get led and necessary material at a good price? Where to get the BCM connection pins or C912 ?
Thanks you
Dik_g:
для управленя с sync, нужно 3 провода от светодиода
С2280Н 1. Pin4 — power " + " 2. Pin15 — LIN 3. Минус прикручиваем к кузову автомобиля " - " |
Hello friend, I am still investigating the installation of ambient light on my Kuga 2 Restyling. One question, is it necessary to have the ceiling console with LEDs like Focus 3? Where can I get, for example, WPT-911 Motorcraft connectors and LED diode for installation? Any pictures of the roof console connection? Thanks for the help
Dik_g:
у меня 2018, я использовал схему 2013 |
So my electrical schematic is wrong? I am not going to mount the ceiling panel of the ambient light, I am going to operate it from the Sync 3.4 screen.
polzikow:
только делиться никто не хочет ( |
Right, too bad. Now they want to earn money.
Yo he visto instalacin sencilla, solo con 3.4 19101, sin abrir APIM. Supongo que hay mucho metodos.
Ok thanks, the only thing that in Kuga restyling, you do not have to disconnect / connect pins in the C23 connector of the A pillar, apart from the BCM connections in Kuga there is only pin 12, correct?
Thank you very much
alarcos
21 August 2020
Hello friend, I want to implement ambient light on my Kuga Trend +. Currently I have light in the front feet to 2 wire W5W. In ETIS I see a CC2280H (BCM) cable coming out from PIN 12 to the ceiling, PIN 6 (LIN 2).
Then, on the ceiling connector:
PIN 15 to PIN 2 RGB LED
PIN 16 to PIN 1 RGB LED.
PIN 5 is ground.
PIN 7 panel / panel lighting.
It is right?
Thanks and sorry for my English.
alarcos
18 August 2020
PIN 5 is ground.
It is right?
Hello mate, is it possible to activate this in FORSCAN on Kuga 2 Restyling with halogen headlights? Can they be activated in the fog lights?
AuRoN89:
A-TEAM video player will be released FOR FREE in the next few days. It doesn't use the shitty Video.qml, but it's still native. and doesn't have any issue ![🙂](//css.ffclub.ru/em/1f642.png)
Keep and eye on www.fmods.net (still offline) for the release |
Is it possible to access this website?
alarcos
10 June 2020mobile
Good guys, is it possible to activate, via Forscan, the turn signals in lower fog lights with halogen headlights? In Bixenon headlights if possible, right next to the xenon bulb is an h15 bulb. Thank you
alarcos
16 June 2020mobile
So is it the same 1.5T 120 and 150/160 / 180hp? Is it possible to load the firmware of the 150 for example to my engine? Thanks and regards
Где найти прошивку для 1.5T 150/182?
Спасибо и всего наилучшего
MaximA:
No, it`s not PNP, unfortunately. For example - VOL button in mk3 wheel is one set with 5 buttons, in mk4 - 3*2 buttons. Other buttons - the same. |
A pity, I want to change my steering wheel for an ST-line of my current generation of Kuga, but here in Spain it is very expensive. I like the wheel of the FF4 better. Is it very difficult to change the pin out of the steering wheel? Has a lot of work? Thanks for the help. Cheers
max_470:
Hi man!
We are all interested in 1.5T with 120hp. Because we don`t have such an engine here in CIS and Russia. Can you make a photo of your engine and can you give a VIN of your car so we can find a firmware for an ECU?
thanks! |
Hello, I look for it and I tell you. Here in Spain they say that the 120/150/180 is only electronic. Cheers
Hello everyone from Spain, I have a new Kuga 1.5T Ecoboost 120hp and I would like to know the differences with the 150 and 180hp engine. Is it just electronics? Can I power up to 150 eg with original firmware? Thank you and forgive for my bad English. Cheers
MaximA:
This is a very difficult job: you need to modify the buttons. A lot of differences between the buttons. Airbag also does not fit. |
Thanks for your quick response, so it's not Plug & Play? Are not the same connections? Could you explain a knob the process. I attach the image of my flyer. Thank you
