W wowfans: |
Universe Thank you for your prompt reply. I have already replaced the airbag cover, with multimedia buttons, and cruise / lim buttons. In order to save money, I refit the right button (OK with arrows circuit board, M with mutimedia control shell ), replaced the SMD RESISTOR on the circuit board with the same value that on the cruise/lim controller , so now the left the button(ok with arrows)is used to control the trip computer settings or switch the displaying information , the right button (the appearance is M with next/previous/vol+/vol- , the circuit board has been changed ) is used to control cruising / lim speed driving, and so I need't to cut the steering wheel to install the cruise/lim controller. About the odometer , I've bought a new basic odometer which has been installed the firmware F1ET-14C026-AAE, it's a 2012 focus English firmware, everything works ok, the firmware can support the cruise control, speed limiter, and view the mileage information, consumption information, tire pressure detection function... Now I want to upgrade the firmware to a 2015 focus English firmware, model is F1ET-14C026-AAJ , I'v downloaded it from the site that you provided me , and I also download the other 3 maching documents: F1ET-14C318-AC, F1ET-14C026-AEG, CM5T-14C318-AD. I'm a novice, only get a elm327 cable (ms-can enabled) , so I want to konw how to install the new firmware ( the 4 files above), and these 4 files form a complete firmware? No more files needed ? If the firm is competed , can I use the focccus 0.8.6 , switch to the "tools" table, use the "upload vbf" function to install the new firmware? or I must by a new els27 cable to replace my elm327 cable ? My car current status: ![]() ![]() |
![]() ittrium: |
duorw Seems that now it is not ELM327 related problem. The problem is that your IPC doesn't accept the secondary bootloader to the address it is uploading. Maybe your IPC is different and is not supported by FoCCCus yet. I will check the right bootloader according to your log a bit later and will let you know. |
![]() ittrium: |
duorw Seems that your ELM327 is not stable or fast enough. Is it based on FTDI chip? If so, try to set timeout to 1 ms in device properties in device manager (default is 16 ms). And if it doesn't help, enable logs in FoCCCus and share here. |
![]() ittrium: |
![]() ittrium: |
![]() ittrium: |
![]() ittrium: |
duorw You need ELM327 with switch for MS-CAN bus, because IPC on Focus Mk3 is on MS-CAN. The sequence is correct, but actually you don't need to update calibration if just want to add DDS and cruise. It may be enabled on old fw versions. All you need is to change direct configuration in IPC and change central configuration in BCMi. Then for DDS you have to execute ABS initialization (still in FoCCCus). But anyway your ELM327 must be with MS/HS-CAN switch, or you need STN1170-based tool, which has two can buses out of the box. |
