Hi all, I need help. I have ff3, 5" screen, oem module and camera. I got the module new. I was using it for about 2 years. There was DTC that says module is not configured. I found configuration using VIN of same car but factory camera. When I wrote configuration camera stopped working instead of camera screen shows old parking sensors display. Even if I wrote back original configuration it still does not work. original configration was 7B1-01-01 FFFF FFFF B6 7B1-02-01 0202 0103 00C3 7B1-02-02 0000 BC 7B1-03-01 51C8 D5 7B1-04-01 0C0F 03DB I wrote 7B1-01-01 0045 1302 14 7B1-02-01 0501 0100 00C2 7B1-02-02 0000 BC 7B1-03-01 51C8 D5 7B1-04-01 0C3C 0308 5" screen is also not factory. It also had DTC that says module is not configured. Its configration was 7A5-01-01 00AE 7A5-02-01 0000000000AF 7A5-02-02 0000000000B0 7A5-02-03 0000000000B1 7A5-02-04 0000000000B2 7A5-02-05 0000000000B3 7A5-02-06 0000000000B4 7A5-02-07 0000000000B5 7A5-02-08 0000000000B6 7A5-02-09 0000000000B7 7A5-02-10 0000000000BE I changed 7A5-01-01 to 02B0 (I could not find other decoding) I have two DTCs ===BCMii DTC U2101:00-2F=== Code: U2101 - Control Module Configuration Incompatible Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Body Control Module Freeze Frame : -GLOBTIM: 186534473 sec - Global real time -TOTDIST: 75532.0 km - Total Distance -MAINECUV: 12.00 Volt - Main ECU voltage supply -INCARTMP: 87 °C - In car temperature ===END BCMii DTC U2101:00-2F=== ===IPMB DTC B115E:08-0B=== Code: B115E - Camera Module Additional Fault Symptom: - Bus Signal/Message Failures Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Image Processing Module B ===END IPMB DTC B115E:08-0B=== |
Hi, Please help. I installed module using OBD. I mean I connect CAN+ CAN- Power and GND to OBD. And connect VIDEO+ and VIDEO- to scrren. Then changed #99 to 02 then Reset ECU of FCDIM (also removed battery wait 5 min then reconnet). But there is no image, also there is no message like "there is no camere". There are two DTC one in BCM U2101:00-2F Control Module Configuration Incompatible and one in FCDIM U2100:00-2F Intial Configuration Not Complete. Thanks in advance. |
