dazst250
2 November 2017mobile
Just buy off eBay an extension cable
dazst250
1 November 2017mobile
Early sync 3 cars did use a simple gps antenna but if you look at newer 2017 focus it now uses a different aerial with built in gps.
dont worry i will not change the rack, im happy with the front sensors to just do what they do and protect the front from damage.
dazst250
14 June 2017mobile
Texnik:
dazst250 if you have a real ST - you have a steering gear with varible rathio = APA do not exist for the ST from the factory for this reason - PSCM unable to calculate correct angles due to varible gear rathio in steering gear... So - there are no any stock software for you to alive APA |
Thank you Texnik that's great info, I'm not going to go out of my way to get it working as I'd need to change the steering rack for a titanium X version? So I'm happy with how I have it at the moment with the allround sensors. They work perfectly many thanks.
been through that whole thread but nothing to help unfortunately? I have everything needed, I have the driver assist pack which already as the abs with direction fitted from factory, I also have the full wiring that I've had to fit from the front bumper to the dashboard and the extra 2 wires from the dash to the APA buttons.
Id love to get this fully working on mine? but I believe my ST has the wrong pcsm and it cannot be reprogrammed with the software from say a titaniumX?? I have every thing else working all the parking sensors, even the IPC has the Park Slot Found in the chimes section but when I press the park pilot button it just says Park Assist not available please see your manual??? not a malfunction though just a warning?
dazst250
9 June 2017mobile
The RS brake conversion on my ST3 has made my car far better, the brakes are unbelievably good.
swapped out my previous fitted ford park assist on the front and put the VW Touran holders in.
Universe
Hi Universe
Do you know anywhere I can get the sync 3 screen and apim from, nothing on ebay at the moment and the UK just seems to be in short supply of second hand ones??
Cheers
Darren
This is what I have on mine from my 2015 focus ST3 UK model. I don't know if this is any help to you
Module Name: IPC
F108 - ECU Network Signal Calibration Number : F1ET-14C318-AB
F111 - ECU Core Assembly Number : F1ET-14F094-JB
F113 - ECU Delivery Assembly Number : F1ET-10849-AKH
F120 - ECU Software #2 Part Number : F1ET-14C026-ACG
F121 - ECU Software #3 Part Number : F1ET-14C026-ASF
F162 - Software Download Specification Version : 0x04
F163 - Diagnostic Specification Version : 0x03
F188 - Vehicle Manufacturer ECU Software Number : F1ET-14C026-ABH
F18C - ECU Serial Number :
Ive bought UCDS cable and activated and initialised the RCM and all working how it should, Ford wasn't too happy to do this in the UK has they was a bit sceptical if it would work or not!!
furgonIve got a friend at local Ford dealer and my car is going to be in next week so ill get him to activate the passenger airbag switch
furgonThats the same one used in the UK Fiesta aswell
UniverseWhen I initialise the RCM it starts then comes up with Error writing to RCM
I logged it and this is what I get
13:47:54.421 > ATWS
13:47:54.431 > ATE0
13:47:54.438 > ATL0
13:47:54.445 < OK
13:47:54.445 > ATS0
13:47:54.452 < OK
13:47:54.453 > ATAL
13:47:54.459 < OK
13:47:54.460 > ATAT0
13:47:54.467 < OK
13:47:54.467 > ATCAF0
13:47:54.475 < OK
13:47:54.475 > STI
13:47:54.481 < ?
13:47:54.481 > ATST0D
13:47:54.489 < OK
13:47:54.489 > ATR1
13:47:54.496 < OK
13:47:54.496 > ATSP6
13:47:54.504 < OK
13:47:54.504 > ATSH737
13:47:54.512 < OK
13:47:54.512 > 023E000000000000
13:47:54.612 < 027E000000000000
13:47:54.812 > 0210030000000000
13:47:54.902 < 065003003201F400
13:47:54.902 > 0227030000000000
13:47:55.000 < 056703DD38CD0000
13:47:55.000 > 05270447103D0000
13:47:55.098 < 0267040000000000
13:47:56.100 > 042E5B2601000000
13:47:56.193 < 037F2E3100000000
13:47:56.193 > ATZ
Is XGloomx on here to have a look at the focccus software to have a look??
I think thats where its not right when i press initialise ecu its comes up with an error and doesnt allow me to finish it??
dazst250
31 December 2016
fitted all the part today apart from the jumper wire has there is no where for it to go??? I have 1 plug with 9 pins which only 2 populated pins 2-3 green and a yellow/grey.
ive plugged the passenger airbag deactivation switch in and the warning light in but its just coming up with 2 faults saying both are incompatible they are activated through focccus and ive cleared the faults with Forscan but they just come back???
the wiring is correct has ive checked on etis, its has though the Focccus software is not writing to the bcm and rcm properly
any help much appreciated
dazst250
29 December 2016
Cannot fit at the moment has my passenger headlight has decided to throw a paddy and malfunction the adaptive lights so in at FORD
ST/RS parts in black
Im just waiting for the parts to turn up from Ford to do the passenger airbag switch in my 2015 focus ST ill post up pics and part numbers if anyone needs them once I have everything
I think Universe and a couple of others had this problem and returned to the original sw to solve it, so I don't know if there is a solution to this or not??
Thank you, ive got it working to an extent, the buttons now work but it just comes up with park assist not available on the sync2 but if your driving and press it it says to slow down to find a parking space or if your reversing it says take out of reverse to find a space??
I think it is working but there's just something missing and I think it is just 1 wire that I don't know where it goes, pin 4 on the park assist just says wire CCA47 BU-WH goes to 42-3 vehicle dynamic system?? but I cannot access this or find a diagram of it anywhere on the internet
Ive connected 3 missing wires already from connecter C215 to C237 these are pins c215 37=c237 18, c215 36=c237 19, c215 38=c237 28
