У меня вопрос, кто-нибудь устанавливал такой или похожий чип, а то я нашёл на аукционе
eBay.com
за 20$, написано что увеличивает мощность авто на 20 л.с.
----------------- информация о лоте --------------------
This auction is for a Dynotec Performance chip/module. This auction will only fit the vechicle in the title for other vechicles look at my other auctions. All vehicles have an Electronic Control Unit (ECU)-a computer chip that electronically manages and monitors your car's performance-that is made according to government regulations. That means that your car could be going a lot faster and getting more power if you replace the ECU. That could cost up to 2000 dollars. This mod will modify your stock ECU with a Dynotec performance chip. This mod connects to the car's ECU by replacing the Intake Airflow Temperature (IAT) Sensor. Once the module is installed, the ECU will read that the air coming in through the intake is cold air; think of it as a "default" setting on the ECU. When the ECU reads this, it leans out the air/fuel mixture-in other words, it will take in more air, and then add more fuel to compensate for the extra air coming in, thus, producing more power and advancing timing 1 to 2 degrees. Because the engine is creating more power, give your Car or Truck up to 20 More Horsepower!!
this product is backed by a Life Time Manufacturer Warranty
new
gain up to 20 horse power
100% SAFE, 100% LEGAL!!
Does not void factory warranty
No tools required
Installs in under 10 minutes
LIFE TIME Guarantee
Accelerate faster and a higher top end
Comes with instructions for installation
Heat resistant and water proof
Slides Right In To Factory Sensor No Need to Solder or Cut Factory Wiring
Great Gift
Sorry will not work on turbo or supercharged engines.
Now is the time to buy this chip wants it hits stores the price will be 119.99 so buy now and save lots.
I accept paypal, money orders. send paypal payments and questions to dadadayton2000@yahoo.com.
Please do not bid unless you plan on paying for the item. negative feedback will be left for non-payers.
вот и не знаю, стрёмно как-то поставишь его, а он тачку спалит или еще что натворит...
подскажите, стоит заказывать?
