Location
DE00/7D0-01-01: xx**-xxxx-xxxx
Values
00=EP On, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC Not Available
01=EP On, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC CGEA SCCM
02=EP On, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
03=EP On, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWFC - C1MCA
04=EP On, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC Not Available
05=EP On, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC CGEA SCCM
06=EP On, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
07=EP On, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWFC - C1MCA
08=EP On, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC Not Available
09=EP On, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC CGEA SCCM
0A=EP On, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
0B=EP On, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWFC - C1MCA
0C=EP On, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC Not Available
0D=EP On, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC CGEA SCCM
0E=EP On, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
0F=EP On, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWFC - C1MCA
10=EP On, EPT 20 minutes, CM IPC, MC Disabled, SWC Not Available
11=EP On, EPT 20 minutes, CM IPC, MC Disabled, SWC CGEA SCCM
12=EP On, EPT 20 minutes, CM IPC, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
13=EP On, EPT 20 minutes, CM IPC, MC Disabled, SWC SWFC - C1MCA
14=EP On, EPT 20 minutes, CM IPC, MC Enabled, SWC Not Available
15=EP On, EPT 20 minutes, CM IPC, MC Enabled, SWC CGEA SCCM
16=EP On, EPT 20 minutes, CM IPC, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
17=EP On, EPT 20 minutes, CM IPC, MC Enabled, SWC SWFC - C1MCA
18=EP On, EPT 20 minutes, CM Reserved, MC Disabled, SWC Not Available
19=EP On, EPT 20 minutes, CM Reserved, MC Disabled, SWC CGEA SCCM
1A=EP On, EPT 20 minutes, CM Reserved, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
1B=EP On, EPT 20 minutes, CM Reserved, MC Disabled, SWC SWFC - C1MCA
1C=EP On, EPT 20 minutes, CM Reserved, MC Enabled, SWC Not Available
1D=EP On, EPT 20 minutes, CM Reserved, MC Enabled, SWC CGEA SCCM
1E=EP On, EPT 20 minutes, CM Reserved, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
1F=EP On, EPT 20 minutes, CM Reserved, MC Enabled, SWC SWFC - C1MCA
20=EP On, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC Not Available
21=EP On, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC CGEA SCCM
22=EP On, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
23=EP On, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWFC - C1MCA
24=EP On, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC Not Available
25=EP On, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC CGEA SCCM
26=EP On, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
27=EP On, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWFC - C1MCA
28=EP On, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC Not Available
29=EP On, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC CGEA SCCM
2A=EP On, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
2B=EP On, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWFC - C1MCA
2C=EP On, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC Not Available
2D=EP On, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC CGEA SCCM
2E=EP On, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
2F=EP On, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWFC - C1MCA
30=EP On, EPT 30 minutes (FNA), CM IPC, MC Disabled, SWC Not Available
31=EP On, EPT 30 minutes (FNA), CM IPC, MC Disabled, SWC CGEA SCCM
32=EP On, EPT 30 minutes (FNA), CM IPC, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
33=EP On, EPT 30 minutes (FNA), CM IPC, MC Disabled, SWC SWFC - C1MCA
34=EP On, EPT 30 minutes (FNA), CM IPC, MC Enabled, SWC Not Available
35=EP On, EPT 30 minutes (FNA), CM IPC, MC Enabled, SWC CGEA SCCM
36=EP On, EPT 30 minutes (FNA), CM IPC, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
37=EP On, EPT 30 minutes (FNA), CM IPC, MC Enabled, SWC SWFC - C1MCA
38=EP On, EPT 30 minutes (FNA), CM Reserved, MC Disabled, SWC Not Available
39=EP On, EPT 30 minutes (FNA), CM Reserved, MC Disabled, SWC CGEA SCCM
3A=EP On, EPT 30 minutes (FNA), CM Reserved, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
3B=EP On, EPT 30 minutes (FNA), CM Reserved, MC Disabled, SWC SWFC - C1MCA
3C=EP On, EPT 30 minutes (FNA), CM Reserved, MC Enabled, SWC Not Available
3D=EP On, EPT 30 minutes (FNA), CM Reserved, MC Enabled, SWC CGEA SCCM
3E=EP On, EPT 30 minutes (FNA), CM Reserved, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
3F=EP On, EPT 30 minutes (FNA), CM Reserved, MC Enabled, SWC SWFC - C1MCA
40=EP On, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC Not Available
