As i have Titanium X , with all Extras , my car Battery even with low mileage is perfect , i do not suffer from battery drain even with Bluetooth Elm327 always plugged i .
Elm327 goes to sleep , only red Led stay's active.
I drive with heated seats , heater , DRL , and now winter lights on all the time.
So no battery problems
Preee
17 November 2013
htcsb
I fitted this in June 2013 , i travel 12 miles per day so it gets charged for about 30 minutes per day. I have turned all other Apps on the phone off so not to drain the battery and allow charging. currently the battery remains on 80% and does not switch off under current charging.
If i turned on GPS and added network card , to the phone then my current 12 miles per day is not enough to keep battery charged.
I have also stored MP3 music files on there and can also play music via bluetooth if required , but not very often as i use USB socket .
The Phone comes with a spare battery.
The only thing that has failed so far was the Poor Mini Usb cable supplied with the phone , so i changed it.
Ok i will write in English if that is better for people to translate.
I know sorry Google translate is not very good
I have no battery drain problems as Torque Pro and Phone are both set to sleep once no power is going through.
This does not drain the battery as the Bluetooth Obd2 also sleeps.
I have Titanium X ecoboost and i travel only short distances and battery still remains fine.
For Ford FF3 there are about 30 different gauges you can set up , Turbo and Boost guage can be configured under setup.
You can also set minimum and maximum settings.
You can Download a Free version of Torque Pro from Google Play Store.
Do you want me to write in English and also translate to Russain or does the Russian translationg not work ?
Я настроил Pro Крутящий момент, отредактировав тему уменьшить размер виджета, и изменил цвета, которые я хотел, я затем установить телефон спать, когда никакая сила не поставляются. Затем я установил мой экранов, которые я хотел.
Я снял защитную решетку и помещен динамик в сторону под приборной панелью, телефон закреплен в с кожурой с помощью двухсторонней липкой пены. Это связано с зажиганием живой 12v адаптер USB в перчаточном ящике. Это автоматически включается, когда я завести машину.
Только ошибка у меня есть, Bluetooth сканирует каждые 2 минуты, но это не проблема.
Частей, которые необходимы являются синий зуб ELM327
367.59 ruble
http://www.ebay.co.uk/itm/V1-5-Mini-Bluetooth-E...0666885
6-дюймовый экран Android китайский телефон
6564 ruble ,стоимость меньше из Китая
http://www.ebay.co.uk/itm/6inch-3G-Android-4-1-...7d161da
Крутящий момент от Pro Google Play магазин
157Ruble
https://play.google.com/store/apps/details?id=or...l=en_GB
Фокус ff3 повышение Pod
3150 Ruble
Я принес один из Ebay, но она была сломана так, я принес его непосредственно от Форда
Очень сожалею о переводе Google
Preee
4 February 2014
16
Hi guys . i would like to show you my Android Boost pod i have created with a 6" android phone and Torque Pro using a bluetooth Elm327 hope you like it. Any Questions please ask.
Привет, ребята. Я хотел бы показать вам мою Android Повышение Pod я создал с 6 "Android телефонов и крутящего момента Pro использованием Bluetooth Elm327 надеюсь, вам понравится. Любые вопросы, пожалуйста, спросите.
http://www.youtube.com/watch?v=OzgggDWVNhI
> s1270.photobucket.com
Thanks , unfortunatly ADS will not sell to Uk
Hello i have tried searching but i can't find the firmware for the FP7 screen , where can i find this.
Здравствуйте, я попытался найти, но я не могу найти прошивку для FP7 экрана, где я могу найти этого.
Извините за мой плохой перевод, я хочу попробовать и установить индикатор давления под моим FF3 1.6 EcoBoost, у меня теперь есть датчик. Я ищу ST схемой, если кто может помочь мне, пожалуйста.
Sorry for my poor translation , i want to try and fit the boost pod gauge to my FF3 ecoboost 1.6 , i now have the gauge . i am looking for the ST wiring diagram if anyone can help me please.
Regards
Paul
Hi , does anyone have the wiring diagram for the ST turbo Boost gauge , i would like to see if i can get it working on a FF3 1.6 150ps ecoboost.
Hi
I have the button , all the wiring is in place and i have traced the wiring and it terminates at c111 conector.
Would i just need to extend the single wire into the ABS fuse box as in page 6 of this topic , or would i need to extend all of the wires from the switch.
button lights up fine with side lights , so i'm just hoping that the single wire that stops at c111 just needs to be extended into the ABS fused under the bonnet.
Google
Привет
У меня есть кнопка, все провода на месте, и я проследили проводки и заканчивается в C111 conector.
Может я просто нужно расширить одного провода в блок предохранителей ABS, как и в стр. 6 этого вопроса, или же мне нужно, чтобы продлить все провода от выключателя.
подсветка кнопки нормально с бортовыми огнями, так что я просто надеялся, что один провод, который останавливается на C111 как раз должен быть расширен в ABS слились под капотом.
Hi civil-zz
two quick questions
1) on GEM page 3 what is ISS
2) Do you plan on activating PCM page and is this needed for CC to be completed with HEC and GEM
Thanks
Preee
Preee
10 April 2012
This is the type of switch i used for my ELM327
I have tried to post a link but could not get it to work.
VitaR:
Preee Turn the ignition key in position I, press "set\reset" button, and hold button "set\reset" turn to position II, and he is 5-10 seconds is a TEST mode. Turn the button until you see the window "ROM LEVEL" |
Hi i have checked and my Rom is 508 , i get a Green arrow on start up and arrow appears at just over 6000rpm. it would be nice if this appeared at 4000rpm , but it's not a problem
. In the Test Mode it now display's Eco Mode settings.
This is the information i get from HEC , is this the correct test mode?
systemroot:
Preee look at your rom level in HEC, you can do it in test mode |
Thank you for your help , my FF2 is only 1.6 so that explains EHPAS.I will take a look at my rom level
lp-san:
Preee English maybe? |
Sorry Google Translate does not work very well.
Gear shift light come's on with ignition , but i thought would activate about 4000 prm to tell me to change gear ECO , it does work at 6500rpm , but i never really hit 6500rpm.
I have used ELM-FF2 and ELMconfig 0.1.1.7 . i have turned on lots of great features in these wonderful programs.
Gear shift at about 3000rpm/4000rpm , would tell my wife she is driving my car better
@systemroot
Спасибо за Ваш ответ переводить сложно, поэтому EHPAS не может быть установлен на моей машине.
IPC часть я не понимаю, может быть, вы имеете в виду GEM программного обеспечения не является правильным в моем FF2 для передачи света смену?
