Hi guys
Can u help me with finding cover under engine. My Focus MK2 petrol engine is with fitted front bumper from CC , so big cover under engine has no problems with mounting, only second small cover cant fit well on bumper
Need some part number or for which model i should search this small cover.
Appreciate for helping !
Hi guys , can u tell me if there is some way to see BT option in CD on IC display. I expect that there will show some information on larger display but on smaller ?
I unlock all options in HEC but only shows Voice when using this command.
Cheers !
Finally guys i can proud with my hard work these days
I managed to update successfully my bluetooth module Nokia and bluetooth sharing works fine now. Hope this info will be useful for more users and these are steps that i managed to do:
- format flash drive in FAT32
- transfer only .bvc and .vbc files for exact language that u have (for ex. my was italian so i drop only 8M5T-14D511-EV.bvc and 8M5T-14D511-EV.vbf )
- plug flash drive , turn on player , turn on ignition and it should be shows "Update running , please wait"
So my doubts were correct - both Novero and Nokia can stream bluetooth media.
Cheers guys
mandalore105Why i begin to update firmware it shows me that error :
" Update failed ! Please restart " I try almost everything but always finished with error
Smash71I try 2 different phones , same result. Today I try to update with latest 2012 update but it show "Update fails , please restart !! "
Can u tell me exactly which files to use in my flash drive.
Tnx a lot for helping again
So there is no chance to play music from my phone?
My hope is to update firmware with some latest . Can u share some links for Nokia or updates didn't depend on manufacturer.
Tnx for helping guy's!
No BT Audio didnt exist , only CD , iPod USB and AUX In ?
Hi friends , today i finally mount my bluetooth module with all wiring for it. All seems working correct , but only playing music from phone didint work. I see in ELMconfig and there is no errors (both module and Sony player are from same car) , also in Configuration page it shows "BT/VC High + USB + BT Audio".
Can u help me with make playing music from phone on my Nokia's module.
Here is my module
Cheers !
Yeah unfortunately my module uses port that is different from mini USB. Hope will find or other way is to replace porn on module with some normal.
Smash71I found C432 form BMW e39 , here are pics
mandalore105Can u show me pic on this older type of USB i cant find it
I ask info for Bluetoth module's connectors. Tonight after long research i found that connector number 1 can be found in BMW e39 and it costs me nothing
Today after i saw finally BT module in my hands
i understand that connector 2 is different than USB 2.0 port , i think that is normal USB port but unfortunately is something different. So for now he is problem , hope u guys will help me for some information
Here is BT module and pinouts
No i mean this one that is used by bluetooth module
Tnx guys finally man who sell it found Sony's original book that includes code
Although i was in Ford's dealer shop and ask mechanics , they told me that with serial number on player they can generate new code.
So next problem is 2 connectors that are missing. Is someone know other car that uses same connector as C432 ?
Cheers guys and anagin tnx for helping !
Hi guys is it true that in official service they can find code for Sony's player only with serial number on it. I find all kit with BTW module but unfortunately player haven't got code .
Finally mount front bumper form CC , fits perfect , look great - very pleased
Next step is rear bumper from mk2.5 . Cheers !
Great to hear that guys
These days will work on mounting on my car.
mandalore105As far as i know i must set only in HEC that car has washer level sensor not in GEM.
Hi guys , i decided to install washer level sensor after i found kit from Opel for only 5$
Today i remove front headlight to see if my car had wiring from GEM. I found connector with 2 wires on one side and 6 from other. Can u tell me if this connector had correct wiring for washing sensor so i just mount sensor on my tank ?
Cheers !
Ok tnx mate
Its a lot of work and dont know to take on this , maybe will use some other or will leave. Most important is that auto dimming mirror works perfect , fits perfect and its more than twice cheaper that Ford's
Cheers !
mandalore105Yes i mean blinking signal , i want to use it on my new rear view mirror which i mounted from bmw e39
he has red diode which i want to make it blinking like it on the instrument cluster.
Ho guys can someone tell me how can i catch signal from instrument cluster on blinking red diode when car is locked , thanks
Cheers !