41=EP On, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC CGEA SCCM
42=EP On, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
43=EP On, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWFC - C1MCA
44=EP On, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC Not Available
45=EP On, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC CGEA SCCM
46=EP On, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
47=EP On, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWFC - C1MCA
48=EP On, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC Not Available
49=EP On, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC CGEA SCCM
4A=EP On, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
4B=EP On, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWFC - C1MCA
4C=EP On, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC Not Available
4D=EP On, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC CGEA SCCM
4E=EP On, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
4F=EP On, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWFC - C1MCA
50=EP On, EPT 40 minutes, CM IPC, MC Disabled, SWC Not Available
51=EP On, EPT 40 minutes, CM IPC, MC Disabled, SWC CGEA SCCM
52=EP On, EPT 40 minutes, CM IPC, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
53=EP On, EPT 40 minutes, CM IPC, MC Disabled, SWC SWFC - C1MCA
54=EP On, EPT 40 minutes, CM IPC, MC Enabled, SWC Not Available
55=EP On, EPT 40 minutes, CM IPC, MC Enabled, SWC CGEA SCCM
56=EP On, EPT 40 minutes, CM IPC, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
57=EP On, EPT 40 minutes, CM IPC, MC Enabled, SWC SWFC - C1MCA
58=EP On, EPT 40 minutes, CM Reserved, MC Disabled, SWC Not Available
59=EP On, EPT 40 minutes, CM Reserved, MC Disabled, SWC CGEA SCCM
5A=EP On, EPT 40 minutes, CM Reserved, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
5B=EP On, EPT 40 minutes, CM Reserved, MC Disabled, SWC SWFC - C1MCA
5C=EP On, EPT 40 minutes, CM Reserved, MC Enabled, SWC Not Available
5D=EP On, EPT 40 minutes, CM Reserved, MC Enabled, SWC CGEA SCCM
5E=EP On, EPT 40 minutes, CM Reserved, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
5F=EP On, EPT 40 minutes, CM Reserved, MC Enabled, SWC SWFC - C1MCA
60=EP On, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC Not Available
61=EP On, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC CGEA SCCM
62=EP On, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
63=EP On, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWFC - C1MCA
64=EP On, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC Not Available
65=EP On, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC CGEA SCCM
66=EP On, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
67=EP On, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWFC - C1MCA
68=EP On, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC Not Available
69=EP On, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC CGEA SCCM
6A=EP On, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
6B=EP On, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWFC - C1MCA
6C=EP On, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC Not Available
6D=EP On, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC CGEA SCCM
6E=EP On, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
6F=EP On, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWFC - C1MCA
70=EP On, EPT 60 minutes (FoE), CM IPC, MC Disabled, SWC Not Available
71=EP On, EPT 60 minutes (FoE), CM IPC, MC Disabled, SWC CGEA SCCM
72=EP On, EPT 60 minutes (FoE), CM IPC, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
73=EP On, EPT 60 minutes (FoE), CM IPC, MC Disabled, SWC SWFC - C1MCA
74=EP On, EPT 60 minutes (FoE), CM IPC, MC Enabled, SWC Not Available
75=EP On, EPT 60 minutes (FoE), CM IPC, MC Enabled, SWC CGEA SCCM
76=EP On, EPT 60 minutes (FoE), CM IPC, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
77=EP On, EPT 60 minutes (FoE), CM IPC, MC Enabled, SWC SWFC - C1MCA
78=EP On, EPT 60 minutes (FoE), CM Reserved, MC Disabled, SWC Not Available
79=EP On, EPT 60 minutes (FoE), CM Reserved, MC Disabled, SWC CGEA SCCM
7A=EP On, EPT 60 minutes (FoE), CM Reserved, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
7B=EP On, EPT 60 minutes (FoE), CM Reserved, MC Disabled, SWC SWFC - C1MCA
7C=EP On, EPT 60 minutes (FoE), CM Reserved, MC Enabled, SWC Not Available
7D=EP On, EPT 60 minutes (FoE), CM Reserved, MC Enabled, SWC CGEA SCCM
7E=EP On, EPT 60 minutes (FoE), CM Reserved, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
7F=EP On, EPT 60 minutes (FoE), CM Reserved, MC Enabled, SWC SWFC - C1MCA
80=EP Off, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC Not Available
81=EP Off, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC CGEA SCCM
82=EP Off, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
