likesHello Russian friends!
There is a little trick that can get you the schematics and connector diagrams for 2013 and newer cars.
You need to enter the Ford Etis website (registration is required!) and log in with your credentials.
Go to the "vehicle" tab and enter the VIN or license plate of your vehicle. When the page opens DO NOT click on "wiring diagrams" but just move the pointer with the mouse over the text, so as to see the link in the bottom of your web browser (or right click with the mouse on it and copy the link).
For example for my Ford Fiesta I read: "https://www.etis.ford.com/wiring/global/main.do?language=ru&country=RU&bookCode=EGRE&modelYear=2016&requestType=TOC".
Look at the bookCode= code! In this case it is EGRENote: Older vehicles don't use this system, so the trick won't work!Now the wiring diagrams will be present using this web address:
https://www.etis.ford.com/wiring/global/diagram....age=001
See I entered
EGRE - for other vehicles you will need to replace that code.
This link refers to the first page of the diagrams (
page=001) of section 10 (
cel=010).
Now just repeat the link by setting page 002, 003 etc...
This is the list of sections (cel=xxx) that I was able to find:
cel=004 Symbols cel=010 Ground connection cel=011 Information on fuses and relays cel=013 Power distribution cel=150 Connector view cel=151 Component location view cel=152 Component location table
So in summary the web link will have to be modified in order to insert the code of the car model you need (EGRE for example); then put cel=004 and page=001
Then go to page=002, 003 etc...
When the page gives you an error, it means that you have reached the bottom of the section. Then you will change to cel=010, page=001, 002, 003 etc...
Hope this method helps!
Google translator:
Привет русские друзья!
Есть небольшая хитрость, чтобы получить схемы и схемы разъемов для автомобилей 2013 года и новее.
Вам нужно зайти на сайт Ford Etis (требуется регистрация!) и войти под своими учетными данными.
Перейдите на вкладку «Автомобиль» и введите VIN или номерной знак вашего автомобиля. Когда страница откроется, НЕ нажимайте на «схемы подключения», а просто наведите указатель мыши на текст, чтобы увидеть ссылку в нижней части веб-браузера (или щелкните правой кнопкой мыши и скопируйте ссылку). ).
Например, для моего Ford Fiesta я читаю: «https://www.etis.ford.com/wiring/global/main.do?language=ru&country=RU&bookCode=EGRE&modelYear=2016&requestType=TOC».
Посмотрите на код "bookCode="! В данном случае это "EGRE".Примечание: в старых автомобилях эта система не используется, поэтому трюк не сработает!Схемы подключения теперь будут доступны по этому веб-адресу:
Смотри, я ввел
EGRE — для других автомобилей нужно будет заменить этот код.
Эта ссылка ведет на первую страницу диаграмм (
page=001) раздела 10 (
cel=010).
Теперь просто повторите ссылку, установив страницу 002, 003 и т. д.
Это список разделов (cel=xxx), которые мне удалось найти:
интервал = 004 символа цел=010 Земля cel=011 Информация о предохранителях и реле cel=013 Распределение энергии cel=150 Представление коннектора cel=151 Компоновка компонентов cel=152 Таблица расположения компонентов
Таким образом, веб-ссылку нужно будет изменить, чтобы вставить код нужной модели автомобиля (например, EGRE); затем поместите cel=004 и page=001
Затем перейдите на страницу = 002, 003 и т.д.
Когда страница выдает ошибку, это означает, что вы достигли конца раздела. Затем вы перейдете к cel=010, page=001, 002, 003 и т. д.
Надеюсь, этот метод поможет!
