Hello.
Need help
When i activated the cruise control in my 2011 mk2.5 1,6 TDCI, with ELMConfig,
for battery saving ( the factory DTRL on in headlight in ignition position) because i switched the light switch to the parking (1)mode .
Now the engine can ONLY OFF in parking light position the light switch.
If i put out the ignition key because the light switch not the parking(1) or light on (2)position the engine not stopped..
If i take out the F110 fuse, the fault is fixed...
I have backup from HEC and GEM but unfortunately making in the parking position in light switch.
What can i do?
Thank You for Help!
