Hi, Hoping someone can help me with Focccus. I have a 2007 Focus 1.8TDCi & have installed Focccus & rewired my ELM327 connector for HS-CAN. Focccus connects to the ECU (if I manually select 38400 port speed), but if I try to read any values I get “Can not connect to ECU Switch ELM to HS-CAN”. Are there any particular tricks? What am I doing wrong?
I am needing to reduce mileage on a replacement cluster. Will Focccus do this?
Thanks
