Kawa1980
Santander (ES), Ford C-Max II
Модернизация и переделка штатных аудиосистем Аудио, мультимедиа, навигация Focus 3
Kawa1980
25 Marchmobile
Hello, I need help identifying the outputs for the center speaker cables. I looked at the wiring diagram and I know they are numbers 20 and 8, but I don't know which connector. Sync 3.
Kawa1980
9 Marchmobile
adrian92
Thanks Adrian92
Kawa1980
4 Februarymobile
Hello, could someone tell me where pin 1 starts (green, pink, white, blue)? I wanted to prepare the wiring for the heated seat buttons for future assembly. According to what I have seen in the diagram, they are pins 22 and 23.
Kawa1980
13 Januarymobile
Xglooom.Thank you very much for your help and answering a few questions. Who controls the time and heat of the steering wheel, the clock spring? Could it then take the current from (pin No. 3 is positive. It can be routed to the BCMi on pin No. 7 of connector No. C8, I got this from the Driver2 forum after reading a bit), greetings
https://www.drive2.ru/l/9562741/
Kawa1980
13 Januarymobile
Hello, I need help if someone could tell me, my BCM does not have pin 19 of the C2280F, can it be connected somewhere else? Could the steering wheel be turned on with the button on the Sync 3 screen and if it uses a different pin?
