Tomdan
Tomasz, ilawa (PL)
 int(3)
Ford vehicles5 years
Tomdan
5 December 2019
I have added the key again and it is the same
and in parmetrach clutch what value it has
I have 75%
Tomdan
4 December 2019
there are no alarm systems
Tomdan
4 December 2019
Hello
I have such a problem in Ford Kuga 2.0 gtdi year 2014
Starter - ok
relay - ok
switching on the relay from the ECU ok (starter turns)
the clutch pedal works for max 75% (I don't know if it shouldn't be 100%)
The ECU sees the START signal from BCMi but does not turn on the relay
What else does turning on the starter depend on?
when you connect the relay it will light up and work for ok
What bites him?
It shows me the temperature in 104 Ccius car (maybe because of it)
