civil-zz:
yes, all of them have the same hardware - ME17.0.2. only one point - seems that AM55-12A650-JH doesn't exist, the last number that i can see is AM55-12A650-JF |
Thank you Civil
You are right, I made a mistake when typing. The correct number is JF
So, if we get one of this PCM and manage to send it to you, would you mind to add support for it in ELMConfig?
civil-zz:
these vehicles have PCM type Bosch ME17.0.2, it is used nowhere except South America market, that's why it is most unknown module type. to add this module support to ELMConfig I need at least one on my table for researches. one time guys from Brazil contacted me with the same question - asked to add this module configuration into ELMConfig. once I had answered that there is a PCM block required physically for this they disappeared  |
Thank you Civil for your answer!
If you are willing to try adding support for ME17.0.2, I will talk to my mates to see if we can get some used PCM and send it to you. If you agree, of course.
If have one boubt. Here we have diferent engines and gear box combinations that I think all use the same PCM, but I'm not pretty sure. The only visual difference is a series of numbers printed in the label.
For example:
C307 GAS 1.6L iB5: 0 261 S07 237 (last module number AM55-12A650-FF)
C307 GAS 2.0L iB5+: 0 261 S07 984 (last module number AM55-12A650-HF)
C307 FLEX 2.0L iB5+: 0 261 S06 984 (last module number AM55-12A650-JH)
Do you think that these are all the same hardware but differ only in software?
Привет, я из Аргентины, и я использую Google перевести на русский, так что простите меня, если я делаю ошибки в письменной форме.
Я хотел бы сделать вопрос к гражданско-ZZ. Фокус MK2.5 продается в Южной Америке с 2010 по 2013 год были оборудованы с какой-то модулей PCM Bosch, которые в настоящее время не поддерживается ELMConfig. Как вы думаете, можно было бы добавить поддержку в будущих версиях? Мы группа, которая с нетерпением ждем, чтобы иметь поддержку PCM для наших автомобилей, чтобы иметь возможность активировать круиз-контроль, поэтому мы готовы помочь в тестировании необходимо, и сотрудничать с пожертвований на проект либо.
Заранее спасибо
Оригинальный текст на английском:
Hi, I’m from Argentina and I’m using Google to translate to Russian, so excuse me if I make mistakes in writing.
I would like to make a question to civil-zz. Focus MK2.5 sold in South America since 2010 to 2013 were equipped with some kind of Bosch PCM modules that are not currently supported by ELMConfig. Do you think it would be possible to add support in a future version? We are a group that are looking forward to have PCM support for our cars in order to be able to activate cruise control, so we are willing to help in testing if needed and collaborate with donations to the project either.
Thank you in advance
