swearwolf
22 November 2021
still hoping sid803 will be possible!
nekto77thank you - unfortunately i don't have access to any of these tools
hi, sorry i can only type english...
i have c-max, 2.0 tdci, i cannot download the firmware from car it gets to about 90% then it says error 31 out of range. i have used different computer and elm cables, same problem. it is SID803 pcm, i need to update vidblock to 150a alternator.
also i cannot upload new firmware, it gets to the end and says same error, and the PCM becomes bricked
swearwolf
17 December 2020
hi, just wanted to say thanks, this was the problem
on the right side, with set buttons, i put some electrical tape over the board before assembling the housing, and problem solved
swearwolf
15 December 2020
MaximA
thank you again, i will have a check of this shortly, thank you
swearwolf
14 December 2020
MaximA
thank you again
I got: 3.6 no press, 3.6 on, 3.5 res, 2.9 +, 1.9 -, 0 off
seems my problem is the On button area?
swearwolf
14 December 2020
hi, i had it working for one day, and now it does not work at all.
when i test it with it unplugged from car, all the resistances are perfect, like the picture above.
when i plug it into car, in the clockspring, when i press 'OFF' i get 1700+ ohms? and ON, CAN, no resistance, open circuit. SET +, - do not work either.
any ideas? thank you
swearwolf
13 December 2020
thank you, all working now
swearwolf
12 December 2020
hi all
sorry for typing in english, i can't speak Russian .. lol
I've been trying to get this to work for a while now. I have done the mod to the cruise control buttons via the vitasku instructions, but i am still getting error P0578 - Cruise Control Multi-Function Input A Circuit and CC no longer works.
How do I test the resistance once each button is pressed? Thanks in advance for any help!
