I always remember about the button, but this is not case with my wife
Devillous
14 May 2016
Hi
I want to deactivate Auto Start Stop with FOCCCUS in my ST MK3 FL 2015...
Need some help.
I know it is 222 in Focccus, but afterwards i get an error for all Assistents - Acite City Stop, BLIS, ABS, Airbag and so on...
Initializing the ECU does not help... Deleting all errors does not help as well...
Any ideas?
if you need my VIN - WF06XXGCC6FE26222 - i change parameter 222, Initialize ABS, delete all DTC but the car is still going crazy...
Also, I have Navigation displaced in between speedo and rpm meter - any idea how to activate that?
would be perfect if you could send a link with a tutorial
is it plug and play?
sync 2.0 which is standard in the FF3 Facelift (big touchscreen)
Hi
Could you post the link to the thread where someone has installed the SYNC in pre Facelift Focus?
Just found the foto...
thanks!
