Anyone here knows which those Volvo ACC radars could be fitted into FF3.5?
31400839
31400419
31471259
Hi guys!
I want to install ACC in my FF3 Lift with 2.0 TDCI Engine.
I have active grill shutter (Kysor) and the question is:
- can be shutter modificated to support ACC radar (e.g. by cutting some parts)?
- if not - can be shutter removed and reprogrammed from BCM and PCM?
- how can i find part number for grill shutter with ACC radar support?
Hello guys,
I am trying to install bixenon lights in facelift model (2018 year).
I have headlights, hcm module, front and rear sensors and now i am trying to buy headlight washers.
In Poland prices of headlight washers for facelift model are horrible. But for pre facelift model are rather cheap.
Does anybody know if headlight washers from pre facelift will fit to facelift model? And what about washers covers? If headlight washers will fit, then i still need to buy facelift washer covers?
Hello guys,
cezarg1410
17 November 2020
togvad Thank You very much!
It doesn't look difficult so i will try it out.
I will let You know about the results.
Thanks!
cezarg1410
17 November 2020
togvad thank You very much for Your response.
To be honest, wiring diagram which I have (downloaded from etis for FF 3 2018) is completely different.
Look at that:
What do You think? Is my diagram completely wrong?
cezarg1410
8 November 2020
Hello guys,
At the beginning: i read that topic from the beginning but unfortunately google transaltor isn't the best and i can't speak Russian
So i have few questions because i am not sure if i understood everything correctly.
I have FF3.5 from 2018 year with OEM Sync3 and monochromatic Ambient light (the red one).
I want to replace that with multicolor lights.
So:
- is that possible to run that multicolor lights without replacing the roof wiring? I am ok with controlling the color from Sync3 APIM.
- i know that i have 3 cables in the doors and in the foot lights, but on the roof lights there are just 2 cables. As I can see from the wiring schema - only the black one is missing (ground). So will adding just that one cable, give me possibility to replace LEDs with multicolor lights?
