ZaQik:
use ELMConfig 1. configuration - read from PCM 2. configuration - check Integrated speed control 3. procedure - page 2 - read firmware from PCM to BIN-file 4. procedure - page 2 - load firmware from file (it was created in step 3) 5. procedure - page 2 - Write current firmware ... configuration will written at the end |
These steps don't work for me, as I can't even load the PCM as you can see in the previous post.
Please, can anyone help me?
marleopr
20 November 2019mobile
Hello! Sorry for my google translator english, but I'm from Brazil, I have a Focus 2.0 Duratec Flex 2013, (Here in Brazil we consider MK2 but it seems to me that there in Europe is MK2,5 ??)
I installed the steering wheel cruise control, after that I opened the ELM-FF2 and activated the cruise control on the IPC and BCM module, everything happened good.
After that I went to ELMConfig (tried in versions 0.2.17c and 0.2.17b) to do the third step, activate in PCM, then when I try to load the PCM appears:
If I go to 'configuration' and try to load PCM it looks like this:
These steps I followed the video:
https://youtu.be/k4UlGCSfR4Y
Remembering that I have a genuine ELM that has the speed required for operation.
I also tried for Forscan extended, the PCM module does not appear to me.
I also have this other program, FoCCCus, but I never used it.
Thanks in advance to friends!
