mohyas89
Mohammed Yaseen, Erbil (JP)
Аудио, мультимедиа, навигация4 years
mohyas89
5 September 2020
Hi
is there any chance to change the home screen icons and choose the one i want ?
mohyas89
2 September 2020mobile
AuRoN89:
you cannot install ROW maps with the standard procedure. you have to use the reformatter.
great, it worked i just changed the number and i found middle east map and north africa file in this forum and the map worked.
Thanks for your great support.
mohyas89
2 September 2020
AuRoN89:
Replace the 2 with 4
Thanks for support, and regarding the map installation this is the autoinstall.lst, anything to be correct ?
[SYNCGen3.0_ALL]
Item1 = 4U5T-14G424-FAG
Open1 = SyncMyRide\4U5T-14G424-FAG.TAR.gz
Item2 = 4U5T-14G421-FAG
Open2 = SyncMyRide\4U5T-14G421-FAG.tar.gz
Options = Delay, AutoInstall
mohyas89
2 September 2020
AuRoN89:
give me your current asbuilt conf of the Block 1
Do you mean the AsBuilt for APIM ? or the block 1 for all of them?
mohyas89
2 September 2020
AuRoN89:
you need to change NAV type in asbuilt, from Telenav to NNG
can you provide me more details , because as you know the as built is codes and if you know which code to change. sorry for my bad english
mohyas89
1 September 2020
Hi How r u
i bought US ford focus 2018 with navigation. is there any way to add middle east maps ? i tried to reinstall ROW files but the navigation become faulty.
