After long searching, I managed to gather all the components I need for upgrading to Sync I my stock base radio on FF MK3 :
-display E1BT-18B955-DA
-radio-cd BM5T-18C815-GN
-bluetooth BM5T-14D212-DC
I made the cable according to the schematic.
I'm ready now to put it in the car ... but I need some answers before that :
-is the schematic used OK ?
-the hole for display cooling "system" is 10 mm diameter ?
-what are the steps to write the new parameters with Focccus ?
-should I watch out for anything special ?
Any other advice is welcome !
Thanks ! Regards !
Я изменил верхнюю опору двигателя, низкую опору двигателя, свечи зажигания, индукционную катушку, без каких-либо улучшений.
fratello
25 September 2017
Thank you ! So I need to dismantle 1/4 of habitacle
fratello
25 September 2017
I am very close the moment when I mount the navigation. But, for mounting BT module, I need to dismantle the climatization panel. How to do this ? Can someone to point me into the right direction ?
Thanks !
fratello
11 September 2017
Hi ! How long must be the cable between APIM and ACM ? Thanks !
Hi, Mr.Universe ! Hope you enjoyed your holiday !
Brumi was very kindly , replied to my questions ... Can you, as "master in schematics & wiring", to confirm the answers ...I hope Mr.Brumi will not be upset about this ! I try to avoid smoke from components
Regards !
So ... so far, so good ! Unwinding wiring ... I have identified all the cables in the APIM plug.I identified the USB cable, the microphone jack, the AUX jack.
Next step = where to connect wires ??
- 1 APIM (+) - to pin 1 ACM ???
- 37 and 38 APIM (GND) - to pin 13 ACM ???
- 16 and 17 APIM (I_CAN) - to pins 14 and 15 ACM ???
- 53 and 54 APIM (HS CAN) - to similar colour wires in the floor connector ???
Thanks !!!
Thank you, brum83, for reply ! Yes, I think the cable is from Tourneo ...How long (approximately) must be the cable ?? ..I have non-oem GPS antenna.
APIM is the BT module ? GPSM ..what is this ? Where is located ? And where is located Module Communications Network ?
It's a bit confusing for me ... I would have a complete diagram of connections between the different modules.Maybe that's how I can handle the connection cable.
Thanks ! Regards !
fratello
29 August 2017
Hi ! Im newbie here, please forget me for using english ...
I have FF MK3 hatchback from 11.2011 , with radio "basic". My VIN : WF0KXXGCBKBU62200
I bought these :
-ACM = BM5T-18C815-GF
-Bluetooth = BM5T-14D212-DC
-FCDIM = F1BT-18B955-DB
-frame
-cable = BK2T-14C007 - AEJ (pictures below )
I need advice ... about how to put all this together for upgrading to Nav and reverse camera !
Should I cut this cable and re-connect it according to the correct connection diagram? Or can it be used as it is, without changes ? There are some connectors that do not know their meaning ...
I know the two CD sockets, the USB cable, the BT module socket ... But what's the other sockets for ? Can anyone help me with tips, how can I use this cable ?
Thanks in advance ! Regards !
