Superb1
VP (AU)
Электрооборудование6 years
Ford vehicles6 years
Панель приборов Электрооборудование Focus 3
Superb1
2 October 2018
24adonis
Thank you, how do I program keys? Forscan does not have the ability...
Superb1
1 October 2018
24adonis
I found a BCM from 2016 Focus F1ET-14A073-EF, would this be compatible?
Superb1
25 September 2018
I can help with 1: set the option DM8 in forscan/foccus in central config
Superb1
25 September 2018
24adonis
Thanks for the information in regards to the BCM.
Have you had any experience updating the ACM firmware? I know this is off topic but forscan does not show any fields to edit.
I would like to add external stereo power amplifier. I found on other forums if you edit 727-01-01 address you can enable 4 volt variable preouts
I have original ACM BM5T-18C815-RK and also F1E9-18C815-KAK
Any ideas if we can edit the module?
Thanks
Superb1
23 September 2018
24adonis
I have not been able to find anything on "BCM Maximum" For now I will leave the car with the updated F1ET.
For now my next project is to edit the ACM but I do not get any options for 727 address in forscan
I have original ACM and BM5T-18C815-RK and also F1E9-18C815-KAK
Any ideas, I would like to enable line out
Superb1
21 September 2018
Is it not possible just to flash newer firmware my modules?
Superb1
21 September 2018
Ok thanks, I will try to get the parts from the same donor car as the sync radio.
I assume the camera connectors are the same?
Superb1
21 September 2018
I have installed Sync 3 into 2012 Focus after conversion I get this blue screen with any BM5T firmware on door opening, its very bright
With F1ET I get black background with odometer but no parking sensor sound...
If I had to decide I prefer the black screen of F1ET, unless anyone knows how to remove the blue background
Superb1
21 September 2018
24adonis:
24adonis
I had to remove the IPC and proceed to flashing on my work bench, too many failed attempts using ELM327 inside the car.
Now I can flash 1st go, its excellent so I tried the F1ET type and its much nicer.
Any ideas on enabling ST Logo?
Also anyone figure out getting parking sensor sound to be regained?
Superb1
17 September 2018
I had planned to upload with BM5T-14C026-ACC
BM5T-14C026-BBD
BM5T-14C026-AFE
CM5T-14C318-AD
Superb1
17 September 2018
You are the man 24adonis
I thought something was wrong after flash with a black screen.
I'm in the middle of uploading BM5T-14C026-ACC about 45%
I will start over with the right alignment of 14.12.2017:
1) BM5T-14C026-BBG (software)
2) BM5T-14C026-ACE (pictures)
3) BM5T-14C026-AFH (eeprom)
4) CM5T-14C318-AE (signals)
Cheers
Superb1
17 September 2018
Again thank you for your reply, I wanted also to know the latest BM5T type firmware
I see up above that
BM5T-14C026-AAH
BM5T-14C026-AEH
CM5T-14C318-AE
But the pictures or graphics are missing BM5T-14C026-ACC?
Superb1
16 September 2018
24adonis:
Superb1
The firmware can be installed, but only the sound from the PDC will disappear
Thanks for the reply.
Would you know the latest available version of the Bm5t firmware?
I can’t download my firmware anymore if i needed to downgrade
Superb1
16 September 2018
Hello looking for some help, I did post in the English section but this area seems to have more knowledge on the subject.
I have a 2012 Focus ST would like to update my IPC to the newest version
VIN WF0KXXGCBKCS87354
Current Details Are
HW CM5T-14C226-BA
SW BM5T-14026BT I think should be BU (Focus St)
PROM CM5T-14C026-KB
P/N CM5T-10849-AJD
My Car is built Germany so I'd expect my dash to be Europe style firmware.
Can I use?
ST:
firmware: F1ET-14C026 -AAJ
firmware: F1ET-14C026-APG
signals: F1ET-14C318-AC
Superb1
16 September 2018
My Car is ST built Germany VIN WF0KXXGCBKCS87354 so I'd expect my dash to be Europe style firmware.
Can I use?
ST:
Superb1
15 September 2018
^ I should add this is an Australian model, I see you can update to F1ET version
Superb1
15 September 2018
Can any one help provided the correct update filenames for my IPC.
I would like to update to the restyled version
HW CM5T-14C226-BA
PROM CM5T-14C026-KB
P/N CM5T-10849-AJD
Thank you
