Blazer2
Franta Prochzka, Kladno (CZ)
Аудио, мультимедиа, навигация5 years
Blazer2
16 March 2020
Thank you for your help The TFT display now works. The backlit 8 "Sync 3 automatic backlight still does not work. I have found that even the illumination settings of both displays do not work together. It only works for TFT display. Please, do you know the item for change via fordscan? Thank you very much.
Blazer2
15 March 2020
746/5000
Hi, I recently upgraded Sync 1 to Sync 3 in FF (version 3.0 build 19149). Everything works perfectly, only on the navigation shown on the TFT display between the alarms, no distance in meters. I still have 9999m, just after turning there jumps 1550m for a while and returns 9999m again. A measuring line is also displayed next to the arrow, which also responds to the distance (to the next turn) and it works correctly, just like on the large display. Anyone have any experience with it? Do you know what it might be?
I have another question, my backlight does not work automatically. Can it be the absence of a light sensor (I don't have the lights on automatically), or is it only in some settings and does it respond to the light switch? Thank you for the advice.