83=EP Off, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWFC - C1MCA
84=EP Off, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC Not Available
85=EP Off, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC CGEA SCCM
86=EP Off, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
87=EP Off, EPT 20 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWFC - C1MCA
88=EP Off, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC Not Available
89=EP Off, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC CGEA SCCM
8A=EP Off, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
8B=EP Off, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWFC - C1MCA
8C=EP Off, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC Not Available
8D=EP Off, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC CGEA SCCM
8E=EP Off, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
8F=EP Off, EPT 20 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWFC - C1MCA
90=EP Off, EPT 20 minutes, CM IPC, MC Disabled, SWC Not Available
91=EP Off, EPT 20 minutes, CM IPC, MC Disabled, SWC CGEA SCCM
92=EP Off, EPT 20 minutes, CM IPC, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
93=EP Off, EPT 20 minutes, CM IPC, MC Disabled, SWC SWFC - C1MCA
94=EP Off, EPT 20 minutes, CM IPC, MC Enabled, SWC Not Available
95=EP Off, EPT 20 minutes, CM IPC, MC Enabled, SWC CGEA SCCM
96=EP Off, EPT 20 minutes, CM IPC, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
97=EP Off, EPT 20 minutes, CM IPC, MC Enabled, SWC SWFC - C1MCA
98=EP Off, EPT 20 minutes, CM Reserved, MC Disabled, SWC Not Available
99=EP Off, EPT 20 minutes, CM Reserved, MC Disabled, SWC CGEA SCCM
9A=EP Off, EPT 20 minutes, CM Reserved, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
9B=EP Off, EPT 20 minutes, CM Reserved, MC Disabled, SWC SWFC - C1MCA
9C=EP Off, EPT 20 minutes, CM Reserved, MC Enabled, SWC Not Available
9D=EP Off, EPT 20 minutes, CM Reserved, MC Enabled, SWC CGEA SCCM
9E=EP Off, EPT 20 minutes, CM Reserved, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
9F=EP Off, EPT 20 minutes, CM Reserved, MC Enabled, SWC SWFC - C1MCA
A0=EP Off, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC Not Available
A1=EP Off, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC CGEA SCCM
A2=EP Off, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
A3=EP Off, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWFC - C1MCA
A4=EP Off, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC Not Available
A5=EP Off, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC CGEA SCCM
A6=EP Off, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
A7=EP Off, EPT 30 minutes (FNA), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWFC - C1MCA
A8=EP Off, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC Not Available
A9=EP Off, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC CGEA SCCM
AA=EP Off, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
AB=EP Off, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWFC - C1MCA
AC=EP Off, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC Not Available
AD=EP Off, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC CGEA SCCM
AE=EP Off, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
AF=EP Off, EPT 30 minutes (FNA), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWFC - C1MCA
B0=EP Off, EPT 30 minutes (FNA), CM IPC, MC Disabled, SWC Not Available
B1=EP Off, EPT 30 minutes (FNA), CM IPC, MC Disabled, SWC CGEA SCCM
B2=EP Off, EPT 30 minutes (FNA), CM IPC, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
B3=EP Off, EPT 30 minutes (FNA), CM IPC, MC Disabled, SWC SWFC - C1MCA
B4=EP Off, EPT 30 minutes (FNA), CM IPC, MC Enabled, SWC Not Available
B5=EP Off, EPT 30 minutes (FNA), CM IPC, MC Enabled, SWC CGEA SCCM
B6=EP Off, EPT 30 minutes (FNA), CM IPC, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
B7=EP Off, EPT 30 minutes (FNA), CM IPC, MC Enabled, SWC SWFC - C1MCA
B8=EP Off, EPT 30 minutes (FNA), CM Reserved, MC Disabled, SWC Not Available
B9=EP Off, EPT 30 minutes (FNA), CM Reserved, MC Disabled, SWC CGEA SCCM
BA=EP Off, EPT 30 minutes (FNA), CM Reserved, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
BB=EP Off, EPT 30 minutes (FNA), CM Reserved, MC Disabled, SWC SWFC - C1MCA
BC=EP Off, EPT 30 minutes (FNA), CM Reserved, MC Enabled, SWC Not Available
BD=EP Off, EPT 30 minutes (FNA), CM Reserved, MC Enabled, SWC CGEA SCCM
BE=EP Off, EPT 30 minutes (FNA), CM Reserved, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
BF=EP Off, EPT 30 minutes (FNA), CM Reserved, MC Enabled, SWC SWFC - C1MCA
C0=EP Off, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC Not Available
C1=EP Off, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC CGEA SCCM
C2=EP Off, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
