Hey guys,
I have a FF22 1.6 petrol engine, and a few days ago I got a P2121-A1 error, witch means a faulty accelerator pedal. A new pedal is pretty expensive. Does the FF3 accelerator pedal fits on the FF2?
Do you know the voltage and resistence of the accelerator pedal and the electrical harness, so I can check the pedal, to be sure that this is the problem?
Thanks for the time and help!
Hey guys,
Thank you Kodicc for your answer!
Because I decided to go with the 265mm, FF2 brake disc, and not the 271mm FF3 disc, I have a dilema. I bought rear calipers that came with 280 mm mounts, and I didn't have any luck on finding 265 mm mounts.
The question: I have 15" wheels, if I put a 280mm disc it will fit? In the front the discs are 278mm, so a 2 mm difference, and the wheels fits without any problem...
Thank you for your time!
Hello,
Does the FF3 rear breakes fits on FF2? The brake disc diamenter on FF3 it's 271mm, and on the FF2 it's 268mm... Can I put the 271 mm brake disc and brake pads, with out any modification? The brake calipers are the same on both models, if so, if I change only the caliper mounts, it will fit?
Thank you!
Hello,
Please forgive me, for using the english language on a russian forum, but I have a question that I did not find any information, anywere .. The ford russian community is the biggest in Europe, so I will ask the question:
The FF3 hatch rear shock absorbers and shock absorbers top bush fit on a FF2 sedan? Thank you very much!
