hello!
I have a problem with heated seats, that probably nobody in polish forums seen before. So I decided to ask you guys for help.
first of all sorry im writing in english, but I cant speak russian, unfortunately
. I would really love to, cause this forum is awesome and helped me alot already.
I have a 2004 focus mk2. it did not have heated seats out of the factory, but it has all of the wiring needed (weird version from the beggining of the production, its not ghia but it has ghia wiring). so i bought the switch panel and heated seats. seats are pretty new, from 2011 focus mk2fl, only 30 000km on them.
all fuses in GEM (86 and 70 - pre-FL gem) are OK, switch has power, pin 5 in switch is connected to pin 17 in green seat connector, seats have power from GEM. after turning on the heating there is 12v on the 17 pin in the seat connector. everything seemed just fine. but after instaling the seats - nothing.
I rode for a week and tried turning the heated seats on and off occasionally, and after few days I noticed that driver seat sometimes work (but really only sometimes, like one in 10 tries) when put to "5" position. then, after my ass got burned and I changed to anything less than "5", it would stop working at all, and would not start again. ocassionaly, after some time, it would start working again, bur not every time. very weird. it happens very random, i cant find any connection to engine RPM, other electric equipment, temperature, anything. just random. mostly does not work, but sometime does.
on the other hand I never noticed passenger seat working. it may be because i tried turning it on a lot less times than driver seat, but still - it never worked for me. I took it off and checked the heating pads by checking the circuit between pin 10 in the blue seat connector (ground) and YB (yellow-black) pin coming from the heating module under the seat - the circuit was ok, so the heating mats seem to be good.
so something strange is going on. on the passenger side - it may be heating module failure. is there any way to check if its broken? tomorrow I will do some tests of the module with electric multimeter and post it in the table.
on the driver side - i totally dont know whats going on.
any ideas guys?
thank You
by the way - how do I insert images to the post?