C3=EP Off, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWFC - C1MCA
C4=EP Off, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC Not Available
C5=EP Off, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC CGEA SCCM
C6=EP Off, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
C7=EP Off, EPT 40 minutes, CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWFC - C1MCA
C8=EP Off, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC Not Available
C9=EP Off, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC CGEA SCCM
CA=EP Off, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
CB=EP Off, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWFC - C1MCA
CC=EP Off, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC Not Available
CD=EP Off, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC CGEA SCCM
CE=EP Off, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
CF=EP Off, EPT 40 minutes, CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWFC - C1MCA
D0=EP Off, EPT 40 minutes, CM IPC, MC Disabled, SWC Not Available
D1=EP Off, EPT 40 minutes, CM IPC, MC Disabled, SWC CGEA SCCM
D2=EP Off, EPT 40 minutes, CM IPC, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
D3=EP Off, EPT 40 minutes, CM IPC, MC Disabled, SWC SWFC - C1MCA
D4=EP Off, EPT 40 minutes, CM IPC, MC Enabled, SWC Not Available
D5=EP Off, EPT 40 minutes, CM IPC, MC Enabled, SWC CGEA SCCM
D6=EP Off, EPT 40 minutes, CM IPC, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
D7=EP Off, EPT 40 minutes, CM IPC, MC Enabled, SWC SWFC - C1MCA
D8=EP Off, EPT 40 minutes, CM Reserved, MC Disabled, SWC Not Available
D9=EP Off, EPT 40 minutes, CM Reserved, MC Disabled, SWC CGEA SCCM
DA=EP Off, EPT 40 minutes, CM Reserved, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
DB=EP Off, EPT 40 minutes, CM Reserved, MC Disabled, SWC SWFC - C1MCA
DC=EP Off, EPT 40 minutes, CM Reserved, MC Enabled, SWC Not Available
DD=EP Off, EPT 40 minutes, CM Reserved, MC Enabled, SWC CGEA SCCM
DE=EP Off, EPT 40 minutes, CM Reserved, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
DF=EP Off, EPT 40 minutes, CM Reserved, MC Enabled, SWC SWFC - C1MCA
E0=EP Off, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC Not Available
E1=EP Off, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC CGEA SCCM
E2=EP Off, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
E3=EP Off, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Disabled, SWC SWFC - C1MCA
E4=EP Off, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC Not Available
E5=EP Off, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC CGEA SCCM
E6=EP Off, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
E7=EP Off, EPT 60 minutes (FoE), CM APIM (NA Market CGEA 1.2), MC Enabled, SWC SWFC - C1MCA
E8=EP Off, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC Not Available
E9=EP Off, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC CGEA SCCM
EA=EP Off, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
EB=EP Off, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Disabled, SWC SWFC - C1MCA
EC=EP Off, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC Not Available
ED=EP Off, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC CGEA SCCM
EE=EP Off, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
EF=EP Off, EPT 60 minutes (FoE), CM BCM (C1MCA and CGEA 1.3), MC Enabled, SWC SWFC - C1MCA
F0=EP Off, EPT 60 minutes (FoE), CM IPC, MC Disabled, SWC Not Available
F1=EP Off, EPT 60 minutes (FoE), CM IPC, MC Disabled, SWC CGEA SCCM
F2=EP Off, EPT 60 minutes (FoE), CM IPC, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
F3=EP Off, EPT 60 minutes (FoE), CM IPC, MC Disabled, SWC SWFC - C1MCA
F4=EP Off, EPT 60 minutes (FoE), CM IPC, MC Enabled, SWC Not Available
F5=EP Off, EPT 60 minutes (FoE), CM IPC, MC Enabled, SWC CGEA SCCM
F6=EP Off, EPT 60 minutes (FoE), CM IPC, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
F7=EP Off, EPT 60 minutes (FoE), CM IPC, MC Enabled, SWC SWFC - C1MCA
F8=EP Off, EPT 60 minutes (FoE), CM Reserved, MC Disabled, SWC Not Available
F9=EP Off, EPT 60 minutes (FoE), CM Reserved, MC Disabled, SWC CGEA SCCM
FA=EP Off, EPT 60 minutes (FoE), CM Reserved, MC Disabled, SWC SWMT - C1MCA and CGEA 1.3
FB=EP Off, EPT 60 minutes (FoE), CM Reserved, MC Disabled, SWC SWFC - C1MCA
FC=EP Off, EPT 60 minutes (FoE), CM Reserved, MC Enabled, SWC Not Available
FD=EP Off, EPT 60 minutes (FoE), CM Reserved, MC Enabled, SWC CGEA SCCM
FE=EP Off, EPT 60 minutes (FoE), CM Reserved, MC Enabled, SWC SWMT - C1MCA and CGEA 1.3
FF=EP Off, EPT 60 minutes (FoE), CM Reserved, MC Enabled, SWC SWFC - C1MCA
Notes
Not available: (Do not log missing messages - HW SWC)
SWC CGEA SCCM: (Log missing messages against SWC)
SWMT = C1MCA and CGEA 1.3: (Cursors and OK Button over CAN)
SWFC = C1MCA: (With Function Buttons)
x
