kuhler
Jacek, POLSKA - Slask Malopolska (PL), Ford Focus III
Системы безопасности и помощи5 years
Ford vehicles5 years
kuhler
27 November 2019
24adonis:
Работает на фокус?
Работает FOCUS prelift 2014, прошить через UCDS в режиме "forced programming".
kuhler
27 November 2019
мой модуль после загрузки BM5T
Module Name: IPMA
F110 - On-line Diagnostic Database Reference Number : DS-BM5T-19H406-AG
F111 - ECU Core Assembly Number : BS7T-14F403-AB
F113 - ECU Delivery Assembly Number : BS7T-19H406-AD
F120 - ECU Software #2 Part Number : BM5T-14F397-BG
F124 - ECU Calibration Data #1 Number : BM5T-14F398-AG
F162 - Software Download Specification Version :
F163 - Diagnostic Specification Version : 0x03
F188 - Vehicle Manufacturer ECU Software Number : BM5T-14F397-AG
F18C - ECU Serial Number :
kuhler
27 November 2019
hetzer:
Я от мондео перепрошил,всё прекрасно работает. UCDS правда не получилось прошить,а форскан бета взял.
Как установить такой серийный номер ECU ? 😃
kuhler
14 October 2019
Do I need to replace the SASM module for options 1, 2, 3 to work?
kuhler
14 October 2019
ZaQik:
1+2+3 yes
4 no
Thank you.
kuhler
13 October 2019
Dear Users.
Maybe someone tried to mount the IPMA camera in a car with hydraulic power steering (Focus MK3).
Which of the systems associated with it can be activated and will work?
1.Automatic driving beam change?
2.Recognizing traffic signs?
3.Monitoring driver tiredness ???
4. Lane Keeping (needs electric PSCM) ???
Or maybe nothing will work?
kuhler
27 September 2019
Thank you Lukasz.
kuhler
27 September 2019
I have a UCDS interface. Will I be able to upload the AS-Built module and update the immo if I replace the BCM module myself? What is the immo coding procedure after replacing a module, e.g. BCM or PCM? How to do it?
Of course I have two original keys.
kuhler
22 September 2019
ZaQik:
yes, it will work
thx
kuhler
20 September 2019
Hello
I have Focus MK3 2014 with PATS standard key not Keyless. My BCM does not work. I think about installing lift BCM.
Will lidar ACS pre lift CM5T-14F449-AC work with lift BCM for example F1FT-14A073-EG ?
kuhler
11 January 2018
Hi, the Universe
I bought a display without an SD card, this is the first time I try to run navi. I have checked the contacts in the card slot, they looks good. I am trying to insert a normal 2Gb FAT32 SD card, navigation system see this card (engineering mode) as FAT 2Gb.
When I try to insert 8Gb FAt 32 micro SD with an SD adapter, the system can not see this card. I have no experience with this and I do not know exactly how this system should work.
How to set the parameter "# 072 NAVIGATION / TRAVELER ASSISTANCE" and # 127 NAVIGATION SYSTEM "in the UCDS FF3 AsBuild configuration - is this important for MFD5 navi?
kuhler
10 January 2018
Hi.
I have Focus 2011-2014 and problem with SDcard in navigation MFD 5.
A few months ago I replaced a 2-line display on MFD 5 '. I fitted SYNC1.1, SONY panel, voice control, cruise control, GPSM and several other functions. The central configuration of the car (AsBuild) was adapted to the current configuration of the car. Everything is working properly.
Now I bought an SD card with the map "FORD MFD 2017 NAVIGATION SYSTEM SD CARD EUROPE + TURKEY" on eBay and I tried to start the navigation. Unfortunately, after inserting the card into the slot in MFD, the message "Data error. Check SD card" is displayed. In the engineering mode of the display, the card is not visible, it is not "mounted".
The seller sent me another card but the second one does not work either.
My question is whether in a car that was originally without navigation, after mounting the MFD 5 display and setting the new configuration in AsBuild I have to change something else to make the SD card map read properly?
Or maybe the cards are damaged or incorrect? But both?
Regards Jacek.
kuhler
4 September 2017
I have information about SYNC1 from TSB 2013.60:
"The following languages are supported by the SYNC module voice control feature:
• English
• French
• Spanish
• Portuguese
• German
• Italian
• Turkish
• Dutch
• Russian
Polish and Swedish can only be read in the text display. The SYNC module is delivered with 4 languages depending on the market.
1) AM5T/BM5T-14D212-A* English, German, Russian, Turkish
2) AM5T/BM5T-14D212-B* English, German, Russian, Polish*
3) AM5T/BM5T-14D212-C* English, German, French, Italian
4) AM5T/BM5T-14D212-D* English, German, French, Swedish*
5) AM5T/BM5T-14D212-E* English, Spanish, French, Portuguese
6) AM5T/BM5T -14D212-F* English, German, French, Dutch
* SYNC does not support Voice Recognition in this language."
I don`t have information about SYNC 1.1 modules and supported languages pack...
Universe, please tell me, module d1bt-14d212-ed will o.k.? It is cheap, and easy to buy. In other side series *-14D212-R* is expensiv but produced in 2017 and probaly have polish language support. If Yoy know, please write about *-14D212-R* series.
Thx.
kuhler
4 September 2017
No, I'm not sure. Sync1.0 certainly did not recognize Polish language, 1.1 recognizes - I do not know. I know that since the beginning of 2017 cars have started to appear (Fiesta, Focus) with speech recognition in Polish. I'm looking for a SYNC modules with this option.
kuhler
4 September 2017
Universe:
I`m back from vacation
On-line to ask your questions
Hi Universe.
"SYNC1.1 did not support speech recognition in Polish. Recently appeared cars with SYNC1.1 that support this language.
Does anyone know or can check whether SYNC modules D1BT-14D212-RA, E1BT-14D212-RA and D1BT-14D212-RB are SYNC v 5.10 and have speech recognition in Polish? Modules produced 09-2016 and 02-2017. "
Can You help me?
kuhler
3 September 2017
Hi
Установка и выбор камеры заднего вида Системы безопасности и помощи Focus 3
kuhler
17 August 2017
RedPepper
I looking for a 4.2 inch screen with SYNC 1 / 1.1 support and support for video input via pins 6 and 12. I want to avoid another mistake - that's why I ask you for it. Please specify the types of displays that meet these conditions.
Thank you and best regards
kuhler
17 August 2017
RedPepper:
kuhler
This instruction for any screens that have no video input fackra
But only for 4,2' EM5T or also for F1BT ?
kuhler
16 August 2017
I have a question to the experts
Screen EM5T-18B955-RA support input standard video signal on pins 6 and 12. This featue is only in EM5T-18B955-RA or in all series 4,2' EM5T-18B955-xx?
kuhler
16 August 2017
Hi.
Rear view camera display. Display EM5T-18B955-RA support input standard video signal on pins 6 and 12. This featue is only in EM5T-18B955-RA or in all series 4,2' EM5T-18B955-xx?
