malisz182
24 July 2016
FalcrumThanks for advice i cut the body its only way to do this.
ILISHi on your movie the move of lamp is long:
And others have short move (me to)
How you get movement so long?
In my lamp its short distance here:
Hi
I can not to remove the engine from right lamp.
How to do this? The left lamp was easy, because to remove this i was must to rotate left (to upside). But in right headlamp i must rotate left to, but there is a bottom and i cant to remove engine
Help
My camera have built-in wire.
This is connector from my camera, and socket from module.
I made this picture it is correct to build wire ?
Yes I know, but the module have firewire connector, and camera have GT17VSN-6DP-HU connector. How to connect this? How to build the wire?
Can someone tell me how is build the wire between Camera and Camera Module?
Google translate:
Может ли кто-нибудь сказать мне, как это построить провод между камерой и модулем камеры?
Hi a have a question.
Is the motors in HID are the same like in AFS ?
I have 2 engines from AFS lapms, it will be ok to auto leveling?
