O_zone:
Sorry, didn't note that you are trying to change DIDs for Windows close/open function. As far as I know availability of those parameters depends on SW version of your BCM... I May be wrong, but GV version and above couldn't be changed in that way, or they have another DIDs for it |
No problems
My SW is below the GV, as I show in the images. (F1FT-14C094-XA)
The doubts are, is it possible to access the block referring to DID39 or DID40, using Forscan instead of Focccus?
How do I find out which memory block is DID39, for example 726-01-01 ...
Many thanks for your answers
phnahes
2 September 2019
O_zone:
It was said many times that focccus does not operate with restyle in proper way, you should use forscan... |
Yes I understand...
But is possible to access the EE39 and EE40 using Forscan?
Has any way to convert EE39 to 726-**-** ??
How do I understand it?
thanks
Varela:
Попробовал сегодня поменять значение DID EE39 (GlobalCloseTime) блока BCM в Foccus. Было 06, поставил 01.Потестил и теперь открытые окна закрываются примерно через пол секунды удержания кнопки брелка Хотел попробовать поставить 00, но при нажатии READ теперь пишет ошибку типа CANNOT UNIT ELM. Надо попробовать открытие окон сделать так же, вроде DID EE40 |
Hello how are you?
Interesting this option. However I tried to do this on mine, it's a restyled Focus 3, but it doesn't work,
I get the following message: "Can`t enter security 3 into ECU".
I put on vbf directory, the files related to Bootloader and other "vbf", which I had placed in Forscan (which accesses normally)
It just read, but when click on write, give error.
Could someone help me solve this problem using FoCCCus?
Would it be possible to change Item 'EE39 / EE40' through Forscan?
Are the options DE, DC, EE, memory blocks, just like "As Built"?
Thank you very much.
