Kawa1980:
Hello, could someone tell me where pin 1 starts (green, pink, white, blue)? I wanted to prepare the wiring for the heated seat buttons for future assembly. According to what I have seen in the diagram, they are pins 22 and 23.
you have pins written on the plug connectors
strattec:
+ Замена часовой и рестового руля SASM - F1FT-3F818-BC - работать не будет |
what sasm will be suitable? I want to keep the steering wheel heating
zappero38:
If you have installed 3.5mk BCM and IPC you can install Volvo radar without internal module since you have newer BCM but first you will need to update it with FF mk3.5 or Kuga mk2/mk2.5 software. |
I understand that I need to upload software from version 3.5 to bcm, I have the appropriate sasm, what about ipc? to change to the counter from focus mk3.5? and what volvo radar will work with software from 3.5? will software from 3.5 work with parking sensors, blis and windscreen cameras?
Hi.
I have a 2012 Ford Focus MK3 1.6TDCi.
I am thinking about installing ACC, my vehicle specification:
PCM - BV61-12A650-NG
PAM - BM5T-15K866-BP
BCMii - GV6T-14A073-EF
IPC - FV4T-10849-LG
I have a heated steering wheel from a 2015-2018 car, the car is from before the refresh. I was thinking about buying a Volvo AG9N-9G768-BF radar, Ford BV6T-14B588-BF module. Will it work in the car? Will all the buttons on the refreshed steering wheel work?
adrian92
29 September 2024mobile
Cze.
Wymieniem klimatyzacj manualn na klimatyzacj elektryczna, dokonaem flash przez forscan, zmieniem w as built 726-01-02 z 09 na 19, oraz w main bcm w pozycji inynieryjnej na 42 pozycji modu sterowania klimatyzacj na pozycj 01 elektryczna kontrola klimatu. Brak bdw ale kompresor klimatyzacji nie zacza si. Co moe by przyczyn ?
Hello
I replaced the manual air conditioning with electric air conditioning, flashed it via forscan, changed in as built 726-01-02 from 09 to 19, and in main bcm in engineering position in position 42 air conditioning control module to position 01 electric climate control. No errors but the air conditioning compressor does not turn on. What could be the cause?
