chleuh2-34
Mah, Montpellier (FR)
Ford vehicles2 years
Электрооборудование2 years
chleuh2-34
18 January 2023mobile
the column lock communicates via the bcmi then the abs is no relation between the bcmii and the pscm according to the diagrams
when the column lock is locked faulty you cannot start or switch on the ignition no ignition
I had bought a bcmii starter kit counter key column lock I tried it on my vehicle the column lock worked well it locks it unlocks normally but still fault u0515
chleuh2-34
17 January 2023mobile
the original took on water I bought a used one but it doesn't work
pscm has nothing to do with electric column lock
chleuh2-34
ok so bcmii problem I have to find a new electric column lock then I will drop off the vehicle at ford
chleuh2-34
16 January 2023mobile
and if I put a rfa 19g481 AE
chleuh2-34
here is the vin number where I picked up my bcmii to mount on my vehicle
WF0WXXGCEWFY06612
chleuh2-34
the column lock problem is resolved, what a relief,
chleuh2-34
ok so I'm going to have to activate steering column in ipc concerning the bcmii that Ford sold me it's blank I couldn't program it with forscan
chleuh2-34
15 January 2023mobile
I saw the active electric steering column option in the backup ipc programming
chleuh2-34
the current bcmii comes from ford kuga all options I tried to program a bcmii with forscan impossible
and I just made a mistake I deactivated the column lock in bcmii it goes back a long time and I thought about it and now I have deactivated the column lock in ipc counter and problem I again have a column lock fault in bcmii
chleuh2-34
I would replace the bcmii Ford sold me a new bcmii I imagine that there are all the options in this new one but only forscan cannot program it
the only thing I changed in bcmii I deactivated the electric column lock the original is defective and you have to buy a new one
chleuh2-34
I'm lost I have no solution
Блок предохранителей (ВСМ) Электрооборудование Focus 3
chleuh2-34
привет я заменил свой оригинальный bcmii DV6T-14A073-HH я заменил его на F1DT-14A073-PC я запрограммировал все работает отлично запирание разблокировка также работает есть то, что запуск без ключа не работает сообщение отображается ключ не обнаружен u0515 Ford c max 2l 140 2014
chleuh2-34
14 January 2023mobile
and if I try the rfa update?? with forscan
chleuh2-34
13 January 2023mobile
Yes
chleuh2-34
I noticed the rcm has a different vin number than my vehicle
chleuh2-34
12 January 2023mobile
it's not the same because I changed the key star kit again
I have to update my autel software because I don't have this option as in the photo
chleuh2-34
11 January 2023mobile
since rfa replacement i did smart key programming
chleuh2-34
9 January 2023mobile
the fault code u0515 is effective it comes back when I press the keyless start button I cut the red wire from rfa to the bcmii start button, still the same fault, no other faultnumber 3 = rfa number 17 = start button number 14 = bcmii
chleuh2-34
chleuh2-34
I replaced all the parts as original but still the same u0515 and in ipc sometimes I have u0214
I switch on the ignition and I open the driver's door I have a message
Ford smart key switch off ignition press power
