Mark12
Mark Abbott, United Kingdom (GB), Ford Focus III
 int(1)
Ford vehicles7 years
Mark12
31 January 2018
Hello, after following everyone's hard work in topic " Installation of a regular bi-xenon " and translating with the help of google, I changed my halogen headlamps to xenon, added HCM, and added front and rear height sensors. I had factory wiring in place and my car is a 2014 focus titanium 1.0 eco boost.
Headlamps: Xenon from focus ST3. Left: BM51-13D155-MA Right: BM51-13D154-MA
HCM: AM51-13K031-CA New unit and had not been previously programmed
Rear height sensor: AV61-5A955-AB
Front height sensor: AM51-13D034-AA For cast iron arm
I checked a titanium x VIN with xenon from the factory on microcat for levelling sensors and HCM, I have used foCCCus to change bcm configuration, headlamps are set to 05 HID, Xenon lamps work and move down and up when ignition is switched on, LED DRL work normal and cornering lights work with the steering wheel position.
The problem I have is that I still have an error on the HCM of missing calibration that I am unable to clear, I have used IDS to calibrate but it warns about a DTC and then fails to complete, I have tried Forscan level and calibration but it also fails, I have tried IDS programmable module installation and it says the module was successfully installed, but even if I run this with HCM disconnected it still says successfully installed? I have also installed the auto levelling headlamp switch inside but I am still unable to calibrate
Can anyone help me out with this and find out what is missing?
HCM Data through IDS, HCM can see both sensors and the values change when pushing down on the car.
HCM ODDTC
HCM CMDTC
Forscan Headlamp Alignment and Calibration error: Service procedure has been interrupted
Forscan HCM DTC
Headlamps from ST3 with black bezel
